PSU Recommend a new psu
Discussion in 'Hardware' started by halfinched, 7 May 2013.
  1. halfinched
    halfinched What's a Dremel?
    19 Jul 2010
    Hi
    Finally found out why my gaming pc died and it turns out it was the psu so I need to get hold of a new one.
    Rig specs:
    Asus Maximus V Formula
    Intel Core i7 3770K 3.5GHz
    Corsair Memory Vengeance Racing Red 16GB DDR3 1600mhz 2x8gb
    Asus Xonar DX
    Crucial 256mb SSD
    Antec Khuler H2O 920
    Sapphire Radeon HD5870 Vapor-X
    Samsung 1TB HDD
    DVD Drive
    This was all running off an Antec Truepower 750W PSU which I think was well within the capabilities of the PSU so 3 years of not very much service seems a little rubbish to me. If you can recommend another PSU / Brand let me know.
    thanks.
  2. vector01
    vector01 What's a Dremel?
    6 Apr 2013
    Corsair enthusiast 80+ series 650 watt or higher PSU will do a good job.
  3. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  4. Cei
    Cei pew pew pew
    22 Mar 2008
    Vote for a Corsair HX or AX unit here.
  5. Shirty
    18 Apr 1982
    The new generation CX modulars are pretty good now too, without the huge premium for diminishing returns. The only real difference is that the warranty is a couple of years less than you get on the top spec models.
  6. halfinched
    19 Jul 2010
    @MSHunter - blatantly managed to miss that in the excitement of having a good excuse to buy new bit of kit that missus can't argue with.
    XFX Black Edition 750 - £100 - 89% (Modular) seems about right but will take a look at the corsair HX and AX as well. Thx.
  7. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I have a bequiet Dark Power Pro - It's a lovely PSU. though I think they are quite expensive if memory serves correctly.
  8. halfinched
    19 Jul 2010
    Had a quick look - am veering towards this: XFX Pro Black Edition 750W Full Modular Power Supply
    mainly due to bit-tech rating. I've never actually bought a fully modular psu before so this may be a bit of a dumb question but do they come with cables or do you buy your own?
  9. Shirty
    18 Apr 1982
    They come with.
  10. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Sorry I'm at work, that came out a bit harsher then I meant. :worried:
  11. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    I am a huge fan of my Enermax Platimax 1kW, but that might be a bit out of your budget. I am also very satisfied with my Thermaltake ToughArmor Q-Fan 750W which I moved to my wife's system when I rebuilt ours a year ago.
    For a more budget side of things, I built a friends system with a Rosewill Green power supply, 650W, seemed very solid had good efficiency ratings and has performed admirably for the past two years. I also quite like InWin power supplies and buy cases with power supplies included for my client systems, out of 30 or so over the past three years I have not had a failure. Furthermore I sold the same power supplies at my previous employer and we would have a rate of maybe 1 in 300 after about five years in a dusty, poorly maintained environment. That is a pretty good rate to me.
  12. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    When was the last time this was updated? If it is from 2009 it is a bit out of date. I was under the impression when it was put up that it was going to be updated every few months. If it has been, Moyo2k should really put a date in the post to identify when it was last updated.
    As for the XFX, it seems to be a good power supply, but personally due to trust issues with XFX (I sold their graphics cards for 5 years or so and had issues with the RMA process) I would try to make your budget match one of the Corsair units. I have heard nothing but praise for them here and I have had excellent experiences with their RMA department.
    And yes, the cables come with the modular units.
  13. jinq-sea
    15 Oct 2012
    I'd probably avoid the XFX PSU purely on the basis of their somewhat hit-and-miss customer service. I appreciate that the XFX PSUs are generally made by Seasonic (my preferred choice) but returns and service are worth it, imho.
    I'd probably go for a Seasonic or Corsair supply - I've got a G-series Seasonic 650W in one of mine, and I've been really happy with it. Quiet, powerful and efficient to boot!
  14. halfinched
    19 Jul 2010
    ok XFX out the window and back to square one :)
    Am I being unduly biased by a shiny bit-tech cert gold stamp? The review they just did where the XFX came out on top doesn't feature a single Corsair unit...
  15. Shirty
    18 Apr 1982
    Yes it was rather odd doing a roundup in 2013 without even mentioning Corsair, considering they have now got a huge presence in the market.
    Quick guide:
    CX - 3 year warranty, fixed/hybrid modular cables, Bronze (£75)
    GS - 3 year warranty, fixed cables, bluen LED, Bronze (£85)
    TX - 5 year warranty, fixed/hybrid modular cables, Bronze (£95)
    HX - 7 year warranty, hybrid modular cables, Gold (£115)
    AX - 7 year warranty, full modular cables, Platinum (£140)
    There is one below the CX but that's only really for office builds.
    For 750-800w models of the above you can expect to spend something like the number in brackets.
  16. Margo Baggins
    28 May 2010
    I wouldn't buy anything from XFX - Their psu might be great, but they are, IMO, a real sucky company.
  17. Instagib
    Instagib Minimodder
    12 Mar 2010
    I'm another person that would steer clear of xfx. There was a reason they were dropped by nvidia as one of their board partners and the xfx x58 motherboard, back in the day, was frankly shocking and barely ran at stock. Their support was a waste of time.
    I've been really impressed with my seasonic platinum 660 XP series psu. It's deathly quiet but can be a bit expensive.
  18. halfinched
    19 Jul 2010
    So there's quite a range - don't really want to go above £150 and was hoping for more the £110 price range.
    Can anyone explain the difference between a HX and an AX I've looked at their pages on Scan and am buggered if I can work it out but its been a long day at work and I probably couldn't see the woods for the trees right now.
    Seasonic X-Series 750W
    Corsair AX760i Digital 760W Full Modular Power Supply (i'm a sucker for a product with an "i" on the end of the name that costs £15 more - does it just give you the software?)
    Corsair AX760 760W Full Modular Power Supply (PSU)
    Corsair HX 750W Professional Gold 80PLUS® Power Supply
  19. Shirty
    18 Apr 1982
    AX is much more expensive due to its Platinum rating (well over 90% efficiency at all loads) as opposed to the HX's Gold rating.
    This requires very expensive components and a more complex design. AFAIK without looking the AX is also fully modular as opposed to hybrid, although in practice you need the 24 pin and supplementary power connectors whatever you're doing so full modular has always confused me a bit :p
  20. jinq-sea
    15 Oct 2012
    I've often wondered about the use of fully modular, but then I hit on a possible scenario - having two systems that are only ever used at different times, two sets of cables, and moving the PSU?
    If money isn't tight, I'd do a Seasonic X series (iirc) or an AX Corsair :thumb:
