Scratch Build – Complete ⭐ WOPR Casecon by RandomDesign
Discussion in 'Project Logs' started by random2k4, 12 Dec 2017.
  1. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Very nice PLA results! I always have a really hard time sanding that stuff and getting it to look clean.
    random2k4 likes this.
  2. random2k4
    random2k4 Multimodder
    11 Aug 2015
    Next, I made the doors. I started with some layers of gray color and clear coat.
    I designed and printed an opening mechanism. After processing it was painted silver.
    And then the doors were done.
    Also made a test if everything fits.
    Also made a test together with the LED panels. Now only some small details are missing.
  3. Cheapskate
    13 May 2007
    Perfect. :D At that size, it looks like it should be cast in Bakelite. It has that old-timey radio feel to it.
  4. Mopsi
    Mopsi What's a Dremel?
    12 May 2017
    The LEDs look like a lot of work. How do you address them?
  5. random2k4
    11 Aug 2015
    All APA106 LEDs, controlled by an arduino MEGA.
  6. Mopsi
    12 May 2017
    Cool, thanks.
  7. random2k4
    11 Aug 2015
    Finally another update on the WOPR
    For the LED panels I still needed to build a small shroud.
    I simply cut some acrylic into shape and painted in in the same
    color as the panels itself.
    They were put into place just by some double sided tape.
    If you know the movie, you know that the WOPR has some lables all around. At first, I wanted to
    make a stencil and spray it on, but watching the movie again, made me realize, they just
    used some vinyl to make the lables. So, I went over to my vinyl cutter and made my own.
    And attached them already.
    To start the computer and LEDs later, I needed some buttons. They should not be visible from the outside,
    So I put them behind the cover at the front.
    Programming the LEDs was now the last step. Its really a bunch of code.
    Here you can see a picture from the work in progress, but it already shows the effect pretty good.
    Now, I will install the LED panels and work on the cable management. And then its time for some final pictures and a video.
  8. random2k4
    11 Aug 2015
    And here are some final pics.
    The making of will follow shortly.
  9. Cheapskate
    13 May 2007
    Done! And it looks beautiful. :D
  10. random2k4
    11 Aug 2015
    Thanks man! Now I am going to finish the X-Wing. Hopefully this year haha
    Cheapskate likes this.
  11. The_Crapman
    5 Dec 2011
    That's absolutely fantastic. :rock:
  12. Vault-Tec
    30 Aug 2015
    Amazing. Finally someone has completed a WOPR! They usually make it to the LED then go awful quiet :D
    Congrats man it looks incredible.
  13. Zenator
    Zenator Minimodder
    12 May 2015
    Love it :)
  14. random2k4
    11 Aug 2015
    Thanks! Yeah the LEDs were quite a challenge.
  15. kim
    kim hardware addict
    10 Jan 2016
    The final result is flawless, remarkable work as usual, I am really impressed by the wide range of skills you're mastering, and the originality of your ideas.
  16. random2k4
    11 Aug 2015
    Thanks a lot! I really appreciate it.
    Always try to learn something new with each project.
  17. lowfat
    lowfat Minimodder
    4 Jul 2013
    Looks awesome.
  18. random2k4
    11 Aug 2015
    And a short making-of
    Vault-Tec likes this.
  19. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    One of my all time favourite movies and this has to be one of my all time favourite builds. I totally love it, wonderful work.
  20. random2k4
    11 Aug 2015
    Thanks!
