Case Mod - In Progress ______RESURREKTION______
Discussion in 'Project Logs' started by mnpctech, 22 Apr 2011.
  1. Watchtown
    Watchtown What's a Dremel?
    2 Mar 2010
    Whats great with communities like this is that you can get new ideas, copy with changes to your own wicked ways, nice skull it looks a bit desolate like mad max
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Thanks! & Nice reference, Mad Max & Road Warrior are all time favorites.
    Anyone know where you get the Black BP G-1/4" plugs shown on this res?
  3. catsol75
    catsol75 What's a Dremel?
    2 Mar 2010
  4. LPRaver89
    LPRaver89 What's a Dremel?
    6 Sep 2011
  5. mnpctech
    21 Apr 2003
    Thank you very much catsol75! :thumb: Here is the chassis so far with Reservoirs mounted.
  6. mnpctech
    21 Apr 2003
    I'm still thinking about different plugs for the reservoirs. I made these spike fan control knobs on Hellbound, I could scale them down with G-1/4" thread and add diamond knurling on the bottom, anodized black...
  7. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Definately the right place for those reservoirs! :thumb:
    Me likey! :)
  8. Cheapskate
    13 May 2007
    They need a halo of spikes, not just one.;)
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Quite possibly :D.
  10. mnpctech
    21 Apr 2003
    Thanks guys! I'd like to...
    and "Halo of Spikes" ...sounds like a Death metal Band :D
  11. mnpctech
    21 Apr 2003
  12. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I really like that look! Black with those silver edges looks fantastic!
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice effect :).
  14. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    I'm a huge fan of the res placement!
  15. Guest-56605
    Guest-56605 Guest
    That Overkill ring is a gorgeous, liking that effect Bill :thumb:
  16. mnpctech
    21 Apr 2003
    Thanks for the comments guys! I sneaking away to get back to this...lol. And another found object I've saved for this build, a 3x120mm Mounting frame from NZXT Khaos tower I dismantled awhile back. Fits perfect! and with some slight modification, it will serve as location for one of the radiators.
  17. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Res placement looks awesome Bill, think Cheaps is right about tons of spikes! maybe a ring of smaller spikes and then some big chunky G1/4" ones for the plugs.
    Looking awesome as always though :D
  18. mnpctech
    21 Apr 2003
    Thanks man! and Yes, cheaps always has great ideas! :D
  19. LeandroJVarini
    LeandroJVarini Mod is my life!
    25 Dec 2007
    Another fine project by Bill!
    perfect design! congratulations
  20. Cheapskate
    13 May 2007
    I have just as many BAD ideas.;)
