Project: Sli 'n' Shiny Wavemaster
Discussion in 'Project Logs' started by coolmiester, 16 Feb 2005.
  1. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    I would like to give a warm welcome to the praetorians sibling, the praetorian 731:
    *PUKES* I wanna kill that stylist, the praetorian is about minimalist not all the crud on the front
  2. (X)TORNADO(X)
    (X)TORNADO(X) What's a Dremel?
    26 Feb 2005
    Uuh very shiny indeed... :thumb: :clap:
  3. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    It could have som potential... :confused:
  4. unrealhippie
    24 Jul 2004
    review here says same inside, new outside. Now personally I thought it was the outside not the inside of the praetorian that made it special :sigh:
    Inside is nice, but its still using 80mm fans, they should be on 120mm by now!
    Still I wouldnt say no if someone offered me one :p
  5. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    what have they done the preatorian used to be a nice case :wallbash:
  6. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    all they need to do is flatten the bumpy bit, and put thier original mesh back. And replace the 2*80mm fans at the back it a 120mm. Then it'll be a seller :)
    Anyway,
    Loving the case coolmiester, love all your wavemaster range :thumb: :thumb:
  7. fohkus
    fohkus What's a Dremel?
    12 May 2002
    damn.. they ruined it. I'm glad I still have the older series.
    any update w/ the shiny wavemaster? :D
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Sorry to anyone who has a Praetorian but that thing is nasty. I'm sure i read somewhere they had actually changed the designer for that case.
    Sli cards will be here Monday so update and pictures shouldn't be too long :)
    Cheers :clap:
  9. Shinymod
    Shinymod What's a Dremel?
    20 Dec 2003
    :jawdrop: that Sli block pair looks.... godly!!
  10. unrealhippie
    24 Jul 2004
    Nice!
    Im pretty sure there was a change in designer because just compare the original to the "731", they dont even look similar!
  11. cool_dude
    26 Aug 2004
    nice, cant wait till monday dual SLI watercooled :hip:
  12. unrealhippie
    24 Jul 2004
    Unfortunately coolmeister was so beaten to the all in one solution:
  13. Nexxo
    23 Oct 2001
    That one has been around for a while. But it only offers a solution for the narrow-tube German systems, and it will only fit an Asus SLi mobo due to the distancing of the two GPU slots. Coolermeister's solution is a bit more flexible.
  14. coolmiester
    31 Dec 2002
    That's the 2x 512mb version and remember its 10mm :p
    The Inquirer leaked this article on Thursday 20 January so i've known about it for a while!
    Its always a bit more satisfying coming up with your own solution and to see DD go down the same route shows it might just work........i hope!
  15. unrealhippie
    24 Jul 2004
    Coolmeister is using the Asus though right for the extra space, so no difference there...
    And the small bore systems arnt that much different, quite alot perform similarly to large bore.
    But the matter of fact here is, the DD blocks look better :thumb:
  16. coolmiester
    31 Dec 2002
    The only problem is though if you try to add a 10mm block to a 1/2" set-up you end up restricting things way to much (more so with a dual Sli block) even if you re-tap the block to fit 1/2" barbs which i tried on the CoolFX below.......the TDX will suffer considerably.
    Moral of the story is try to keep everything low-flow or everything hi-flow!
  17. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    no offence but the praetorian is disgusting in my appnion, i think it's vile
  18. unrealhippie
    24 Jul 2004
    I hope your talking about the Praetorian 731 (new one) not the old one!
  19. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    What's all this got to do with coolmiester's project? Back on topic peeps, any sign of those cards from Gainward Paul? :hip:
  20. Dean_j2001
    1 Apr 2003
    yer i was
