SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. scooby
    scooby Minimodder
    3 Mar 2004
    Jez is right we do have a pipe/tube tutorial in our forum. FrooP, go to page 73 start at thread #1449. I hope this helps and if you have any questions let us know.
    Hey Jez, may I suggest a sort of data base of tutorials and similar info in the forum and apply them to the first page so people can just go through them to find what they need.
    Example:
    -SU quick reference card, page 72, thread #1428
    -SU Tube/Pipe Tutorial, page 73, thread #1449
    Something like that, so far I have about 10 page locations ready to go. I'll go through the forum and make a list of where all the tutorials and other important info can be found and pass it on to you. To date we have 112 pages with 2240 threads and I know it can be hard to go through the whole forum just to find a tutorial. So if you think this will help let me know and I'll PM you the info.
    Scooby;)
  2. FrooP
    FrooP can I eat this?
    24 Oct 2007
    doesnt look that bad for the first time [​IMG]
  3. scooby
    scooby Minimodder
    3 Mar 2004
    Fantastic FrooP, that looks great for a fist attempt. I love the mod you have on the GPU and PSU looks great.
    TIP: When your done and satisfied with the tube layout you can go back in and erase the line path to reveal a cleaner look on the tubes.
    Keep up the great work and post some pics of your finished case mod.
    Scooby:thumb:
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Warning Linux ahead!
    Just to see if it could be done, I've managed to install SketchUp on my Ubuntu Intrepid driven EeePC 701.
    What it needed was as follows:-
    The latest version of WINE (1.1.4 at time of writing)
    Convert all Ruby scripts in SketchUp's directory structure from DOS to Unix text format.
    Disable Direct Rendering (DRI) in xorg.conf
  5. FrooP
    24 Oct 2007
    can anyone tell my why the glass inserts on my cover wont get displayed in kerky? (i tried it with the modified transparacies, but it just wont show up)
    heres the shot from sketchup
    and here the render from kerky
    im pretty new to kerky so bare with me :thumb:
  6. scooby
    scooby Minimodder
    3 Mar 2004
    Download THIS.
    Discription: Basic Glass
    In SU create/edit a new name for your glass/transparancy so IT can be slected in KT. Let use call it "Window 1", then in KT select Window 1 and then select "Basic Glass" and then select which ever one you want, you may edit (under "Edit Material") the color to suit your needs.
    Your model is looking great FrooP, keep it up my friend.:thumb:
    @IanW, I have read about that some time ago. Thanks for the info, I know that a few here are running Linux and have never thought it would work. Glad it's working for you.:rock:
    Scooby:naughty:
  7. FrooP
    24 Oct 2007
    i heave already downloaded almost all librarys, checked again, it seems like kerky doesnt like my cover, its listed with several other objects and the window cuts arent listed at all:
    maybe i choosed the wrong output settings in SU?
    i am able to assign custom materials and all, but this seems very strange to me :sigh:
  8. FrooP
    24 Oct 2007
    anyone?
    please? :eyebrow:
  9. Nexxo
    23 Oct 2001
    My impression is that it does not see the window cut-outs as a separate feature from the cover.
    Looks to me that you have just drawn areas on the cover and coloured them transparent in SU. It don't work like that in real life (if only). In real life you actually have to cut out the areas in the cover, and then create a transparent acrylic sheet underneath it.
    Similarly, these programs will try to interpret your drawings as realistic 3D emulations of real life objects, so you have to follow the same rules.
  10. FrooP
    24 Oct 2007
    oh yes! thanks very much, ill try that asap
  11. FrooP
    24 Oct 2007
    it worked! i applied custom materials and found out that i can "paint" surfaces in su in diferent colors, so the window cut part was black on the backside :sigh: fixed it and it worked, thats the render, gotta improve some stuff though
  12. Teyber
    Teyber ******
    18 Mar 2007
    hey could you guys help me asap? how do i change the units in sketchup from inches to mm?
    cheers
  13. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    It's options -> model options I think.
    EDIT: Window -> Model Info -> Units
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
  15. turboshifter
    turboshifter What's a Dremel?
    29 Oct 2008
    sweet collection
  16. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Nice!
    You do need the latest version of KT though. (1.09 I believe, it's beta but works fine.) You can download it in the bugfix forum, NOT under the main download. Echo has some serious errors with the calculation of glass in the official version.
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
  18. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    I also saw this article about SU where they talk about the scc :D
    btw. any progress on the beta ?
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    no, no progress.
    been too busy at work to want to spend time working at home!
  20. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
