Scratch Build – Complete ⭐ WOPR Casecon by RandomDesign
Discussion in 'Project Logs' started by random2k4, 12 Dec 2017.
  1. random2k4
    random2k4 Multimodder
    11 Aug 2015
    Finally after moving to the US from Germany, I got all my workshop items and will be able to mod again.
    So here is my next project.
    It be the computer called WOPR (War Operation Plan Response) from the 80s movie WarGames.
    I will change the scale factor to fit it on a desk. Should be something about 75 cm in lenght.
    The LED effekts will also be included, but not as many as in the original :D
    To start the project, I made a 3D model in the scale factor I want to build later on.
    The 3D model will also function as some kind of template later on.
    Vault-Tec likes this.
  2. Cheapskate
    13 May 2007
    Not to scale? :lol:
    I think Hcp's build needs a mention here. Mostly as a cautionary tale of LED soldering burnout.
  3. random2k4
    11 Aug 2015
    I could make it full scale since I am here in the US I got more space to work with :D
    But its for a client who wants to fit it on his desk ;)
    Next, I converted the 3D model into a paper template for printing.
    It is now 55 pages and 232 parts.
    After printing, I redrew the folding lines, to make them fold easy. It is also better for gluing lateron.
    Then everything was cutted out.
    At the moment I am gluing all parts together piece by piece.
  4. Nexxo
    23 Oct 2001
    NICE PROJECT.
    SHALL WE PLAY A GAME?
  5. random2k4
    11 Aug 2015
    And the gluing went on and on and on .....
    I reinforced some parts with card board to make it stronger for the following step.
    So thats the case so far, still need to work on some spots, but I am happy with the result so far.
    cobalt6700 likes this.
  6. kim
    kim hardware addict
    10 Jan 2016
    interesting approach with the paper mock-up, it's already a hell of a job, but all parts are much more easy to figure out I guess
  7. random2k4
    11 Aug 2015
    Between the years I got some time to continiue working on the mod.
    After the paper model was done, I applied a coat of fiber glass resin to strengthen the paper.
    After everything dried, I got a nice sturdy model.
    Afterwards, I started applying glass fiber from the inside. Have to do it area after area,
    cause it needs to dry in between so I wont get any distortion in my paper model.
    Will take some time due to the outside tempratures here in Ann Arbor at the moment.
    Yes its freezing cold in my garage :D
    AML_customs_pc likes this.
  8. AML_customs_pc
    AML_customs_pc Minimodder
    24 Feb 2017
    Really like that you have done a model and using that to build the case out of fibreglass. Looking forward to the next update.
  9. kim
    kim hardware addict
    10 Jan 2016
    I realise now how I've been silly to think that it was only a mock up :wallbash: ...I am litterally amazed by your technique of strengthen it with fiber glass :jawdrop:, genious idea :idea: , it opens a new possibility to realise complicated shapes without a 3D printer...
  10. random2k4
    11 Aug 2015
    :D This technique has its advantages, that you can basically realize any shape or form. Did it for some of my other projects as well.
    Still sometimes when the paper is not 100% straight you need a lot of efford to fix it after the glass fiber cured. But after you apply body filler any imperfections will be
    nearly invisible. (At least I hope so :D)
  11. random2k4
    11 Aug 2015
    So I continiued applying the fiber glass piece by piece.
    Finally, after everything was done, I could trim the excess.
    And this is, how it looks from the inside now. The surface will be also painted at the end to blend with the case/hardware.
  12. Cheapskate
    13 May 2007
    Ew. Looks like cold chicken broth jello.
  13. random2k4
    11 Aug 2015
    I think more like cut jely fish. I made the pictures after the las coat of resin, thats why its still glossy. But as I said will be dulled down and painted.
  14. random2k4
    11 Aug 2015
    I started to sand down the fiber glass to make the following layer of body filler as thin as possible.
    After sanding the paper down, I also could work on some rough spots or on spots were the fiber glass had som imperfections.
    Then body filler was applied.
    After hardening, I sanded everything smooth.
    I decided to work area by area, so I coul concentrate on getting every surface as perfect as possible.
    So here are the first two surfaces already done. The openings will be taken care of later.
    And then, returned to sand the paper down.
    douglas alves likes this.
  15. kim
    kim hardware addict
    10 Jan 2016
    looks like the sanding job requires a gas mask :grin:
  16. David
    7 Apr 2009
    Oh, I've got to see how this turns out!
    Subbed.
  17. Vault-Tec
    30 Aug 2015
    Man you have your work cut out. I wish you all the best, that thing is going to eat the hours :D
  18. random2k4
    11 Aug 2015
    Time again for a small update.
    This time I worked on the stand of the case. I applied some body filler on the bottom side and sanded it down.
    I sanded until everything was smooth and on the same level.
    Then the body filler work continiued.
    I removed the paper from all openings to get a better feeling for the final outcome.
    The first parts are nearly done yet, still some fine tuning on the edges needed.
  19. Cheapskate
    13 May 2007
    You've made a lot more progress than I expected since it's winter.
  20. random2k4
    11 Aug 2015
    Yeah, its freaking cold in my garage right now. Wearing two sweaters at once most of the time. But the temperature does not do you a favour in the curing times od glas fiber and body filler.
