Hardware Zotac GeForce 9300-ITX WiFi mobo
Discussion in 'Article Discussion' started by Tim S, 18 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Aw... It is just so cute... Who is a cute little Motherboard then? You are!
    I like the look of it, but I think it might have been fun to throw a graphics card in and see the gaming performance. This plus an E8500 and a 4850 could do nice things...
  3. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    hehe this thing would be awesome with a GTX 295 and a QX CPU!
  4. Combatus
    16 Feb 2009
    I'd have to agree!!!
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    i just love this featureset for such a small form factor. I'm putting together a compact gaming machine, and if i hadn't just purchased a DFI P45 JR and a 130W cpu, i'd snap this up in a second!
    I'm seeing the design already... the column PC: PSU and HDDs on the bottom, vertically aligned mobo above that. Fold a good GPU towards the back of the board with a flexible PCIe riser, cool the CPU and 9300 with a short water loop, all cables connected to the top, and a single 140mm radiator above that... damn i gotta start drawing....
  6. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    any chance of a gaming performance review?
  7. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    can you stick a Q6600 and GTX 295 on and see how it performs :)
  8. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    A perfect candidate for a Sugo SG5 case and a proper gfx. Super mini gaming rig! Sadly this will never come to finland :(
  9. The boy 4rm oz
    10 Apr 2008
    I really do like these Zotac boards. They can take modern reasonably specced hardware in a very small size, perfect for a HTPC mod ;).
  10. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    wot, no HQV-HD tests? or is the disc still missing :p
    this does look like a very shiny board, but for an HTPC board i dunno why anyone would compromise on image quality and get this instead of the g45 board. unless of course they need that 16x slot, in which case arguabliy speaking they have the space for an mATX board.
  11. wgy
    wgy What's a Dremel?
    28 Jul 2008
    i would love to see how this would preform with a quad, and a high end GPU
  12. verdi
    verdi What's a Dremel?
    12 Feb 2009
    oooh I've been waiting for this. Cheers guys and will try and order one tonight! I got the designs ready for the project and is close to what xtrafresh says above without the water. Can't wait!!
  13. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Love to see this actually being build :D
  14. Xtrafresh
    27 Dec 2007
    I might have to copyright the idea, i think this is what i'm going to enter in the case design compo...
  15. Guest-16
    Guest-16 Guest
    PC Pro wanted it off us to review, there's only one sample in the whole of Dennis.
    Our HD HQV disk is HD DVD. Our HD DVD drive is IDE, but neither this or the Intel board has IDE :(
    The image quality is still very good, and just drop in a 4670 - doesn't require a PCI-E connector, plus has better HQV performance and UVD2. Plus, you still get to keep a smaller form factor. Although the smaller form factor does cost £40 more than mATX.
  16. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    95W max on the supported CPU's, so no.
    but a Q9xxx and GTX295 would be fine. that would look pretty crazy, with a big heatsink as well, the motherboard would just look like a bit of sellotape holding the GPU and CPU in place.
  17. Guest-16
    Guest-16 Guest
    Q6600 G0 is 95W, you just can't overclock it. A dual core would be far better - less stress on the front side bus and power hardware.
  18. Xtrafresh
    27 Dec 2007
    agreed, a quad really has no place in this thing, but a nice E8600 should be able to hit 10x450 :naughty:
  19. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Small size, yet supports Powerfull hardware.
    DO WANT!!!
  20. Vhet
    Vhet What's a Dremel?
    4 Mar 2009
    If i may do some whining:
    Page 3, "this should be enough for substantial overclocks on most Core 2 Duo CPUs even with 266MHz and 333MHz DDR2 RAM (just make should you have the have the cooling to go with it too)."
    scuzmewut? assuming should would be sure.
    ~vhet<3
Tags: Add Tags
