Project:Uber Silent pc 56k* warning
Discussion in 'Project Logs' started by sladesurfer, 12 Jun 2007.
  1. sladesurfer
    sladesurfer What's a Dremel?
    14 Jul 2006
  2. M_D_K
    M_D_K Modder
    3 Apr 2002
    Whats happening with this project and or what are you doing to the case. A little bit of text explainning what your doing would be handy.
  3. Guest-23315
    Guest-23315 Guest
    It appears that he's trying to build a PC thats as quiet as possible.
    If that was the case, why are you still using the stock Intel cooler and why are are you using a 1200W Thermaltake PSU?
  4. Jipa
    5 Feb 2004
    Cable management is rather outstanding though..
  5. forester joe
    forester joe shhh. can you hear your PC?
    24 Oct 2005
    right on
    my thoughts exactly!
    interestingly enough, it would seem that many gamers over estimate the watt demands of their system. if you try out the extreme psu calculator you may be surprised at how much power you actually need.
    I'm planning a system with a dual core CPU, 2GB RAM, 2 HDs, and a high midrange graphic card, with room to upgrade to SLI, and I still seem to be well under 400W!!!
  6. keir
    keir S p i t F i r e
    5 Oct 2003
    It doesn't look very quiet at all!
  7. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    lol, most 1Kw+ PSU's sound like jet engines, and well the intel stock fan is a steaming pile of **** for silence.
    Not to sure on what graphics card that is or the cooler fitted to it. i first though maybe its a 8800 GTS but the built in heatpipe is running the wrong way. Is it an Arctic cooling cooler, nope as theres a heatpipe in it.
    Could it be an 8600 with a massive cooler?
    you need to modify it in some way to belong here.
  8. widmod
    widmod Minimodder
    9 Oct 2006
    use a passive psu would be more silent 1200w seeem too much but i don't know what you'll include in your project. some sound damping mats might be handy too or hdd enclosures...ans so on :geek:
  9. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Yeh nothing has actually happened here, you've just assembled the PC with good cable management but a MASSIVELY over-powered psu and stock cooler have been included, along with the stock gpu cooler. not that there are many after market ones yet.
  10. identikit
    identikit Minimodder
    5 Jun 2004
    It looks like somebody went out of their way to make an uber noisey PC. I like the HDD silencing method, but how secure is it?
  11. kenco_uk
    28 Nov 2003
    Well, from the title, it's a project, so I sit here in the hope that plans are afoot to quieten this beastie.
  12. widmod
    widmod Minimodder
    9 Oct 2006
    he modded something? these silencers look quite stock with that case
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    He got the PSU cheap through work.
    And like it's been said: dude, once you get your HD2900XT 1GB, away goes the silence!
  14. identikit
    5 Jun 2004
    That's the stock HDD mounting method?! :lol:
    Never seen anything like that before.
  15. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    For those who are confused, it appears that the hard drives are mounted not on the stock retention brackets, which do seem to have some padding, but are rather suspended by nylon string to decouple their vibrations from the case.
    As others have said, it seems a shame to put that kind of effort in and then ruin it with a high-wattage power supply. I don't recognize the cooler and it's got a large fan, so I'll accept that perhaps it is quiet. As for the stock Intel cooler, it's a bit noisy but if your motherboard has automatic fan speed control it'll barely even spin most of the time.
    And, I saw that someone suggested a fanless power supply. I'd avoid that if I were you; they tend to die rapidly unless your case already has some rather impressive (noisy) airflow.
  16. GoodBytes
    20 Jan 2007
    The problem with the current setup of the HDD is that you can't attach the frontal bottom fans... I tried this (or maybe a thin fan would work)
    BTW, this case, the Antec SOLO, has everything you need to make cable management THIS nice. Just don't open the other side panel...
    http://pages.infinit.net/eps/other_side.jpg (they are a lot of cables which my camera had a hard time to see as they are black... shame, but you get the idea)
    sladesurfer, here is a trick to make the power button not only more solid, but stop from vibrating. Take a normal case screw, and screw on the back of the button. Like so: (sorry for the bad picture)
    http://pages.infinit.net/eps/powerbutton.png
    Also, if you look a at a certain angle on the side of the frontal panel of the case, you can see screws... I painted them black so you really don't see them :)
    For CPU fan noise, I have a Zalman fan, set to minimum speed with fan-mate, and I enabled Cool'nQuiet. In results, under idle my AMD Athlon 64 X2 4400+ S939 is at 36C, and at load 42C. At 36C the fan is stopped literary. So you get quiet when you listen to music and surf the web. Of course all my case fans are set to lowest speed, and my PSU is a corsair, as my signature mentions. You can't get quieter.
  17. GoodBytes
    20 Jan 2007
    What I am surprised is that your frontal USB/audio and not connected and are beige.. mine are shiny black like the case. And the plastic texture of the frontal bay to insert a floppy or media card reader seams to have a different texture then the other plastic panel above it, not on mine, I guess its your camera.
    Maybe the case differs depends on the region?!?
    anyway, I see many people putting their optical drive on the second (starting from the top) slot. Why not on the first? There are plenty of room in the first one.
  18. MrWizard6600
    MrWizard6600 What's a Dremel?
    20 Jun 2006
    if youd said that a few months ago i woulda flamed you.
    Thermaltake has taken a huge turn for the better by signing with channel well. They've also adapted better water cooling designs (spicifically the TMG rads)
  19. Heero195
    Heero195 What's a Dremel?
    12 Jun 2006
    Has anybody found out just what the point of this log is ? Where is the modding ? :wallbash: Get on with the cutting..
  20. widmod
    widmod Minimodder
    9 Oct 2006
    its me the so called "somebody" :read:
    i had no expirince with these but there are semii-fanless ones too which switch their own fans on just for a few seconds.
    i wasn't confused at any time
