Case Mod - Complete ⭐ Project: Tweaked Meshify S2
Discussion in 'Project Logs' started by TerHorstCustoms, 31 Jan 2020.
  1. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    There is still quite a list to do:
    -Mount the frame inside of the case.
    -Testfit the distro + cable management plate.(When its done at the the CNC Guy)
    - Loop prep (Flush rads, mount gpu block, delid cpu)
    - Make loop (all the beding stuff and mounting)
    - Testloop (EK kit)
    - Modify cables to lenght.
    - Fill loop and do a nother leak test.
    - Setup system fully (software)
    - Make photo's and video.
    - Edit video.
    And then I'm about done :)
    ifohancroft likes this.
  2. ifohancroft
    ifohancroft Minimodder
    11 Jul 2018
    Holy..!
    I totally forgot that you are also going to use the case :D
    I say, turn this into a scratch build :D It's awesome even on its own.
    TerHorstCustoms likes this.
  3. TerHorstCustoms
    29 Jan 2020
    Well I could do that that but then some of the designed stuff will not fit. When I look back at the design now there that might have been a smart thing to do :)
  4. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Do you have to take the rads off to get the GPU out?
  5. TerHorstCustoms
    29 Jan 2020
    With the aircooler I needed to take off one rad to mount it. When its going single slot with a waterblock that shouldnt be needed anymore :) In this case that was fine because it is Just a test fit and getting the system ready for a first boot and install all the software before the blocks go on.
    MLyons likes this.
  6. ifohancroft
    11 Jul 2018
    Yeah, I think it can also be made to look and work amazing on its own. I am starting to see how it would look finished though. It would be ****ing AWESOME!
  7. TerHorstCustoms
    29 Jan 2020
    I guess I'm gonna finish this build the designed way and think about a stand alone version of the frame for a next one :)
  8. TerHorstCustoms
    29 Jan 2020
    New update after I had some extra time during the weekend.
    The frame is mounted inside the case and it fits perfect :)
    Next up is installing the blocks for the cpu and gpu and start working on the loop :)
  9. ifohancroft
    11 Jul 2018
    It looks ****ing amazing! Those angles kind of remind me of a theater or home theater setup, with the screen in the middle and speakers on the side, angled inwards :D
  10. MLyons
    3 Mar 2017
    god damm that's a sexy build.
  11. The_Crapman
    5 Dec 2011
    Fantastic. A clever design and looking great so far.
  12. TerHorstCustoms
    29 Jan 2020
    Thanks :) I'm not sure what does it but those 360's realy look like some speakers.
  13. TerHorstCustoms
    29 Jan 2020
    Thank you! More to come soon :)
  14. TerHorstCustoms
    29 Jan 2020
    Thanks :) Trying to make something fresh looking.
  15. arduum
    arduum Minimodder
    10 Mar 2015
    amazing:clap:
    ifohancroft and TerHorstCustoms like this.
  16. TerHorstCustoms
    29 Jan 2020
    Thank you :)
  17. TerHorstCustoms
    29 Jan 2020
    Update time :)
    My first delid done on this build
    Then it was time for some awesome waterblocks
    [​IMG] [​IMG]
    And the first testfit with all the block inside the frame. That is mounted to the case after 4 hours of tweaking stuff :worried:
  18. Cheapskate
    13 May 2007
    SNUG
    Oh, man. You still have to sneak the wires in too.
    While getting a foot or a cat in the shot does make you an official BT modder, I think you put way too much work into it. :lol:
  19. kim
    kim hardware addict
    10 Jan 2016
    Splendid, awesome: the idea, the3D renders, the case, your work and the pictures: absolutely flawless and beautiful, you're really talented :wallbash:
    I also spotted out a drooling collection of GPU's on the shelf :grin:
  20. TerHorstCustoms
    29 Jan 2020
    This was a testfit with all the blocks installed. Lets keep it at snug for the gpu with only 1 mm clearance between the end of the card and the new frame :worried:.
    The hardware has to come out at least 2 more time before the final install :lol:. Next big step would be the distro with buildin cable managment. But is a project on its own with 18 custom parts that need to be milled :) . Only found out about the foot in shot after I was done with the photo's, it was all good that angle tho ;)
    After all the hours of designing in CAD I don't mind putting all the hours in, I'm just realy happy that most parts fit like planned :)
