Other Windows Experience Index
Discussion in 'Hardware' started by jamesn, 13 Mar 2012.
  1. Plodder
    Plodder What's a Dremel?
    14 Apr 2012
    Processor: 6.9 e7600 at 3.86 ghz
    Memory: 7.0 Kingston hyperx ddr2 at 1073 mhz
    Graphics: 7.8(both) HD6870
    Hard disc: 7.8 OCZ-vertex3 120gb
    Upgrading soon :)
  2. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Mine is annoying as I am sure MS have messed around with the scores.
    I get
    CPU: 7.8
    Ram: 7.9
    Graphic's (Both): 7.8
    HDD: 7.8
    I was getting 7.9 for the graphic's on a single GTX 480 but with a single GTX 680 I would have thought it would have been the same not lower.
  3. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    Mine seem quite high for the spec that I've got:
    Processor: 7.1 (Intel Core 2 Quad Q6600 at stock)
    Memory: 7.1 (6GB Crucial DDR2)
    Graphics: 7.1 (Sapphire ATI HD5670 1GB OC)
    Gaming Graphics: 7.1
    Primary Hard Disk: 7.2 (64GB Crucial M4 SSD)
  4. echo three
    echo three What's a Dremel?
    26 Jan 2012
    From memory my q6600 at stock got a 5.2 with overclocked to 3.6 getting a 5.9.
  5. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    WEI really is utterly useless. A while ago when p0pe posted his WEI score from his PC BETO mod I found that my rig at the time was showing higher gaming scores. He was running a 4870X2 and I was running a 4770. That made me never, ever take any notice of what WEI says ever again.
    However..
    7.4
    7.5
    7.9
    7.9
    5.9
  6. Deders
    Deders Modder
    14 Nov 2010
    I bet your systems can play solitaire and minesweeper just as fast.
  7. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Thanks to nvidia convincing me my gtx 280 was faulty I now have a new XFX 5870 courtesy of BT member Teknokid:
    CPU: 7.5
    RAM: 7.5
    Graphics: 7.8
    Gaming Graphics: 7.8
    Primary HDD. 7.3
    Sent from my CM9 Touchpad using Tapatalk
  8. terrorbyt
    terrorbyt MultiModder
    19 Apr 2012
    since upgrading from a 6870 to 6950 it's raised the above by 0.1. I imagine if I OCed it I could get it to 8 but not sure if it's worth it
  9. Deders
    Deders Modder
    14 Nov 2010
    There is no 8
  10. Malvolio
    Malvolio .
    14 Dec 2003
    Hold onto your butts, as the results from benching my netbook at work will thoroughly rock them off:
    2.3
    4.4
    2.0
    3.0
    5.7
    :D
    And if you're wondering, that system runs W7 Ultimate without issue. And by without issue I mean that most days it doesn't melt into a pool of molten plastic and metal under my feet despite running both Winamp and Chrome (at the same time, no less!).
  11. terrorbyt
    19 Apr 2012
  12. Reg216uk
    Reg216uk Minimodder
    2 Nov 2011
    7.7
    7.9
    7.9
    7.9
    7.8
    Think ive done pretty good there :) woo
  13. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    This is the kind of crazy ******** that WEI loves. I get 7.8 on that, and every other test shows that I'm theoretically slower than a 2500K.
  14. Tangster
    23 May 2009
    I'm getting a more respectable WEI score now I'm on an SSD.
    7.8 (only when at 4.8GHz+)
    7.9
    7.7 (overclocked GPU, stock gets 7.5)
    7.9
  15. Reg216uk
    Reg216uk Minimodder
    2 Nov 2011
    Just another friendly thread :D
