Scratch Build – In Progress xSlim - one more HTPC! :D - tiny update 28.04.2009
Discussion in 'Project Logs' started by HeXeN, 30 Jun 2008.
  1. Attila
    Attila still thinking....
    22 Feb 2008
    Congratulations on your good fortune HeXen., :clap: It's always good to hear about someone
    having some good luck, and I'm glad you are continuing with this project, I wondered what ever
    happened to it.
    PS: That's a good mobo/CPU combo for a HTPC, our tv runs off that very same combo with a
    dual tuner tv card. :thumb:
  2. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    One more time... and i will be very angry "$@%!%@$%%@"
    Fortune is turning with her a55 to me! No time, no time, plenty of voices in my head :D
    First of all, i have made some preparations for next step of "modding". That's the preassembling of new parts at my workshop :) 4mm thick alu and 4mm thick transparent perspex for mobo tray.
    Some Screews, bolts and lots of unwanted stuff​
    [​IMG] [​IMG]
    Finally i found some things for mobo and mobo tray.
    [​IMG] [​IMG]
    Taaa Daaaa -> preassembled case. I know perspex is a bit to big, better have to much than less :eyebrow:
    Let me know how it's looking.​
    For sure there will be engaved pattern but still no such thing in my head (any ideas ??)
    Alu will be polished to the mirror look, engraved pattern will be filled with black paint.
    I was thinking about flower patterns (i don;t really know how to describe them) but this will look like scatches. second option will be a mechanical scetch last is paintstripping pattern.
    What you think?
  3. ringo
    ringo What's a Dremel?
    14 Jun 2008
    First nice Frame and metal work.
    You can also engraved a wood style, twines flowers or something else. But I don't know how you will like it. If you want some technical drawings, you can engraved some gears or something else.
  4. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    Nice work I will be watching this one.
  5. HeXeN
    14 May 2006
    @ ringo - thx first of all - mechanicall gears - that can be quite easy to draw - i'm not to good at drawing :D
    @ Thx AFX :)
    Reagards,
    Tomek
  6. ringo
    14 Jun 2008
    You can copy it from some pictures like this one [​IMG]. You only have to check, if there is a copyright on the picture. Or you use it and make some easy changes.
  7. HeXeN
    14 May 2006
    Thanks for the design :) that's nice of you! I think i will try to make some sketches. I will have 4 days holidays.
  8. The boy 4rm oz
    10 Apr 2008
    I'm glad to see this back on track, I can't wait for more.
  9. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    All good so far :)
  10. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Wow. It is looking good, and tiny, which is even neater. 80mm high? Gyah!
    That Alu will look nice with some subtle etching.
    Laz
