Hardware Apple tries harder to prevent upgrades
Discussion in 'Article Discussion' started by Claave, 16 May 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    You'd have to be a chump to buy Macs these days.
  3. msm722
    msm722 What's a Dremel?
    1 Aug 2005
    Yea I can't understand why upgrading something like a HDD should be discouraged.
  4. xs_damage
    xs_damage What's a Dremel?
    19 Feb 2010
    wow. The most unreliable component in the machine can no longer be easily replaced. Apple are really testing customer tollarance now.
  5. adam_bagpuss
    24 Apr 2009
    LOL just another step to control you even more by Apple.
    next step is to charge you for conencting to wi-fi. "Want to connect to wi-fi sir then you gotta pay us as your not using an airport product"
    forget the hassle buy a cheaper better PC that allows for such things.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    iMac are not really designed for self servicing, so it's no surprise.
    5600rpm? they use Delta fans or what? it's mostly laptop components FFS, there simply is no need. oh wait, iMac designed for the eyes, not for practicality.
  7. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    This is an odd move, but they've never really made it easy to access the hard drives anyway, especially in laptops.
  8. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    The real price of fashion.
    Jehla likes this.
  9. Xyllian
    Xyllian What's a Dremel?
    24 Jan 2011
    The answer is monies, Apple charges three times the amount than a etailer for identical hdds, its a cheap move by apple, i like their handhelds and top laptops but other then that it is pure crappolution.
  10. javaman
    javaman May irritate Eyes
    10 May 2009
    Hence the reason I don't buy apple products. I want to choose how I use the product not be told that I have to download from here and use this piece of software or this sim card with what ever deal we want you to take. Their products aren't that good that I can't get what I want elsewhere usually cheaper and better.
  11. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    It's probably a blower, like those seen in graphics cards. Higher RPMs for the same throughput - and easy to make run fast.
    I'm not sure this will entirely cut off upgrades. Apple authorized repairers can order official Apple parts such as hard drives extremely easily - it may result in higher prices, but probably not much more.
    It's a shame though - I just replaced my Macbook Pro hard drive with a Crucial SSD, and it's given all the improvements I expected. It wouldn't be nice if Apple were to stop this.
    Jamie - What laptop have you used? My MBP 2010 13 inch, once I removed the back panel, the hard drive was locked in an anti-shock bracket by four screws - which were easily removed. Yes, there were a couple of Torx screws, but they were easily sorted.
  12. wyx087
    wyx087 Multimodder
    15 Aug 2007
    that's the issue people are commenting on: it's about making sure all material comes out of their marked-up source, rather than directly from actual component manufactures.
    even blower does not need to be that fast. 5870 blow at around 3600 at highest speed. gtx580 blow at around 3000 at its firmware limited 85%. (from personal experience of owning them). normal fans are much better, but they cannot fit it inside a the slim design, so instead of changing product appearance, they chose to use inferior component. (inferior in terms of heatsink size, thus require higher airflow)
  13. Rustypouch
    Rustypouch What's a Dremel?
    5 Feb 2011
    God no!
    I'm not surprised by this move to be honest. Most people don't really give a toss about what rights they give away these days. I'm not even going to begin the Anti-Apple comments, I'm just so bored of that debate now. They are the Marmite of the Computing World, you either "love it or hate it".
  14. RedFlames
    23 Apr 2009
    haven't they also started using non-standard screws to stop you opening them up?
  15. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Hahahahahahahaha.
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  17. TheBoyBest
    TheBoyBest What's a Dremel?
    21 Apr 2011
    I fix notebooks, desktops and Macs on a component level basis and have to admit to not being a great fan of Apple related products, I can confirm that Apple have started using custom pentalobe screws as well. People seem so keen to buy into the brand, typical of modern living. Style over substance - though I must admit I think my custom built desktop PC is way nicer than something Apple could throw together.
  18. Elton
    23 Jan 2009
    Oh surprise surprise.
  19. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Fixed XD
    Everyone is free to buy what they want, but I can't imagine myself buying a PC that I couldn't even upgrade with a ram stick or a new HDD.
  20. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Thats been Apples mission since day one. They are the PC version of consoles. You want an upgrade, bin your old machine and buy a new one.
    They also try to slow down progression. Look at the IPADS, was there really a need to not provide mini USB sockets and other common standard functionality you would expect now as a minimmum?
    Its so they can sell you a new version every year with a tiny upgrade. If you have a IPAD, is there really a need for you to trade in for a IPAD2?
Tags: Add Tags
