SketchUp The MNPCTech Case Design Competition, part II: Scratch Build
Discussion in 'Modding' started by Xtrafresh, 14 Jan 2009.
This thread is made of pure:
  1. Win
    13.7%
  2. Win
    14.7%
  3. Win
    17.6%
  4. Epic design Win!
    51.0%
  5. Cheesecake
    55.9%
Multiple votes are allowed.
  1. Asulc
    Asulc Minimodder
    18 Jul 2007
    Haha good idea, but crap...that means more holes...haha
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    Slightly offtopic, but there's the Psile-case from Nexus for miniITX Boards -> http://www.psile.com/index.php
    It's alittle bit taller then a Mac Mini, but that results from the non-existant PCI-riser-card.
    However, also looking very good imho.
  3. jhanlon303
    7 Sep 2006
    A bukkit load of mini-ITX case at http://www.mini-itx.com/ look in the online store.
    I guess I'm more a builder than a buyer.... but I peek at cases to make the brain gears engage.
    john
  4. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I'm yet to get started, I have come up with a few ideas, only witing so far though. Uni work load at the moment is epic!
    I was tempted to make a cluster as Cheap was on about, and as my main use for computer (other than browing bit-tech) is for CAD, the cluster could be used quite nicely as a render behmoth.
    So my ideas are, 1xATX/mATX for main rig with a further 4xMiniITX pc's for the rendering. If I watercool the lot, I'm hoping to fit 5 x Quad Core CPU's. Was going to add either an SSD Raid array or a 2.5" HD array. And as with all my designs, it needs to be as compact as possible. We'll see what I can come up with when I get some time.
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Sounds cool. The Cosmos S should be able to fit all that. It would be fun to see your build and a normal one next to eachother :)
  6. dullonien
    22 Dec 2005
    I want it smaller than a Cosmos S lol. I'm tempted to make it hot swappable, so entire MiniITX pc's can be unplugged if needed somehwere else and plugged straight back in when rendering. This would make the watercooling very difficult indeed, so I'll have to rethink that one!
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Cheap, that design is EPIC! it belongs in a sci-fi movie, man.
    This stealth pwr/reset idea is way cool, nice one Dan!
  8. Cheapskate
    13 May 2007
    Thanks, Bill.:D
    Yeah, If you could put it on a curved drawer, it would be even cooler.:D (But it would look even more like :p)
    ...So I was waiting for tree trimmers who never showed yesterday...
    I'mma gonna toss out de random ideas for the fun. This one centers around a massive-passive cooling heatsink. All the white and gray spots are where I had to redraw surfaces after intersecting.
  9. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looks like thats going to be another PC killer Cheapskate :jawdrop:
    Edit:
    ->Cheapskate] Took your advice on the res and shrouded those pumps.. heres what I came up with...
    you were right! looks much better now there all hidden away even on SU so dread to think what it would have been like on the real project.. thanks dude :rock:
  10. Cheapskate
    13 May 2007
    :thumb: Much better.
    I got another one, working on the idea of 2d frame bits...
    I should have enough room for 60 systems in there.
    SU isn't corrupting anything at this scale.
  11. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    How, in the name of fluffy jesus, do you get that much detail into your Sketchup? I've been using SU daily for the last month, and I'm still struggling to produce simple models! And I thought I was doing WELL!
    Then I come here and see these.....................works of art, and I feel humbled and shamed by my efforts.
    And I can't deside who to vote for either :(
  12. Editor22
    3 Jan 2009
    Is that guys hair falling out because the thought "OH MY F***ING GOD ITS GONNA TOPPLE OVER!" running through his head?
  13. jhanlon303
    7 Sep 2006
    Looks like Cheaps gave up on a computer case and decided to use his wicked SU skills to design rental property! :jawdrop: He's making an apartment house.:rock:
    john
  14. Cheapskate
    13 May 2007
    If it will make you feel any better, I've been using some form of 3d graphic software since about '96, and I had some training on Autocad ages ago... I've been interested since I saw Tron back when it first came out.
    -But, there's a few free plugins available you should look into. I think they came off 'Smustard'.
    The last one uses one called chamfer along path.
    Also You can get a lot more control if you blow up the objects like the last one, and under 'model info,' crank the precision down as far as you can get it.
    That guy is thinking, "I have to carry this to a LAN?"
    @John - A human-sized hamster playground.:D Where the photo finish dash to the toilet has to be done through the Jeffries tubes.:hehe:
  15. Editor22
    3 Jan 2009
    o.0 never realised there was free plugins! I really miss chamfer, fillet and inverse select from 3ds so that would be a HUGE help.. off to go trawl google for some of this SU porn :rock:
  16. Cheapskate
    13 May 2007
    It's a lot of useless stuff, but I did find a DXF exporter.
    The one that finds stray points is nice too.
    The chamfer one will do fillets too, but you need to play with the #s a bit to get it right. I always forget which one needs to be positive and negative. I found out later when I zoomed out that it was because I made that last model while I was upside down.
  17. Asulc
    Asulc Minimodder
    18 Jul 2007
    do you have any links to the useful plugins?
  18. Cheapskate
    13 May 2007
    I think I said Smustard.:p
    I have no clue on the dxf exporter. I think I googled 'free dxf exporter sketchup'. I ended up on a guitar making forum.
    I think I'm done with this one.
    I might try to clean it up if I get trapped at home again.
    -but don't hold your breath. At 40.5 megs, it's starting to lag a little.:hehe:
  19. Asulc
    Asulc Minimodder
    18 Jul 2007
    Guess I missed that...haha
    Starting? what kind of computer are you running?
  20. Editor22
    3 Jan 2009
    You going to be playing about with another Cheapskate? think it needs a name...
    Got my hands on a nice speedy "follow me" plug in after a bit of digging just select the lines hit tube and its done :) cant seem to get the chamfer to work though :(
