Scratch Build – Complete ⭐ Scratch BL@ck: Only handmade crafted - 20 liters Slim ITX (10 cm Thickness) UPDATE 03.04.21
Discussion in 'Project Logs' started by Canardwc, 18 Apr 2020.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    With an ancient tool (hammer still better working than CNC for this use :naughty:), to begin bend and finish it with my new vise, milimeter after milimeter (old school way too :p:) the mobo tray to stiffen it:
    Jean R built likes this.
  2. Canardwc
    22 Sep 2011
    And now, a clean and robust (with bended countours) core tray!
  3. Canardwc
    22 Sep 2011
    And now, you can see my work kitchen station :dremel:
  4. Cheapskate
    13 May 2007
    :lol: Dear god! someone send this guy a 2' square plywood plank before he gets evicted!
    b1g-d0g and censored_Prometheus_ like this.
  5. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    :hehe::hehe::hehe:
  6. Canardwc
    22 Sep 2011
    Yes I know, quite hard to find supplies and space in a small flat in these SARS days in Paris in France !!
  7. Canardwc
    22 Sep 2011
    Finished to file the contour shape and the brushed effect on aluminium tank plate
    Remove with a paper clip filed the PCI 6 pins to keep only the 6+2 to get cleaner cable management:
  8. Canardwc
    22 Sep 2011
    I Found a little place in the coridor of my building caves, so there is my new shop! Still better than my 2 square meters kitchen ;)
  9. Cheapskate
    13 May 2007
    A genuine subterranean lair cut from the bedrock? :thumb: PERFECT for mad science! I feel inadequate with my house built on sand 20 feet above sea level.
    Who doesn't want their own bat-cave, even if it's communal.
    Canardwc likes this.
  10. Canardwc
    22 Sep 2011
    Craft 10mm spacers with thread rod:
    Cut:
    Filed:
    Holed:
    Threaded:
    But I broke too many tools today : :duh::waah:
  11. censored_Prometheus_
    26 Mar 2019
    Nothing should be done in haste but gripping a flea. :dremel: Use grease to thread.
  12. Canardwc
    22 Sep 2011
    Hole the rear panel for treaded rods and draws:
    Place the core tray tray to the rear panel with crafted spacers:
    As you can see, I have a gap for the last spacer in the midst of the PSU hole cooling!
    So I will srew a new piece of steel to the core tray (symbolized by the paper tape on the scrap metal):
  13. Canardwc
    22 Sep 2011
    Your right, I used thread with aluminium in the past and was okay, but, steel doesn't works like aluminium.. Now I know! :wallbash:
    Thanks for trick I'll apply in the future, for sure!! :thumb:
    What kind of grease use you?
  14. Canardwc
    22 Sep 2011
    But I was using thread doing a 1/2 round, then get back, then a 1/2 round more, etc, etc.. but needed to know about grease...
  15. censored_Prometheus_
    26 Mar 2019
    Good luck, I watch with curiosity. :dremel: The apartment looks brutally! :thumb:
  16. censored_Prometheus_
    26 Mar 2019
    Any motor oil is suitable. :dremel:
  17. Canardwc
    22 Sep 2011
    Thanks!! :thumb:
  18. Canardwc
    22 Sep 2011
    Hope it's for good reason?! :grin: Thanks for your interest.
    I know it's looks ugly now, but I'm looking for a raw final render.
    Brutally? What does it means?
    I live in a small tipical parisian flat that make me feel in a old 1950 woody english boat
  19. censored_Prometheus_
    26 Mar 2019
    As cave... :cooldude::grin:
  20. Canardwc
    22 Sep 2011
