SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Well the site's purdy, but there is currently *zero* content!
    [qft]Latest uploaded components
    None yet. Be the first one to upload![/qft]
    Also note that it's at a .net.tc address which is free (it's actually at sketchupcomponents.awardspace.com).
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Except that
    Wouldn't be your own empty site?
    We frown on people joining just to pimp :grr:
  3. FromU2ME
    FromU2ME What's a Dremel?
    25 Jul 2006
    The site's down anyway...
  4. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    Commell LV-670 Mini-ITX motherboard (socket 478)
    Photo of the board:
    High-detail model of the board (10963 edges, 814KB uncompressed) :
    Low-detail model of the board (3524 edges, 263KB uncompressed) :
    Download:
    High-detail model (253KB)
    Low-detail model (90KB)
    Zip-compressed. Hope you like it :)
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
  6. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    ooh nice job Rexxie, glad you have done a low res version too..it is a PITA when you have to delete all the pins in the PATA connector cos your machine is slow (solved now: new pc)
    makes my Lian-Li style Temp Bezel look amature: :p
    although the temperature modules are very detailed on the back :)
    /end self pimpage
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    Another excellent piece from GuardianStorm:
    An IDE converter:
  9. GuardianStorm
    26 Apr 2005
    thanks :) i am to please / aliviate my bordom...
  10. Ravimade
    Ravimade What's a Dremel?
    30 Aug 2005
    hi
    sorry for my bad english ;)
    i have a big problem since few days
    I'm trying to use the follow me tool to create a round component.
    But when i'm using the tool with my sketch, i don't have the curve part of the sketch in the representation
    and here is my sketchup file
    http://rapidshare.de/files/29589501/test.skp.html
    thank for your help ;)
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    I think it might be because your model is too small.
    Scale it to 100 times bigger, then use the follow-me tool, then shrink to the original size.
    Let us know if that works.
  12. Ravimade
    30 Aug 2005
    yes!!!!
    thw jazzle, it works!!!
    I do like you said and i have now my draw how i want!!!
    I'm making a key switch and i will show you haw it looks like at the end
    Thanks a lot!!!
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    de rien, happy to help. :)
  14. stevie1556
    stevie1556 What's a Dremel?
    29 Jul 2006
    By any small chance does anyone have an Antec P180 case for sketchup? I was in the process of making my own case, made one side frame from aluminimum, but its not square. And the glue used is like cement!
    So for my project I am now thinking of using an Antec P180 case
  15. Ravimade
    30 Aug 2005
    here what i m doing
    not yet finished ;)
  16. Ravimade
    30 Aug 2005
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    Would you like that to be put on the SCC?
  18. Ravimade
    30 Aug 2005
    no pb, you can put it ;)
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
  20. Guest-18698
    Guest-18698 Guest
    hmm i had a go with the sketch up and its very good, but i cant afford £315 on it just now. is there anyway i can get it cheaper?
