Windows Windows 7 Public Beta News
Discussion in 'Software' started by icutebluezone, 8 Jan 2009.
  1. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Argh... freaking frak! Download from legit site failed at 71%... connection with server reset. :wallbash:
    Gonna have to try again from the technet site.
  2. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    awesome, got my hands on a key :D for once I get lucky :p
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    See post #36. The only upgrade path is from Vista SP1
    No problems downloading or getting keys, but can someone confirm a clean install is possible before I format a hard drive? :confused:
  4. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Yeah, I had a clean install! :clap: I am writing this on it now!! :lol:
    Only one of my laptop's 9 drivers had compatibility issues....
    Go for it! (Keep another working PC at hand just incase it goes FUBAR!)
    Dave
  5. ModMinded
    26 Aug 2008
    Sorry for the incorrect info. It says clearly that the only upgrade available is from Vista, not XP (which makes sense) :duh:
    As dave said, clean install is not a problem. I was able to install it on a 20gb ide drive. Needs about 14gb.
    For those interested, here's MS FAQ on the beta:
    http://www.microsoft.com/windows/windows-7/beta-faq.aspx
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The links for the keys work perfectly fine. Thanks, kenco.
    The links for the ISOs work fine as well. Thanks, Fluffy. However speed is not even funny @ <100kB/s.
    Going to get a torrent now.
    Oh, by the way. The keys from MS are not unique. Just saw somebody on TPB post some of the keys I received. So if anyone needs key.... PM or just use the links. ;)
  7. Volund
    16 Sep 2008
    I just finished a clean install, it went fine for me.
  8. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Do you need a duel layer DVD to burn this?
  9. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  10. kenco_uk
    28 Nov 2003
    Anyone tried an upgrade from Vista + SP1?
  11. alastor
    alastor Minimodder
    6 Sep 2004
    Just started downloading with the plan to do it overnight...currently getting ~15-20KBps.
    Won't even be half done by the time I wake up :(
  12. culley
    culley What's a Dremel?
    12 Jul 2006
    I've got a key, and downloaded the 64bit version and I'm installing it now, I'm going to be dual-booting with vista.
  13. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Right, how do I get a key?
  14. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    it's about 3GB, so no.
    http://www.microsoft.com/windows/windows-7/beta-download.aspx
    once they confirm your email address they give you a key and a download link.
    i downloaded a copy off torrents on wednesday at ~550KBps, and successfully activated it with a key from the above link.
  15. ModMinded
    26 Aug 2008
    The torrent 64bit and MS 64bit version are the same size (almost 100% sure the same file, with no tomfoolery), and torrent is much quicker.
  16. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I managed to get a spare key if anyone is struggling with the site. It seems to be chugging along nicely now though.
    I did something a bit stupid with my set-up which someone might be able to help me with. I dug out an old 32gb drive and did a format and installed everything to that. Stupidly though I just had it hooked up and hanging out of my computer so of course ended up knocking it on the floor and now it makes a lovely rattling noise.
    Whenever I start my computer though I get asked which OS to boot to, and I've no idea how to turn this off without uninstalling everything properly.
  17. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Hey...hey, guys.
    I think my heart just stopped.
    update - completed in 4:03. My ethernet cable now has an exhausted look of elation about it.
  18. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    I too managed to snag a spare key, IE gave me a different one to FF.
  19. overdosedelusion
    29 Oct 2006
    what the hell connection is that O,o Uni?
  20. notatoad
    25 Jun 2004
    boiled_elephant, i am going to kill you and steal your internet connection, ok?
