Modding X-box game controler mod
Discussion in 'Modding' started by M_D_K, 17 Feb 2003.
  1. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Ah well, 40,000 people can't be wrong.
    But nice work, though M_D_K ;)
  2. fathazza
    fathazza Freed on Probation
    20 May 2002
    bradford i miss mr dickinson please bring him back....
    hazza
  3. bradford010
    7 Dec 2001
    lol, I'll see what I can do. Coincidentally, I have uber bargain hunting in the works which promises to yield results that will crown me as the Duke :hehe:
  4. afjs1413
    afjs1413 Minimodder
    13 Jan 2003
    Hi, i just got a quick question...
    If i do this mod but with a steering wheel or somehting else for the Xbox, will it work with the same drivers?
    I assume it will but just wanna make sure..
  5. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    hmm if i could find the drivers i'd do this to my old snes controller.. so that i could use da controller for my favourite snes games on my comp... or ps2 controller, i prefer that over xbox controller
  6. M_D_K
    M_D_K Modder
    3 Apr 2002
    A-afjs1413= No i belive they are just for the contoler
    A-metarinka=No you can't put a usb end on a PS2 contoler well i don't think you can anyway my mate eaterofpies made a parelel PS adapter that works well and also increases the vibration it runs off one parele port and your 5v supply, the plans i have somewhere and could find them if anyone wants them and the snes thing wouldn't bother they are crap compared to the X-box or PS/PS2 controlers.
    I did this mod purely for the fact atht the X-box controler has so many buttons yokes and hats its very vresitile and good on games. Plus when i get my New Madcatz Min Con controler then it will rule.
    keep the questions coming
  7. Mister_Tad
    27 Dec 2002
    right then the only thing that i miss in pc controllers is pressure sensitive buttons, surely they would make sence to have
    do the drivers for the xbox controller recognise the amount of pressure on the buttons or does anythgin for the pc actually support pressure sensing buttons?
    ive got a wireless logitech wingman runmblepad (bit of a mouthful) at teh moment but xbox controllers are pretty schweet too :D
  8. sp00n
    sp00n What's a Dremel?
    21 May 2001
    The XBox controller buttons are digital, so no pressure sensetivity there. The two rear triggers are analogue, so you could use those instead.
    Does anyone know if you can buy the lead between the controller quick release socket and the xbox connector? That way splicing a USB connector onto the short lead lead would be smaller than using an entire extension, and might look better as well.
  9. Annon
    Annon What's a Dremel?
    22 Mar 2002
    Actually, the Xbox controller buttons are analog. Check out http://gear.ign.com/articles/306/306618p1.html .
  10. M_D_K
    M_D_K Modder
    3 Apr 2002
    I havn't found any of the short leads i spent quite a long time looking for one, well actualy about 20mins but hey short attension spane.
    The rear buttons come up as another axis if you look on my picture you have,
    Left box - Left analogue stick
    Z Ax - Left analogue trigger
    Z Ro - Right analogue trigger
    X Ro/Y Ro - Right analogue stick
    Point of View Hat - The D pad on the bottom left
    Buttons - all the buttons including the buttons on the analogue stick when you press them down
    lets keep all the Q coming as im bored and have nothing else to do
  11. CrOaKeR
    CrOaKeR Host warrior 4, Vengence!
    21 Feb 2002
    GAME stores in teh uk stock packs of 3. Well at least mine did, I am lucky to have 2 game store in one shopping centre :D
  12. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    where can i get drivers? the ones i use wont reconize the trigger buttons.
  13. death_star
    death_star What's a Dremel?
    14 Jul 2003
    done a LONG time ago.
  14. Froggy
    10 Jun 2003
    the links on here dont work. thats why i revived the thread.
  15. death_star
    14 Jul 2003
  16. Pliskin
    Pliskin What's a Dremel?
    23 Aug 2003
    could you post the wires you connected to what? I tried mine, and I'm sooo lost
    I have mine conected as folows
    Pins
    USB 123 4
    Xboxusb 12345
    I discarded using xbox pin 4 as i have heard that it's the 12 volt line, or do i need to connect that to pin to usb pin 4?
    ne help needed!!!
    *edit*
    pinout connection i have (pcusb to xboxusb) 1-1 2-2 3-3 4-5
  17. Pliskin
    23 Aug 2003
    :-( it dosent work, i tried several guides, they say all the same things.... WHY WONT IT WORK???!!???
  18. death_star
    14 Jul 2003
    white to white green to green black to black red to red and forgot yellow not needed
  19. metarinka
    9 Feb 2003
    I have seen old drivers and plans to get snes or nes controllers to run off the ps2 port. Its not terribly hard, and for the classics you just cant' beat a snes controller. then again I mostly play fps now.. and an snes controller wouldn't get me past the buy menu...
  20. Pliskin
    23 Aug 2003
    craptastic, that dosent work............ perhaps the wires inside the outer plactic are broken.............fun for another day..... perhapse I'll just purchace a premade converter box
    *edit* in fact there was a break... but i did past it, and i have for sure good connections.
