Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. wejjy
    wejjy Minimodder
    9 Aug 2010
    Amazing work my friend, your skills are just too good for this site you make us all look really bad at welding!
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Skillzzzzzzz man!!
  3. motorsportcfd
    motorsportcfd What's a Dremel?
    25 Jan 2012
    Great TIG work, mate! Keep up the great work, I am loving this project!
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks KoSoVaR. :D
    Thanks for the compliment jeff. :D
    Thanks craig and thats what i like doing things different. :D
    Thanks for the compliment mate. :D
    Thanks for the compliment wejjy.:D
    Thanks for the compliment quizz-kid. :D
    Thank you for your compliment mate.
    Waynio likes this.
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: Soooooooo niiiiiiiiice :D:clap:
  6. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate.I was having a blast making them.To be honest i never have seen 90 degree stainless steel reservoirs before. :D
    Waynio likes this.
  7. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    WOW, just love it, some seriously good work going on right here, I wish I had access to the tools to do things like this, keep up the good work and very much looking forward to finished result :D :thumb:
  8. TheBigFella
    TheBigFella U jelly?
    20 Feb 2012
    WoooooW:jawdrop::jawdrop:
    Amazing skills :clap::clap:
  9. Cheapskate
    13 May 2007
    :jawdrop: <-- if this avatar had a tongue flopping out of the mouth, It would describe my response perfectly.
    The only thing they lack is a funnel-top for easy refilling.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Can't say I've seen a res like it before neither :D the sanding just makes your welds unbelievably good. :rock: rep if I can :D
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks coolamasta. :D
    Thanks BigFella. :D
    Thanks Cheapskate and its not to late to make a funnel-top if im right about what you mean.
    Thanks mate. :D
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 6. 25Feb 2012
    This week i had some time to draw the I/O panel with the lasercutter software.After that i bend the panel.Today it was time to mount it in the desk body.
    The I/O panel.
    First i tapped the holes with M4 thread.
    Then i did the measurements for the hole where the I/O panel in gonna be mounted.
    Cutting out the hole.
    Drilled and countersunk the mounting holes.
    Mounted the I/O panel inside the desk body.
    Test fitting with an old mobo.
    It fits like a glove so on to the next job.
    More to come. :D
  13. myrizzle
    myrizzle What's a Dremel?
    23 Nov 2011
    Ohhhh, that is nice :)
    Can you be persuaded to send the drawings of the I/O Panel out to me? Or are they only for yourself? Mad props :)
  14. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Awesomeness in its wow kingdom!!!!! :)
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe: Too good, looks like one pulled from another case it's so good. :D
  16. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Awsome :D, wouldnt it be better with 9 pci-e expansionslots instead of 7 ???
  17. Cheapskate
    13 May 2007
    Isn't an ATX enough power?
    Would you want a rig generating that much heat just over your crotch?
    -Forget I asked...:worried:
  18. peteski
    peteski long live the pc
    8 Jun 2011
    nice work mate :rock: :rock: :rock:
  19. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Real nice back-plate, any chance you will fill the corners and short side on pci area to have even flange all around. :)
  20. Selfmindles
    Selfmindles What's a Dremel?
    25 Feb 2012
    Nice work!!!!!
