Scratch Build – In Progress Temp name: Black Tower project [Update 16 Sep 2008]
Discussion in 'Project Logs' started by Anobis, 20 Apr 2008.
  1. Anobis
    Anobis What's a Dremel?
    28 Mar 2006
    Ok a little update again :D
    Made the space four the neon.
    Had a look with the neon in it.
    Nice and bright :D
    And made the aluminum front.
    Still needs some filing and sanding. But its looking pritty good :D
  2. Anobis
    28 Mar 2006
    Last update four today i think.
    I cut a pies of Laxan. And sand it it down first with 150 then 600 and wet 600 after words. It gave a nice soft smooth surface. Wear you slightly can see true but not in detail.
    Hire you can see the pies with the neon and Lexan in front :D
    Looks nice. And wen it will been painted with high gloss black. with mirror polish aluminum. It wood look even better :D
  3. Anobis
    28 Mar 2006
    And bigger update to day.
    Glued the front plate on.
    Forgotten to make pic's of the other upper parts i glued on :duh:
    And glued the lower parts on.
    And put on some MDF filler.
    I know it docent look prity. But this stuff ain't real easy putting it on. It is a real hard filler.
    But no biggy. Just more sanding fun :hehe:
    Hire i have it sand half way.
    Found a few bad spots. So i yous some more filler.
    Like you can see in pic below.
    Four gotten...... Again! to make pic's :duh: Of the more sanding and how i Glue the front.
    In the lower pic you can see the other front plate. With filler sand down and filed a gain.
    And on the other pic you can see the upper side bar's. Upper left and right.
    And a nice pic of the front view.
    And she came a long :D
    So i went of to pet her ant play a bit. A ball of wire and a stick. Such a simple thing but she likes it :D
  4. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    She looks evil, I'd suggest you don't let her in so much :eyebrow:
  5. The boy 4rm oz
    10 Apr 2008
    I love the layers.
  6. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    I'm in your modz, scratching yo Bondo!
  7. Anobis
    28 Mar 2006
    Got this at home finally :D
    3 blue 10cm
    2 red 10 cm
    and 1 Antec True power Quattro 1000Watt.
    some power wires and splitters (not in pic)
    And four the paintball lovers under us.
    I all sow gotten today my Opsgear shroud And my 3th Tippmann A-5 :D
    It looks so nice but its real big to :p
    So it dozenth really fit real good in the pic. will make better ones wen its day light out side :D
  8. yeknom
    23 Apr 2008
    That Tippman is gorgeous. You got the barrel?
  9. Anobis
    28 Mar 2006
    An Opsgear 18 inch Interceptor. with an Opsgear M107 muzzle brake :D
  10. The boy 4rm oz
    10 Apr 2008
    Nice power supply and an awesome paint ball gun. Mmm .50cal goodness lol.
  11. Anobis
    28 Mar 2006
    Well made the holes four the outtake 140mm fans.
    Hire i taped it off and drawn the lines.
    Hire i cut the first out of 2.
    And hire both are cut out.
    And in this pic i made the top plate. This is going to be placed above the fans.
    And made the first side panel :D
    And drawn the side template.
    Thats it four now. Hope you all liking it four so far? :D
  12. Anobis
    28 Mar 2006
    A real small update to day. Didn't had much time so i did this four now.
    Drilled holes.
    And screwed these in.
    Real handy little things :D
    And made a few screws.
    By you zing these things.
    And with some tread. You get end result like pic below.
    And last pic test mounting it. To see every thing is a o K :dremel:
    And it looks wonderful :thumb:
  13. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Nice work man, still coming along nicely. I used to have a Spec Ops Paintball A5-A2 in that same digi-camo with a matching flatline barrel, but I got married and sold it lol. Man I still miss that thing.
  14. The boy 4rm oz
    10 Apr 2008
    The front plate looks cool, excellent work.
  15. ModimusPrime
    ModimusPrime The Dremelator
    3 Jan 2008
    Coming along great. I love the front of the case, functional and still great looking!
  16. Anobis
    28 Mar 2006
    Nice camo :D
    thats the downside of getting married :p
    The misses was end fun of it i ges ^^
  17. Anobis
    28 Mar 2006
    Thanx The boy 4rm oz and ModimusPrime. Your compliments are an very good moral boost :D
  18. Anobis
    28 Mar 2006
    Not really an update.
    But i found my old teabag again. Ware the idea begone four this project :D
    So you peeps can have an idea how its going to be come. If i don't change my mind half way lol :p
  19. Anobis
    28 Mar 2006
    Ok an small update four now :D
    Made 2 side plates.
    Hire shown one in pic.
    Glued the first air duct.
    Hire holding it to give an better view.
    Still needs needs work but the angels come later :dremel:
    And made the hole four the 10cm neon :D
    Its going to be the same idea like the front. But now also light's comes from the air duct it self.
    Thats it four now i hope you all like it :D
  20. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    I realy like the front panel, and the air ducts looks nice too.
    Are you going to polish the metal on the front?
