Scratch Build – In Progress Anyone interested in a workshop build?
Discussion in 'Project Logs' started by Goatee, 14 May 2020.
  1. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Looks pretty secure (or at least as secure as said big ass padlock will be).
    Looking at those lovely big windows, though, they seem to be a bit of a weak point - both from an ingress point of view but also that they'll give any scrotes a good chance to check out all of the nice stuff inside. Are you planning to put any security film on them or anything?
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
    yeah, windows will be an issue. Door hinges have straight through bolts, I plan to fit some bolts rather than screews to the bolt receiver and wall hinges, so even if equipped with the right screwdriver you couldn’t get the hinges off.
    Im looking for some film, ideally security and thermal combined.
    There is space for some secondary glazing panels, so some 6mm thick polycarbonate would be sufficient.
    I also have some 12g blank firing “Alarms” from my airsoft days. One of those inside the door when on holiday (if that’s even a thing in the future) will at the very least alert the neighbours and require a new set of trousers for said scrote!
    bawjaws likes this.
  3. David
    7 Apr 2009
    Mounting the hook for the middle hinge upside down also prevents the door being prized off the hinges - top and bottom hooks are more than enough to take the load.
    Goatee likes this.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    I did think about doing that as I had the hinges off, I will likely do it when I bolt them through the frame.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Started boarding out
    Lighting is in and connected to a junction box. When the spark does the rest of the house, will ask him to install the consumer unit (as he will need to run a new cable out to the workshop).
    Tested my concept for the trunking and sockets.
    I really like the aesthetics so will go with that. All wiring will be fed via the roof to enable easy access in the future for alternations.
    ifohancroft, Sam__ and ciaognep like this.
  6. Cheapskate
    13 May 2007
    When does the stripper pole go in?
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    That's in the back room.
    The_Crapman and MLyons like this.
  8. legoman
    legoman breaker of things
    28 Feb 2010
    Liking this a lot, on the sockets, did you not think about one with USB?
    Also the conduit sockets are far easier to fix issues or make alterations.
  9. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yeah, might put a USB one a socket, good idea!
    Picture dump - Warning very OSB!!!
    And I may have sliced through my work table!
  10. David
    7 Apr 2009
    Oriented Strand Board.
  11. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Workshop is looking good. Now that you have work shop you can build a new cutting table.
    There are a few engineered wood products that all look very similar but have a key differences.
  12. legoman
    28 Feb 2010
    Yeah I put a circular saw through one half of a saw horse, still usable similar to what you did.
    Socket wise, may be worth looking at along these lines, reason being most put the USB over the plug, so if you have a tall adaptor it will cover the USB making its useless
    https://www.screwfix.com/p/13a-2-ga...2-outlet-usb-charger-with-white-inserts/8009j
    MADPC and Goatee like this.
  13. Cheapskate
    13 May 2007
    I got a splinter looking at that. I was never a fan of composites. The tiniest bit of water damage and they turn into the bottom of a hamster cage.
    -Hell, I'm currently rebuilding particle board cabinets that melted.
  14. Goatee
    Goatee Multimodder
    19 Apr 2015
    OSB isn’t too bad, I’m using OSB3 which is a higher grade designed to withstand more moisture ingress.
    Im going to be pretty pissed if I get enough moisture inside the shed to cause an issue!
    I did get a couple of splinters cutting all 18 of the boards up. I still haven’t done the roof, it’s a weird side 65-80cm by 155cm and I would need 12 panels that size which would generate loads of scrap off standard 120 x 240 panels. (8ft x 4ft in freedom units for you @Cheapskate )
  15. Yaka
    Yaka Multimodder
    26 Jun 2005
    Sweat build, all that foil insulation reminds me of buck in better call saul
    Goatee likes this.
  16. Cheapskate
    13 May 2007
    Could you use masonite strip siding instead?
  17. Goatee
    Goatee Multimodder
    19 Apr 2015
    There is only two support rafters, so its not quite that simple.
    I like that idea, I had been contemplating using something like this that comes on a roll. I could cut to size, then staple onto the rafters to give the air gap for the roof insulation to work its magic.
    Some more OSB goodness, now with lighting, power and storage area for all the roller bins.
    I may have had to cut down one of the worktops as I made it too long. I couldn't get the roller bins in. Ooops
    ifohancroft likes this.
  18. Goatee
    Goatee Multimodder
    19 Apr 2015
    Or use a spinney blade of death and finish with a handsaw, 2 minute fix.
  19. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yeah, couple of screws, bing, bang, bosh!
  20. Arboreal
    21 Jan 2011
    How's it going?
    Watching with renewed interest as my wife has been told to expect to WFH for up to a year.
    We're now actively looking at what we can afford to build in the way of a garden room approx. 4x3m for her to work quietly and comfortably in.
    This is because the dining room table isn't going to be great forever, and there's no room in an awkwardly [to divide] shaped living room.
    One we llked at used the same insulation in the roof space as you have been using, with Kingspan/Celotex under the floor.
    No one other than the £18k 'looks like a real house room' guy has suggested lining the walls. We'll be going with 44mm 'log' construction.
