Case Mod - In Progress Tribal's case - Christmas update hehehehe 13/12/2007
Discussion in 'Project Logs' started by Rodrigo Vicentini, 30 Apr 2006.
Thread Status:
Not open for further replies.
  1. Hz4
    Hz4 What's a Dremel?
    17 Jun 2006
    I know it! It was same style with Mercedes:)
    Btw you are made awesome work!
    I like that rose :rock:
  2. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    Just fix that mercedes front anyway you can..
  3. Gaoske
    Gaoske What's a Dremel?
    10 May 2005
    Please don't...
    I still prefere a star in my windscreen over one in or on the grill of my car :blush:
    You're on your way of succes with this one, awesome dremelskillz... :dremel:
  4. Nutty
    Nutty What's a Dremel?
    2 Jan 2005
    really nice job!
  5. nicke
    nicke What's a Dremel?
    17 Jun 2004
    that front really remind me of a mercedes, that's frightning. what's the name of the company that makes them or is it somekind of a low budget thing "whit out a name". but really a good looking job you sure can use the dremel
  6. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    I will change that front :D
    hehehehe I already modified that front, it doesn't seem one more mercedes, tks man
    :thumb: tks man
    tks man :thumb: :D
  7. Rodrigo Vicentini
    30 Apr 2006
    Finally I come to bring innovations for you, I was without time of continuing with project, but now I am with more time, then we are going the new modifications.
    Some pictures:
    here a test of the PSU in new position
    the demarcation for the cuts
    here the box that will hide the PSU, I drew in the corel and I printed for not having mistake in the hour of the cut.
    suporte para a PSU.
    everything in the place :thumb:
  8. Rodrigo Vicentini
    30 Apr 2006
    test for PSU to be seen enters in the place hehehe
    front vision of the case, they are still without the finish, I will put plastic mass.
    vision of the interior of the case, still lack some fittingses.
  9. Jipa
    5 Feb 2004
    great work with the dremel! :jawdrop:
  10. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Kickass dremel skills.. Nice work on bending that metal cover for the PSU to :thumb:
  11. ry@n
    ry@n Minimodder
    31 Aug 2005
    LOVE the dreml work man! and I really like the look of that PSU cover thing, what coulour are you going to spray this masterpiece?
  12. ssR
    ssR Carbon God
    11 Aug 2006
    man your dremeling skills are amazing, i bet it took you quite some time to get all the cuts done. great detailing, just make sure you sand the cuts a bit to really make it perfect. keep up the great work, this will indeed be a unique case :)
  13. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    impressive!
  14. ViPPeR_666
    ViPPeR_666 What's a Dremel?
    31 Jul 2006
    Great work dude, I just can't wait to see the front you've you'll mod!
    :D
    PS: Se precisar de ajuda com inglês fala comigo que tamo ae. Mod ta fodao hein :X
  15. Rodrigo Vicentini
    30 Apr 2006
    tks man :D :clap:
    Thank you friend :thumb: , that covering for PSU will be cool :clap: , and very different also :D
    Thank you friend, that covering will be in the same color of the case, opaque black, with details in blue.
    thank you friend, I will still have to give a finish in the cuts, but I will make that before painting the case :D
    :thumb: :thumb: :thumb:
    tks man :D
    The front of the it case is still in the beginning rss
    PS.: heheh caso eu precise eu pesso sim cara :D
  16. Rodrigo Vicentini
    30 Apr 2006
    here and the beginning of the work in front of case, the front of the it marries will have 3 holes for coolers, two to stop the entrance of air in it case it one for entrance of air in the PSU
    [​IMG][​IMG][​IMG]
    Here also already and the beginning of the arrangement of PSU Box :D always using my connectors mikes, I used a piece of blue acrylic UV to do the fitting.
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  17. Rodrigo Vicentini
    30 Apr 2006
    the project and basically to transform that wax block:
    in something similar to that skull here:
    (I don't say equal because the author of this skull was very skilled in you make her, impossible of doing equal, anybody know how to inform who and the author of this skull?)
    here some pictures of as I am doing, I must have worked in that skull something around two days (adding the working hours)
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
    [​IMG][​IMG][​IMG]
    the skull still no this finished then can give some clues. :D
  18. Rodrigo Vicentini
    30 Apr 2006
    Here and one copies faithful front of mine case, done of plaster, I can already advance that in her I will make a door for the stalls of mine case...
    [​IMG][​IMG]
    :thumb:
    good that skull actually later will turn two, they will be the front grills of my cabinet, where he/she will have the coolers to pull the air outside inside of the it marries, I will also make another grill, very complicated now, for the hole of the cooler of the source, as I spoke to me will build a " door " for the stalls of Cd-rom, and also to do some details in front of PC, on the feet still doesn't have anything to speak on (I am not still worrying about them no) the focus now and the front of the it case.
    :D
  19. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Ok, I'd say that those cuts are nice, in fact nicest I've seen on the Internet. I also like the tattoo-like theme where you are steering this one, keep at it.
    Janne
  20. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    That skull came out very well too. What are those teeth made of?
Thread Status:
