Project: Sli 'n' Shiny Wavemaster
Discussion in 'Project Logs' started by coolmiester, 16 Feb 2005.
  1. ModKid
    ModKid What's a Dremel?
    5 Jul 2002
    the wavemaster uses an ordinary coolermaster frame, stock side panels with a different front piece, stick a ccfl to it and name it wavemaster :)
    Yes the cm case has some sharp edges, but not many though. Overall a really nice case, sturdy and imho prolly stronger than any lian li out there.
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I don't know where Tom's been sticking his hands in a Wavemaster but I've got two of them and never had any problems with sharp edges. My only complaint with the Wavemaster (and all CoolerMaster cases for that matter) is the hard drive bay is connected to the 5 1/2 " Bays. Other than that the case is really easy to work with. Solid construction, beautiful paint job (nice and shiny on the Black Version). Sorry for the o/t part. I def love the look of the dye with the mirrored windwo. Anyone know where I can get an equivelant looking dye in the US?
  3. ModKid
    5 Jul 2002
    dangerden.com ?
    frozencpu.com ?
    Xoxide.com ?
  4. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    At last :clap:
    Be updating as soon as i have time to start fitting everything :thumb:
  5. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Now you're talking :hip: Only thing is, you're going to need a hell of a PSU to run them :naughty:
  7. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Ooohhh very sexy! Everyone likes twins :naughty:
    <A88>
  8. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
  9. alastor
    alastor Minimodder
    6 Sep 2004
    :jawdrop: one of those things is worth about the same as my whole rig...
    But wasn't the original plan to use 6600gt's? Not that I'm bitter and jealous or anything.... :D
  10. (X)TORNADO(X)
    (X)TORNADO(X) What's a Dremel?
    26 Feb 2005
  11. fohkus
    fohkus What's a Dremel?
    12 May 2002
    wow that is definately overkill. Darn you.. i wish i could just have one of those!
  12. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    All I can say is that too much money is being spent on this project :D
  13. Rocket733
    27 Dec 2003
    Lol is there such a thing :naughty:
    Gotta love the way those are gonna look with their waterblocks on.
  14. Firehed
    15 Feb 2004
    Pretty much only the Antec True550 EPS12v modded to dual PCIE power plugs (see my log) or the PC Power and Cooling SLI model. Or so I've heard... that's based off of FX55/2x6800u/2 optical/2-3hdd I think. Somewhere in the depths of the Anandtech 94?-page A8N-SLI discussion.
  15. Jock
    Jock Banned
    12 Dec 2004
    The 600w Enermax Noisetaker SLi PSU would be worth considering :)
    Thats what I'm using in my SLi rig.
  16. coolmiester
    31 Dec 2002
    Woot.......i got one of them :)
    /...........but its only got one Sli plug :confused:
  17. Firehed
    15 Feb 2004
    An SLi PSU with only one PCIE power plug?
    Hmm... that might say it's not quite cut out to be an SLi PSU. Kinda like the thermaltake one some site reviewed where the PCIE power plugs didn't fit because the connectors were messed. :rolleyes:
  18. mattthegamer463
    26 Nov 2004
    8 of my rigs is worth half of one of those!
  19. coolmiester
    31 Dec 2002
    Its model number EG701AX-VE(W) and it says on the box it has 2x 6 pin PCI-Express VGA Connectors for SLi Compatibility............lol i can only find one!
    The GFX cards came with the 6pin plugs that split into 2 male molex (each)
    I'm hoping that a 6pin plug from the PSU and one from the GFX card into two of the molex from the PSU will do it...........nothing like wishful thinking to will it to work :D
  20. stevehp
    stevehp What's a Dremel?
    6 Jul 2002
    There are different versions of that power supply the version you should have snagged is called the EG701AX VE SFMA 2.0 SLI this one has a hybrid mains plug where the 4pins of the 24pin come off so you can use it on a 20pin board chucking the extremely bulky adapter of the older versions plus it has ATX 2.01 specification, and also the dual PCIe 6pin connectors(not called SLI plugs FYI) the only way to tell is if the kit came with a mains ATX adapter. There's also a newer version from Enermaxs All-in-one series which will support dual processor boards as well with the 8-pin cpu power connector.
