Scratch Build – Complete ⭐ Scratch BL@ck: Only handmade crafted - 20 liters Slim ITX (10 cm Thickness) UPDATE 03.04.21
Discussion in 'Project Logs' started by Canardwc, 18 Apr 2020.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Hi everybody,
    It's been a long time, but in this wired period I have less work, and more time, but have two diabolic little Boyz now!
    For those who know me, i did 4 scratch builds some years ago (without pretention).
    I'm back with my last build i done with metals scraps but this time, I will do it with new materials (and also recycling steel/aluminium scraps).
    Next post in this thread will show (again) my old scratch (done in 2015) to remember it to you and then tomorrow, the work will begin.
    My philosophy is not to do a clean Cnc with RGB, complicate watercooled loop and milimetred build, but try to give a soul with handmade craft to a common piece "of furniture", a basic computer, try to let it noble, esthetic and have a nice final render... And I allways keep in mind that I should be able to uprgrade hardware easily at any moment.
    And should put every part/component to its own place.
    My motto: do the simplest, the best with the less and efficently. In fact, I assume, I'm just LAZY! :idea:
    So I hope you will be interested in.
    See you & let's go
    BHB Mods and Sam__ like this.
  2. Canardwc
    22 Sep 2011
    What I've done in 2015 (already few years ago I realise) with my both 2 sides panels of Cooler Master C690II
    Dot_Kappa likes this.
  3. Canardwc
    22 Sep 2011
  4. Canardwc
    22 Sep 2011
    But the rear was discusting... But I will keep and claen this part to do a PSU/MOBO/WCloop/HDD/GPU tray that I will call de core tray.
    censored_Prometheus_ likes this.
  5. Canardwc
    22 Sep 2011
    So i bought 2 new steel plates to remake it better and more clean for eyes.
    But i don't know if i will treat the metal like old shotgun (hematite), rust it, or just grease it.. I will see that later.
    I'll keep the hardware plate like a mountig plate (core tray). So I'll have to cut it.
    Need to do a new bracket for GPU and watercooling tank.
    Then,i'll will make some holes to install screws, glue them with epoxy to the future external rear plate.
  6. Canardwc
    22 Sep 2011
    My vise done with 3 joints greenhouse
    Bending and cuting the GPU bracket aluminium tubing:
    Cuting and installing the mounting tank plate:
  7. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    What kinda thickness of aluminum is this? How does the manual bending go?
  8. Canardwc
    22 Sep 2011
    It's a 2mm.
    It's quite easy to bend.
    A trick to bend it easier: cut surfacing with a cutter or a saw above less 0.5mm along your line to bend. Like that, the bend will follow your cutting. But this trick will olso weakened the aluminium structure. So you have to try and choose your startegy ;)
    Pre cutting will give more angle and without will be more smooth.
    An exemple on my old mod GPU SHELL
    TerHorstCustoms likes this.
  9. TerHorstCustoms
    29 Jan 2020
    Thanks! I need to do some basic bend for for a idea I have and didn't realy wanna shell out the cash for a bendpress yet.
  10. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Anyone who can mod in their kitchen has my attention! :dremel::rock:
    Canardwc and Sam__ like this.
  11. Canardwc
    22 Sep 2011
    Your sentence make me laugh.; :lol:
    Yes, I live in small flat in Paris :hip:
  12. pccustom
    pccustom Multimodder
    12 Jul 2017
    I LIKE IT!!
    Canardwc likes this.
  13. Cheapskate
    13 May 2007
    You need a 'work board', something you can abuse and protect your house with. I put together a wood trash can for that purpose.
  14. Canardwc
    22 Sep 2011
    Hi, i know but as you can see, there are placemat et cutting board under ;)
    I know that is not not enough, but like on a boat, i Have to do with stuff on board : Rubinson Crisoë on the desert island ️:brrr:
  15. Canardwc
    22 Sep 2011
    Thank you and hope you'll like the finished scratch!?
  16. Canardwc
    22 Sep 2011
    Little uptdate:
    Very simple GPU Brackets with aluminium pipe bended and 2 x M4 hexagonal screw:
    Final tank mount:
    New steel supplies :clap:
  17. Jean R built
    Jean R built Modder
    17 Feb 2020
    When I was the owner of an Alfa Romeo GTV 916 :rollingeyes:, a beauty that always had a problem I once had to fix the oil sump.
    We fixed it with Pattex Power Epoxy Liquid Steel or Acciaio Liquido in Italy, it's really strong so strong you can even drill it like you would on metal.
    Although I'm not really sure if you can get it in France.
  18. Canardwc
    22 Sep 2011
    Hi, very cool to reply. Thks. I Will looking for on the Web. :thumb:
  19. Canardwc
    22 Sep 2011
    I will use a chimical product to dye steel in Black based on Cu) ; that we called "hématite" in French (used for shotgun barrels among others)
  20. Canardwc
    22 Sep 2011
    Dismount old scratch build (2015) computer:
    Description:
    Itx z97i plus
    i5 4670k OC @ 4600MHz
    2x8Go Gskill sniper 2400 MHz
    Gygabite 1070Ti OC @ 2088 Mhz
    1T Seagate Black
    SSD OCZ Vertex 3 124 Go
    SSD Samsung 250 Go
    M.2 Crucial MX 500 Go
    Seasonic 650 W semi-passive
    Loop:
    XSPC Tank
    Swiftech MCP35X pump,
    EK supremacy CPU block,
    240 rad,
    2 x 120 Gentle Typhoon 1200 Rpm
    Removed the hooks and guide rails on the verso of the side panel of CM 690 with Dremel saw to obtain a clean and neat core tray.
