Case Mod - In Progress AppleCoreDuo
Discussion in 'Project Logs' started by Cyprio, 2 Dec 2006.
  1. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Larger pic for some fine detail:
    And one more
    Same procedure for the fan below it and viola! (the 2 areas look slightly unaligned in the pic but it must be the camera angle as they look spot on to me)
    Here is a sneak preview of what the finished cage will look like... remember the inner cage will be black.
    Signing out for now...
    Cyp.
  2. KaotiK
    KaotiK What's a Dremel?
    2 Jul 2007
    Love the G5 case. You've done this case justice :thumb:
  3. Sandwich
    Sandwich What's a Dremel?
    21 Jun 2007
    This is quite an inspiring mod. I love what you have done with the mesh
  4. Dna14
    Dna14 What's a Dremel?
    21 Jul 2007
    I like the look of that. I would like to do something similar myself but It would probably take me forever and end up buying a case. Good Work!
  5. customh
    customh conflagration.
    22 Oct 2005
    Great Job!! Look forward to seeing it finished, even if it is a while off.
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    How long did it take you to drill all those holes???
    BTW great looking case
  7. Cyprio
    2 May 2006
    Thanks for the encouraging comments.
    The hole drilling took me the best part of 2 hours with breaks as i was using a normal hand held power drill and my hands were aching quite a bit!
    I finished quite late last night so the light wasn't good enough for a close up pic of the finished holes. Here you go:
    Looks like i was a bit out with the fan holes along the bottom :( Hopefully with countersunk bolts this will not be as noticable.
    I used this for countersinking the bolt holes by the way:
    I also forgot to add the window in the opposite side panel (door) was cut using a waterjet - the panels are 3-4mm thick and i didnt fancy tackling it with a dremel or jigsaw so sent it off to get professionally cut. They did a pretty smooth job and cut out the semi-transparent mirror plexi for a flush fit as well. Will post more pics of this in my next update.
  8. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    DAMN, DAMN, and DOUBLE DAMN!!!!!! HOLY CRAP THAT LOOKS GOOD! Submit it to ALL the modding contests you can dig up!!!
    Brendan
  9. Sandwich
    21 Jun 2007
    Then apple being apple would prolly sue his pants off... then jack the design for themselves. and then steve jobs well do a press conference saying how great his designers are then proceed to grope himself.
  10. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    That's a really cool way to drill your own mesh. Those grills looks stock, great job.
  11. Predatator295
    Predatator295 What's a Dremel?
    23 Jul 2007
    Congratulations, I love this mod, and a lot of job have been made!!!!!
  12. Franklin
    Franklin Minimodder
    24 Oct 2004
    Great job so far. It's not easy to mod a Apple G5 case and make it even look better. B.t.w. this reminds me of the Mr. Bean mod, but I hope you will finish it, Mr. Bean never seems to finish his mods :waah: I'll keep an eye on this worklog.
  13. Brett89
    Brett89 Minimodder
    15 Dec 2005
    Fantastic work on the holes, looks top notch. Amazing hand-work. I love the G5 case stock, and it's awesome to see someone improve upon it.
  14. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    looks good, 5* and subscribed :)
  15. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    OMG! that's a serious amount of drilling!! :eeek: Good idea with the guide plate!
    It's comming along nicely.. thought you had sacked the project there for a while, and I'm glad to see you back at it!! =D
    Will continue to follow this log closely... keep it up! :thumb:
  16. Cyprio
    2 May 2006
    :thumb: Thanks again guys. Dont worry - i WILL finish this. I feel like that i have been living and dreaming this mod for so long now that any other conclusion is simply out of the question!
    I work full time for the National Health Service in London and so the only time i have for modding is weekends and for those of you who live in a big city you know how much stuff there is to do on Sat/Sun so its a bit of a battle for time. :)
    I have just received loads of bolts (countersunk and button head) and have also ordered some primer and matt black paint. Will update at the weekend... i promise. ;)
    Cyp.
  17. Cyprio
    2 May 2006
    Couldn't wait as they look so good! :)
    Now that is what i call "Snug":
  18. Macros_the_Black
    7 Jul 2007
    Good to hear! =) hehe, I hear ya.. I have this huge project that I'm still planning atm (came up with the idea about a year ago), and all I can think about is how I'm going to solve this and that problem, and so on and so forth. I really look forward to start buildning, but alas that's probably another 1-2 months of further planning away. <=)
    hehe, then you should be well aware of the downsides of consuming alcohol... heh, I not even sure what the NHS does..... aaanyway.. what I mean is, stay away from thoose beers and do some magic with them tools of yours instead! ;P
    Looking sweet!!
    Btw, perhaps I didn't :read: properly, but are you going to paint any part of the case later on?
    [edit] where did that extra word come from?? *deleted* [/edit]
  19. Cyprio
    2 May 2006
    Yeah Macros, if you look at what i have done to the middle cage i am going to paint it matt black as i need to hide the epoxy. I needed to mod the rear quite a bit to make it PC compatible. I also had to change the front ports to PC compatible ones. :)
  20. Macros_the_Black
    7 Jul 2007
    Goodie! That's what I was thinking about (the epoxy). Will probably look real nice with brushed alu and matt black... can almost picture it.. mmm, liking it.. looking forward to seing it done! :thumb:
