Scratch Build – In Progress Project: Silent Shadow
Discussion in 'Project Logs' started by Bl00m, 17 Jan 2011.
  1. Bl00m
    Bl00m What's a Dremel?
    17 Jan 2011
    Hi all here at Bit-Tech!
    I´m new here and have a project that I would like to present to you!
    Let me introduce Project Silent Shadow, This is my first Modding project.
    The main thing with this project is that I´m going to build a computer chassi from ground up.
    The color theme that the build have is Black and Red, I will also try to keep it as clean as possible. I will also make this an all watercooled build.
    The chassi is going to be made out of aluminum, what methods I will be using to get all the cheetmetal as I want, I will have to figure that out as I go.
    The hardware That is going in to this build will come during everything but I know one thing and that is the PSU that the Swedish company Fractal Design is sponsoring with, it´s an Newton R2 800W, witch I will be sleeving.
    Hope that this is making some Bit-Tech members interested in following my journey.
    Keep in touch updates is coming soon:)
    Excuse my English, it´s not all good but I hope you understand what I´m writing.
    Big thanks to:
  2. KidMod-Southpaw
    28 Sep 2010
    Can't wait to see this started. Mod on mate!
  3. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    Hi bro! be sure to get those pictures I know you have uploaded in this thread! It's against the Bit-tech rules to start a worklog without a build, and the only way for us to know you have one is from pictures. :-D
  4. Bl00m
    17 Jan 2011
    It will come soon now! I forgott this one:( sorry but like aI said it will come maybe tonight;)
  5. Bl00m
    17 Jan 2011
    Okey so here the long expected update:
    there will be more of them soon:)
    Fractal Designs Newton R2 800W:
    Some pictures when I was sleeving the 24 pin:
    24 pin done:
    And now some PCI-E kabels have to be sleeved:
    In lack of real tools a couple of staples had to do the trick:
    Now to some pictures of the finished cables.
    And here we have the aluminum that will become the case:D
    Stay tuned more is coming!:D
    /Patrik
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Nice shots for a first timer, cant wait to see what you up to!! :) Mod on!
  7. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    nice bit of sleeving that mate:thumb:,what do you have in mind for the case shape,square,rectangle?also how thick is that alu? ill be pulling up a chair for this.....mod on bro!
  8. Bl00m
    17 Jan 2011
    Thanks:) It will be like an ordinary case since this is my first build:)
    I will be using 2 and 5 mm aluminium to form the case:)
    And here is a drawing from Solidworks:
  9. that_du^de
    29 Nov 2010
    looking good:thumb:
  10. Bl00m
    17 Jan 2011
    Okey time for an update.
    Here we have The beautiful things that Aquatuning.se Sponsored me with:
    Sorry but the pictures are quite bad, I think I got some Dubai dessert sand in the camera from my vacation.
    Here are some things that I ordered from coolingstuff.se
  11. Bl00m
    17 Jan 2011
    OH what is this?
    Another update so soon?:D
    Yes Here are some more sleeve for the tubing and the color-x delivered from MDPC-X,
    And oh another package! From QuietPC! The nice people at QuietPC are the newest of sponsors and contributes with some Himuro HDD coolers and PCI brackets.
    //Bl00m
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Subscribed should be good Bl00m :D:thumb:.
  13. Shael
    Shael What's a Dremel?
    19 Jan 2011
    Ahh another scratch build to watch :) I like the case design - Subscribed :thumb:
  14. Bl00m
    17 Jan 2011
    New Update and New Sponsor, Bitspower
    Yeah okey so now it´s time for another update, unfortunately without pictures.
    But here it is Bitspower a great manufacturer of watercooling products goes in and sponsors with some fittings for the watercooling.
    Here is the products:
    Model name: BP-MBCPF-CC6
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758874&kind2=52
    Amount: 16
    Model name: BP-MB45R2CPF-CC6
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758838&kind2=52
    Amount: 6
    Model name: BP-MB90R2LCPF-CC6
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758853&kind2=52
    Amount: 4
    Model name: BP-MBWP-C06
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758924&kind2=52
    Amount: 12
    Model name: BP-MBWP-C04
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758922&kind2=52
    Amount: 2
    Model name: BP-MBWP-C03
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80758921&kind2=52
    Amount: 2
    Model name: BP-LGS1-UVRD
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80757089&kind2=40
    Amount: 1
    Model name: BP-WTP-O10-DRD
    URL: http://www.aquacoolingtechnology.com/html/product/pro_show.aspx?num=80757186&kind2=14
    Amount: 4
    hopefully this is all I need:)
    Big thanks to Bitspower!
  15. Bl00m
    17 Jan 2011
    Long awaited update!:D
    So it was some time since the last update in this project so it´s about time!
    So what has happened since the last update?
    Yeah some waterblocks from EKwaterblocks, The Bitspower fittings and even another XFX 5870 has arrived to my door.
    But the biggest thing this time is that the first cuts has been done in the aluminum.
    Enough Talking, time for some pictures hope they looks better then before.
    We start of with the shipment from EK, the onlything that is missing is the waterblock and backplate for graficscard number 2 that arrived after the pictures was taken, so it might appear later on.
    Got some fashion advise from EK:p
    5870 V2 backplate:
    That was the EK shipment.
    Next up is Bitspower:D
  16. Bl00m
    17 Jan 2011
    The update continues!
    Here we have the graphics card and The fittings that wonderful Bitspower Sponsored with:D:D
    Here we have both of the graphics cards
    BITSPOWER!!!!:D:D
    Next up is some CNC action:D
    //Bl00m
  17. Bl00m
    17 Jan 2011
    Update continues! CNC:D
    Okey so now we have arrived to probably the most interesting part of this big update!
    This will end this big update, but it will come some more soon:)
    //Bl00m
  18. chomps1891
    chomps1891 What's a Dremel?
    11 Mar 2011
    nice work dude
  19. KidMod-Southpaw
    28 Sep 2010
    Haven't looked at this for ages but BLOODY HELL you've made some progress mate! Great job on the sleeving and those are some yummy orders!
    Fantastic. Sums up the log.
  20. djzic
    djzic Bokehlicious!
    8 Nov 2010
