Other Windows Experience Index
Discussion in 'Hardware' started by jamesn, 13 Mar 2012.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    At what kinds of speeds? I've tried 5Ghz before now; Still 7.8.
    After some googlage; 2500K at 5.4Ghz apparently hit it, SR2 with a couple of Quads at 5Ghz also apparently got it, I'd need to push about 7.5 to be able to achieve it on this, then.
    I'd be very curious to see how it calculates this score, I'm wondering if it doesn't look at CPU name rather than actual performance. Apparently there's i7 970's that only score 7.7( 4.4Ghz, the one I saw), There's no way in all heaven my little FX8120 can touch one of those in reality.
  2. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    My 2700K hit 7.9 at about 5.2/5.3 GHz, so it doesn't rely on 8 physical threads. It probably takes a lower frequency with 8 physical cores though, I haven't got an octo-core to test that.
  3. .//TuNdRa
    12 Feb 2011
    I don't have a good octo-core. I've tried. Still 7.8.
  4. Deders
    Deders Modder
    14 Nov 2010
    Was a long time ago but I'm pretty sure I read it in an interview with one of the developers.
    Maybe that was enough to make the hyperthreaded 'cores' fast enough to raise the score.
    I'd retest to be sure, Although it might be to do with the CPU. I've found that even though Nvidia recommend a 570 for Arkham City with everything at it's highest, I can play it full detail with 30-60 fps if I overclock my CPU by a GHz.
  5. Pookeyhead
    30 Jan 2004
    My SB-E stayed at 7.8 at 5.3GHz.
  6. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    OK now I'm upgraded to a Phenom II X6 1100T and 8gb corsair ram.
    CPU: 7.5
    RAM: 7.5
    Graphics: 7.3
    Gaming Graphics: 7.3
    Primary HDD: 7.3 **
    ** this is a bit weird, I'm still using the same old ocz vertex!
    Sent from my CM9 Touchpad using Tapatalk
  7. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Faster SATA controller maybe? Due to the newer technology you've upgraded to. That would be my guess.
  8. Dave Lister
    1 Sep 2009
    Yeah that makes sense, it's sort of like a hidden free gift !
  9. Pookeyhead
    30 Jan 2004
    SSD has helped here. WEI is still a load of BS though.
  10. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    7.4
    7.4
    7.3
    7.3
    7.8
    For sig system. SSD is on a SATA2 controller.
  11. terrorbyt
    terrorbyt MultiModder
    19 Apr 2012
    None of these scores are over 9000, I find them all perfectly acceptable
    docodine likes this.
  12. legoman
    legoman breaker of things
    28 Feb 2010
    CPU 7.6
    RAM 7.6
    GPU 7.4
    GPU Gaming 7.4
    HDD 7.5
    miffed at the GPU scores but hey ho
  13. zapango
    zapango What's a Dremel?
    15 Apr 2012
    7.7 - I7 965x @ 4.2Ghz
    7.9 - 12GB 1600Mhz
    7.9 - 2 x 570 DCii
    7.9 -
    7.8 - Crucial M4 128
    Was a little surprised at how high the cpu hit tbh.
  14. Deders
    Deders Modder
    14 Nov 2010
    Pretty sure I got about 7.5 for graphics with my old 9800GTX+'s in SLI
    Edit: just re ran my assessment as I thought 7.1 was a bit low for a 560TI. Went up to 7.9.
  15. terrorbyt
    19 Apr 2012
    CPU 7.1
    RAM 7.5
    GPU 7.8
    GPU Gaming 7.8
    HDD 5.9
    Good thing WEI isn't a proper benchmarking tool, my cpu would be bottlenecking me
  16. kenco_uk
    28 Nov 2003
    Currently, 7.5 for CPU, 7.9 for all the others. I've got some reading to do regarding o/cing.
  17. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    CPU: 7.7 @4.5ghz
    RAM: 7.9
    GPU: 7.9
    GPU Gaming 7.9
    HDD: 7.7
  18. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    7.8
    7.9
    7.5
    7.5
    7.9
  19. legoman
    28 Feb 2010
    Yeah i thought it was a bit odd, just re ran it
    Old scores
    CPU 7.6
    RAM 7.6
    GPU 7.4
    GPU Gaming 7.4
    HDD 7.5
    New
    CPU 7.6
    RAM 7.6
    GPU 7.9
    GPU Gaming 7.9
    HDD 7.5
    Thats more like it!
  20. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    7.9 across the board on the 3930k, both the 3960x's sitting around I'll try with them later
