Case Mod - In Progress ZdMods | Project 720 | Started on the top - Oct 17
Discussion in 'Project Logs' started by Meelobee, 12 Dec 2013.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Thanks craig :) The sanding directions don't matter much as the plates will be painted in a later stage.
    I'm still working on the midplates, but with a 40hour job and an almost 2 year old I don't have as much time for the build as I would like..
    I've made a small photo setup, still not perfect, but it gives way better pictures than before. Next big update will have all pics taken like this;
    Last night I had some time to work on the plates, decided to redo the spacers between the plates. Now the are made from brass instead of aluminium and all are filed to exactly 20mm so the plates are all level. I've also used countersunk screws on both ends for a much cleaner look.
    Almost done, 3 holes, 2 spacers left :)
  2. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Very impressive as always! A true master of aluminum!
  3. SiZZiGY
    SiZZiGY Nano Evolution in progress...
    11 Oct 2013
    Very nice idea thoses plates I really like it :) Looking forward, will be a fantastic casemod :)
  4. sprintdmc
    sprintdmc What's a Dremel?
    16 Apr 2013
    Great work Meelobee, very creative and great designs. Looking forward to watching this progress.
  5. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking good man!
  6. Meelobee
    5 Nov 2003
    Thanks guys :)
    so yeah about time for an update!
    First up, the reservoir I'm going to use, a big fat Aqualis 880ml :) Gotit 2nd hand, but it looks brand new :)
    The box is a bit damaged
    But the reservoir is in perfect condition and looks awesome
    From Coolermaster Benelux I got a set of white Jetflo 120 fans, 7 in total, thanks Ruben, you rock! :rock:
    The sticker on the fanhub was replaced by a custom ZdMods logo made by plakjesuf
    Then the midplates, the part that was most time consuming so far. Did quite alot of filing to get all the plates to the right size. The 2 plates on top need some additional work so I can fit the mobo and mobotray, but thats for later. The plates are connected with countersunk sleevenuts with a brass 20mm tube around them.
    To support the midplates I cut a couple of 20x20mm alu corners and attached them to the front and back of the case
    And one last pic with the front
  7. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    That looks so sweet. Nice work. :)
  8. OrangeClockwerk
    28 Jul 2013
    Basically the best Dell XPS I have seen brother! Keep it up! :clap: The aluminum work is fantastic hand crafted artwork!:dremel: I love all your builds so far, always something new and unique to keep people on their toes and guessing whats next!! I have a 400ml Aqualis sitting around from my first build, I need to use it already :sigh: , its such a nice reservoir, I keep wanting to make handmade reservoirs now that I know I can lol! I actually wanted the 880ml one you have here but couldn't find it when I was building my first water loop so I got the 440 nano-coated one. Great products anyhow! Oh yeah congrats on the cooler master fans, is that a sponsor for the build now? Anyhow, can't wait to see more updates on this!!
  9. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    It's so beautiful! :jawdrop:
  10. Meelobee
    5 Nov 2003
    Thanks craig :)
    Thanks man :) I try to always find an original approach with each case, looks like I found it for this one too, I got some idea's for the mobotray and wiring too, so I hope its going to be even better. I love the reservoir, it really is beautifull, can't wait to see it in the case filled with fluid and the leds on. And no, got the fans for a review.
    Yeah it really is a nice cat :D ;) Thanks Maki!
  11. Hukkel
    20 Dec 2012
    It looks great! Nice and original.
    Will you paint the case of maybe poslish it shiney inside and out?
    I'd love to see the inside shiney silver so all those layers and front and backside will reflect the shapes and light.
  12. Meelobee
    5 Nov 2003
    Thanks Hukkel :)
    Not sure on the finish yet, polishing would be cool, but that requires the surfaces to be in perfect condition, as scratches and other damage would really show. Painting gives me a bit more options on the finish, and I can fix the small damaged spots and once painted they won't be visible anymore.
  13. hero1
    hero1 Minimodder
    18 Oct 2013
    Looking great.
  14. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    An incredibly innovative multiple midplate design? Or a mind-blowingly gorgeous front panel design? Which one... Hm?
    Looking great, man! Can't wait to see another update in the near future!
  15. AlderonnX
    AlderonnX Minimodder
    10 May 2012
    EPIC !:clap:
  16. Meelobee
    5 Nov 2003
    Thanks guys :)
    Not much updates lately, busy collecting parts and materials for the case. Ordered the aluminium plates for a mobotray and bottom plate last friday, they should arrive somewhere this week.
    And I've bought a mobo, an Asus Maximus VI Formula;
    More when I got the aluminium :)
  17. Meelobee
    5 Nov 2003
    Update time! :)
    Made a mobotray from a 3mm aluminium plate (32x49cm) and installed the standoffs for the mobo. Decided not to use a rear i/o bracket, but instead installed the i/o panel right into the backside of the case;
    I've cut almost half of the mobotray away to get a more open feel/look
    The mobotray is held in place by small aluminium corners, on this picture the first two are done
    And here the third is done too (The small corner on the top right)
    Installed some parts to get an idea of the look, hmm not too bad at all :naughty: :lol:
    The 5h plate is measured and filed so it wraps around the mobo
    Hard to see, but the double bottom is also installed, under the white plate on the bottom there is 15mm space to hide cables
    That's it for now..:dremel:
  18. siliconfanatic
    10 Sep 2012
    Refreshing to see some nice, healthy progress on this. It's turning out really well, too!
    G0UDG likes this.
  19. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Money can buy expensive parts, but not great aesthetic sense.
    I love the contrast of linears and curvilinears! These highlights are well balanced, and just right.
    Keep 'em coming, M!
  20. Meelobee
    5 Nov 2003
    Thanks silicon, progress is a bit too slow imo opinion, but I've only got so much time..
    Thanks for the awesome comment leonetu, glad to hear the aesthetics are seen :)
