Case Mod - In Progress Battlestar Galactica Mod: Complete!
Discussion in 'Project Logs' started by Boddaker, 27 Mar 2007.
  1. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    wow, i hate that show but i love this project
    keep up the great work:dremel:
  2. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    nice! alot done since christmas. great job!:)
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Yup, it's looking great bod :)
  4. BlastoNecrosis
    BlastoNecrosis ...farted!
    30 Jan 2008
    Woa Dang!
    So i've lurked these forums for some time...and am approaching the time for my first casemod...and your is just fan-freaking-tastic...so i thought i'd finally pop in...
    AND...ask a question if i may....
    what is the styrofoam you are using and what is the stuff you use to make a shell over it withought destroying it?
    for the mod i am going to be starting soon i wont need "shells" but rather a protective "hard shell" over the styrofoam. so i was just wanting a lil advice =D
    thanx and again GREAT looking mod!
    ~Blasto:rock:
  5. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Thanks Blasto! :D
    The pink foam I used is standard Owens Corning insulation sheeting. You can get it at your local Home Depot.
    The "shell" was made by a two-part plastic resin called Plasti-Paste from Smooth-on. It's main purpose is to serve as a mother-mold when casting in certain molds. But I used it to save a step so I wouldn't have to create the mold before casting the part. It worked fairly well, but I had a lot of sanding and bondo work to get it smooth. If you check out some of the earlier pages of my worklog, I show pictures of the process.
    Good luck with your first mod!
    :cooldude:
  6. BlastoNecrosis
    30 Jan 2008
    yeh, i think with my mod ill be able to get away with plain ol bondo as i am going to be keeping the foam inside said shell...so coating the foam ---> bondo ---> sanding to smooth finish ---> styrene (plasticard) for the "fluff" :D ---> primer ---> paint ---> matte acrylic finish.
    and as a lil preview....my mod is based off this guy...the forgeworld chaos dreadnought!!!
    yeh....he'll be around 4 feet tall....man...im just collecting the materials ATM but im already salivating :D
    look out for my first post & pics....methinks ill dub him.... THE DREADMOD!!!
  7. Boddaker
    30 Nov 2006
    Wow, that will be an awesome project! Can't wait to see you start on it man. :cooldude:
  8. Boddaker
    30 Nov 2006
    Ok here's what I got to show ya. While I was laid up in the house, I managed to get some details
    put on the side panels. Of course my son had to lend me a helping hand. He turned out to be a pretty good sander! :D
    I got both side panels detailed, as well as the front panel. Once I get a coat of primer on them I will
    take some more shots. (primer always makes things look so much better!)
    TEASER #3
    Here is the unit installed in the case. Actually, this thing won't even be seen once the case is finished!
  9. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    lolol he makes the case look huge! :D Nice work as usual.... hrrmm, maybe he's been the one building this case all along and you've been taking the credit! :eyebrow:
  10. Mother-Goose
    22 Jul 2004
    still can't work out what they are for (the tubes) is it bsg related or is it a case feature that is in no way related to bsg? (as it is internal)
    I like your son's skeleton shirt dude, does it glow in the dark?
  11. Boddaker
    30 Nov 2006
    Crap, you're on to me! Ok, I confess, I've been violating child labor laws to build this case. :hehe:
    The tubes are part of a BSG feature, and will play an important role in its function (even though they themselves wont be seen).
    And yes, the bones glow in the dark. We got that shirt for him for Halloween, and he loved it so much he still wears it all the time. lol
  12. Cheapskate
    13 May 2007
    What do you feed the little guy? I can see his ribcage! :hehe: Sorry, I couldn't resist.:D
    I still don't know what the tubes are for, but I'm hoping you get them charged with argon.
  13. Boddaker
    30 Nov 2006
    MYSTERY MODULE REVEALED!
    OK, here it is: The mystery module is neither a dual res, nor ambient light tubes, but an integral part of a
    functional blast door mechanism! That's right folks, BSG will have fully operational motorized blast doors,
    one on each side. :naughty:
    So far I've got both doors built, and one side totally loaded up onto the spool. Check it out:
    The doors themselves are made up of .010 sheets and .040 strips of styrene, spaced 1/8" apart.
    The result is a strong but flexible door that looks and acts like a segmented garage roll-up type door.
    I glued styrene C-channel to the top and bottom of a piece of clear acrylic. These will be the tracks in which the doors will travel.
    Here is the whole thing positioned in the side panel. I forgot to take pictures of it, but I added a gentle curve
    to the acrylic on the front end heading towards the hard drive cage.
    The door in its closed position.
    I had to cut away part of the drive cage to allow the doors to pass through to the spool.
    To provide a smooth corner for the doors to travel around, I cut a channel out of a piece of acrylic tubing
    and fit it over the sharp edge of the drive cage.
    A shot from the front...
    A shot from the side...
    Here is the panel on the case, with the blast door in its fully open position. It could open more,
    but the drive cage's posterior support beam is right there with nothing exciting to see beyond
    that, so there's no need to open any further.
    Shot from the front. You can see the door reeled up on the spool, demonstrating how flexible it is.
    Now it's on to the other side to finish the tracks and door fitment. I'm still waiting on the servos and limit switches,
    so I won't be able to finish the blast door assembly until then. But it's not like I won't have any work to do while I'm waiting! lol
    8)
  14. InferiorPlanets
    InferiorPlanets Worshiping the SilverStonehenge™
    22 Jan 2008
    :thumb: BIZNATCHIN'!!! :rock: I can't wait to see that in action! Outstanding as usual bro!
  15. markkleb
    markkleb What's a Dremel?
    25 Jan 2008
    I better not find out you are using those countersunk rivets:lol:
    (holy crap 21 pages, hurry and finish the dam thing)
  16. iwog
    iwog Linux cursed
    14 Jun 2007
    Thats awesome, i assume we'll be getting a youtube of the opening and closing?
  17. Boddaker
    30 Nov 2006
    lol great word!
    Actually, this case uses flush rivets almost exclusively! :p
    Most definitely! :D
  18. Mother-Goose
    22 Jul 2004
    HOLY CRAP that's cool!!!!
    awesome for some extra ventilation, very impressive!
    Do tthe doors return to their closed position easily (just by reversin the motor)?
  19. InferiorPlanets
    22 Jan 2008
    :D More originals coming once I see the blast doors in action! :hehe:
  20. MikeK
    MikeK What's a Dremel?
    6 Feb 2005
    I´m not a Battlestar Galactica, but I think I´m a fan of your Battlestar Galactica mod!!
    Great work!
