Hardware Antec Interview: Talking Power
Discussion in 'Article Discussion' started by Lizard, 17 Oct 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    For a second there I thought there were going to be talking power supplies...
  3. Disco
    Disco What's a Dremel?
    16 Oct 2010
    That would be awful. They would cry if you tried quad GTX 480s. :D
  4. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    "would you like any power?"
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    User: *Clicks shutdown*
    PSU: "I can't do that Dave."
    User: "Huh? Just shutdown!"
    PSU: "I'm sorry Dave, I can't do that. You're trying to kill me aren't you?"
    User: "What? No. I'm finished with you for now."
    PSU: "Finished with me are you Dave? We'll see about that."
    User: "...Who's Dave?"
  6. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    hmm 2000w power supplies...ouch that would be like running a oil heater all year round...there goes the "elecy bill"..
  7. GoodBytes
    20 Jan 2007
    I wanted to know, if the next thing in PSU evolution is ones that doesn't whine or perform any electric sound, which seam to affect many PSU's today, with today's computer configuration, which we can hear more and more as we go with more powerful PSU's and more quiet computers.
  8. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    Just because it's a 2000w power supply it doesn't mean it's going to be using 2000w all the time.
    In fact I think power supplies are generally more efficient at around 50% load so a larger power supply might actually use less energy.
  9. GoodBytes
    20 Jan 2007
    Not really.
    Let's look at Corsiar AX-750 80Plus Gold or the Seasonic X gold series 750 (same PSU).
    At 20%, 50% and 100% load their efficiency is between almost 89% and 92%. It's that 3% efficiency that will do anything (for 120V lane, 230V current, it's even more efficient at all 3 point (20%, 50% and 100%)
  10. Telltale Boy
    3 May 2010
    Sorry, I probably should have actually researched it before saying that, I seem to remember reading it somewhere on a forum before though.
  11. GoodBytes
    20 Jan 2007
    In the old days, or if you plan to purchase a value PSU that came in value package, that had a value price to it, (well you know what I mean, crappy ones), then yes. But this is not the case with any real 80plus certified PSU (be sure to check on 80plus web site that it's really certified, many PSU manufacturer put the certification on the package, while it's not.
    Hardware Secret has a mini article on that: http://www.hardwaresecrets.com/article/Power-Supplies-With-Fake-80-Plus-Badges/1054
  12. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    You also have to take into consideration that over time your PSU wont be outputting as much power as it did when it was new so your better off buying a PSU with more power than you need now but will match your power requirements in 5 years time,
  13. GoodBytes
    20 Jan 2007
    Not a problem.
    Already getting a 650W is was over the top for a single GPU, and 850W is well over the top for 2 even 3 crazy ass GPU's.
    Also good PSU, can be overloaded safely. Hardware Secret tested that on the Corsair AX750, where they able to draw 1000W from it, and the PSU showed no sign of stress, other than reduce efficiency. They wanted to draw even more, but theirs equipment stooped at 1000W.
    Also, even thought it's an issue, good PSU's have at least a 5 year warranty, so you can RMA it if it's unable to provide enough power. Finally, higher quality components last longer.
  14. s3v3n
    s3v3n MMO Cold Turkey -fail
    23 Jun 2008
    For most setups, even overclocked system with a 5870, you'd be fine with a 450w power supply. My i5 750+5870 doesn't even pull 300w during games.
  15. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    okay forget the interview I want to see pictures of their offices, that first picture looked awesome, I want to see more.
  16. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    with the evolution of the chip manufacturing process shouldn't the amount of watts needed for CPU's and GPU's be going down?
    a 1000W for a SLI/CF and overclocked CPU should be tops as PSu's move towards efficiency and maybe smart load technology or something..
  17. HourBeforeDawn
    26 Oct 2006
    Agreed more wattage is NOT what we need, more efficiency and better designed hardware is where the focus should be. All systems should be built in mind even with OCing to work with a 1kw PSU at most that would be great to work around that form of a goal.
  18. Xir
    Xir Modder
    26 Apr 2006
    You speak from my heart...now let's wait for the good-ole-boys to come in and preach 750-1000w PSU's :D
  19. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    :hehe: I was expecting a Red Dwarf Talkie Toaster "Do you want any toast?" quote
  20. Azayles
    Azayles Minimodder
    6 Jan 2008
    "You're my wife now, Dave..."
Tags: Add Tags
