Case Mod - In Progress [Worklog] Purple LI
Discussion in 'Project Logs' started by aRkangeL, 29 Nov 2010.
  1. KidMod-Southpaw
    28 Sep 2010
    Very very nice vinyls! A little big though?
  2. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    I don't think, but the machine can't cut less than this.
  3. bolandrm
    bolandrm What's a Dremel?
    29 Mar 2011
    I am actually thinking about buying the same case for my first case mod. Are you planning on painting the case purple? I would like to paint it metallic yellow with black stripes and cut a window in the side. What paint / primer / procedure etc would you recommend?
    Thanks!
  4. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    I don't will paint the case...
    I recommend that anodized the case, or lacquering. Its the beste way, because on normal painting you can ruin the paint more easily.
  5. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Could also be just sleeving, you took a pic of - how about including the actual 8-pin EPS connector in the shot? ;)
    But realy eager to see HOW purple this build will look in the end - not seeing too much of it at this point? :)
  7. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    No no, its EPS cable, you want photos?! AHAH
    this shot its only a teaser shot...
    I will use the purple in the sleeving, and fluid...
  8. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  9. Nutman
    21 Oct 2008
    Haha, thank you. ;)
  10. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  11. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  12. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  13. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  14. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    nice one man, i can see that you have seen "Hannes's" Projects ! Gj !
  15. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks a lot friend!
    Yes the projects of big hannes are really nice!
  16. KoSoVaR^
    19 Dec 2010
    He is a big fan of me to :), has folowed his project on sweclockers a long time now :p, i dont have the time to fix the pictures as he does but i have always wanted :)
  17. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yeh this takes time and its needed some skills!
  18. KoSoVaR^
    19 Dec 2010
    I have PS skills :), but no time :O... :(, Check out my project (Project Chocolate Temptation) here on Bit-tech :)
  19. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    I have some skills but not those who wanted!
  20. KoSoVaR^
    19 Dec 2010
