Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate and thats a long time ago.You can learn everything it just takes time. :D
    Thanks mate. :D
  2. Cheapskate
    13 May 2007
    It's always neat to see a pro welder's work. Have you thought about welding a stainless steel reservoir instead of using stock WC gear? -It could be awesome.:D
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate and i already weld a couple of custom stainless steel reservoirs.Here is one of them.
    Im gonna think about it to use 2 of them in this project. :D
    Waynio likes this.
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: Damn those look awesome. :D:clap:
  5. avolla
    avolla Mini Water Modder
    26 May 2010
    Absolutely love what you're doing with this. I'd kill to have your welding skills. It is a shame to sand them down.
  6. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Waynio. :D
    Thanks mate. :D
  7. bulldogjeff
    2 Mar 2010
    Oh yeah!!! Another epic desk mod by the looks of it. Looking forward to this one.. Looking really neat and tidy .
  8. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Fantastic Paslis!!!
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 4. 12 Feb 2012
    This weekend i made some progress.I started to work on the frame for the cables etc.
    M5 thread rivets ( dont know the english word )
    The pneumatic tool.
    I made a short movie how this tool works.
    http://www.youtube.com/watch?v=EVyycuAtFKM
    Finisht the frame.
    After that i made the mounting plate for the frame out of 3mm aluminium and bend it.
    Then i drilled and countersunk the holes and mounted the plate on to the frame.
    After that i drilled and countersunk the holes inside the desk body and mounted the frame on the desk body.
    Now thats finisht i can start to make the bracket for the lifting column.For this i used 3mm aluminium.
    First some cutting.
    Then i drilled and countersunk the mounting holes.
    Time to mount the bracket on the frame and mount the column on the bracket.
    Now its time to test the column.I'm very happy with the result.Ofcourse i made a small movie while testing the column.
    http://www.youtube.com/watch?v=XuQd1qhDOtk
    This was it for today. :D
  10. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate. :D
    Thanks quizz-kid.
    peteski likes this.
  11. peteski
    peteski long live the pc
    8 Jun 2011
    Paslis again you amaze me with your skill. you must have a good boss aswell to let you use your work place at the weekends. keep up the good work mate :rock: :rock: :rock:
    P.S +rep and 5 stars
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks peteski and your right about my boss he gave me a key to the shop so i can use it whenever i want. :D
    Thanks for the rep and stars.
  13. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Very nice, that will lift 2-3 monitors easily?
    The controller is for both leg and monitor, nice clean unit.
  14. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks craig and yes that will go easily as it can handle 800N.And your right the controller is for both leg and panels.
  15. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Verry nice paslis!!
    Hihi :D!
    gogogo :D
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nut rivets are great, I need to practice more at it on countersunk ones, can do flanged ones no problem but countersunk ones went in awful for me with a manual tool, looks like the air tool does it nicely. :D
  17. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Make me one too , pleasee!
    this is just fantastic, i think that you should use a lot of coppar details into this build, bitspower has some awsome copper oldtime looky fittings
  18. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate and yes you got my custom welded reservoirs. :D
    Thanks Waynio now i know what the english word for those are.:D If you can get hold of a air tool use it mate it works like a charm.:D
    Thanks mate and i was thinking using copper details for this build because the colors im using are titanium grey and blue so copper will look very nice imo. :D I will look at the bitspower fittings for sure.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Oh it will look seriously nice that colour combo. :)
  20. KoSoVaR^
    19 Dec 2010
    Awsome!
    I think that alphacool has a lot of copper fittings, tube reservoars etc aswell check them out aswell, they have started to really use copper more and more on thier products now
