Case Mod - In Progress Battlestar Galactica Mod: Complete!
Discussion in 'Project Logs' started by Boddaker, 27 Mar 2007.
  1. Frido
    Frido Minimodder
    19 Apr 2007
    That wasn't so hard, was it? :D
    /Frido
  2. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Ok, finally another update! I know it's not as frequent as I promised before, but at least it hasn't been
    2 months like last time! Anyways, I'm slowly making progress on this blast door, creeping ever closer to
    a fully functional system.
    I wanted to show you how I made the pivot point for the smaller spool. Here is a shot of the piece I added
    above the spool that has a screw in the center. It's just a small piece of 1/8" aluminum riveted in place and tapped.
    Here's a shot from below looking up.
    A shot from below, with the spool disconnected from the pivot screw. I removed the threads off end of the
    screw so it wouldn't screw into the top of the spool. You can also see that huge factory-made hole to the left
    which was why I had to add that extra piece of aluminum over it.
    And here's the top view of the spool showing the center hole where the screw sits. To remove the spool,
    I simply unscrew the set screw and lift it out. :)
    Ok, so with the smaller spool in place I added the clear film. Got this sheet from my local drafting
    supply store. It's 5mils thick.
    Taped one end to the blast door, and the other I wrapped around the small spool. Sorry for the pics,
    but it is quite difficult to photograph things that are completely transparent!
    This shows the blast door open with the acetate stretching across the window opening.
    I opened the door a bit wider so you could see the extra pieces I added on the left for the door to glide on.
    Next, I got the limit switches mounted. They "limit" the movement of the door by cutting power to the servos
    once the door reaches a set position. This one will stop the door after it has closed fully.
    And this one will stop the door once it has opened fully. I extended the leading edge of the door with some
    styrene, which will serve to trip the limit switches.
    Now all that's left is mounting the controller board, and a bit of wiring and it will be ready to rock. :D Video is definitely
    forthcoming, hopefully by this weekend if all goes well.
    8)
  3. The boy 4rm oz
    10 Apr 2008
    Can't wait to see a vid of this all working. Fantastic work mate, keep it up.
  4. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    awesome, as always
  5. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Another superb update (even if small).:thumb:
    Where's my movie dammit! [/rant]:D
  6. Elio
    Elio What's a Dremel?
    4 Oct 2007
    You see told you i'll have to wait...Damn...
    well at least it's worth the wait ;)
    realy cant wait to the video you mantioned...:clap:
    keep up the remarkble work!!!
  7. Boddaker
    30 Nov 2006
    Slight delay on getting that video of the blast door. Ran into some issues and couldn't get the two servos to play nice together no matter how I wired them.
    So I am looking into a USB controller that I can program via a windows interface. Hopefully then I will be able to program the sequence and adjust the speeds more accurately.
    So while I am waiting on that, I decided to focus my attention on another part of the case, more specifically, the other side panel behind the motherboard tray.
    This is a welcome change of pace, as I was getting totally bogged down and frustrated. Now I get to actually make some progress!
    I thought I had more pics than this, but I dont. So it will have to suffice for now. Call it a teaser shot lol!
    I made up a cardboard template for the other side panel's opening, so I could place the 10" LCD screen along with
    the larger BSG lettering I had cut way back when I did the small lettering for the front. (thanks again to Moddersmart.com)
    I got something special planned for the lettering, but you'll have to wait to see what that is. :naughty:
  8. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I'm not sure why you aren't going for steel cable such as guitar cable re-inforced doors, with single servo per door operation, which eliminates buckling & all syncronization issues & no clear film required. So that when the door is open, the case is actually open, no flexible window there. Is it because maybe you'd have to make the doors again? It's not possible to attach the cable to the top & bottom of the existing doors? You know, since you have four spools & servos hooked up, you could make twin opening single servo driven doors per side :naughty: Sorry for being a total pita about it btw, just trying to help :thumb: That's what happens when you make a mod this good, you get people like me bugging you over it :D
    I can't imagine what you have planned for the lettering, you always amaze us with your ideas!
  9. Boddaker
    30 Nov 2006
    Well, if this doesn't work with the new controller, I'll be trying out your cable idea! Its just that I don't have much room for cables on the inside that would be required with the use of pulleys.
    And please, by all means keep posting other ideas! Just because I say I'm doing it one way, doesn't mean it will actually work! lol Then I will have a multitude of options to try if/when my original plan falls completely to pieces. That's the beauty of these forums. :)
  10. mvagusta
    24 Dec 2006
    You mention having to use pulleys for the cable but what i'm thinking of doesn't need any pulleys. The doors are driven by the one spool only, and the cable is simply lining the top & bottom edges of the doors. The only purpose the cable serves is to make the doors a little less flexible - still flexible enough to easily wrap around the spools, but not flexible enough to kink.
    Fitting this isn't simple i guess, you'd probably end up having to make new doors to get this cable fitted along the centre of the door edges, and if you were going to remake the doors, then you could probably just make them using slightly thicker plastic so it won't buckle, eliminating the need for cables!
    Another reason to re-make the doors is so that you have twin-doors on each side, so the current 4 servo & spools, are each opening and closing one door each, and all four of these doors would be about half the length. Maybe this isn't what you want, but i think having 4 doors instead of 2 would look very cool! and you've already made 4 spool & servo mechanisms.... it's a sign!
    And maybe the ends of the doors could have a full length "finger joint" style of mating area, say 1 or 2mm, so that when the doors are closed there is a bit of overlap. This is as good as clearance, making it easier to align the posistion of the switches that tell the servos to stop. I'm probably talking too much now, so i think i'll just get back to work now :D
  11. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I like mvagusta's ideas, they are completely different to everyone elses lol
    It's good work bod, I'd almost forgotten about the 10" on the side, that should be looking great when it's done :) As for that lettering, I feel some sort of back lighting coming on I really do.
  12. Frido
    Frido Minimodder
    19 Apr 2007
    Might the letters be background-lighted up? :) Or just floating in mid-air? (Sorry, can't let that idea go unnoticed, right?)
    /Frido
  13. Boddaker
    30 Nov 2006
    hmm, you guys are very close, as it does have something to do with lighting...... ;)
  14. mvagusta
    24 Dec 2006
    Holographic :confused: It wouldn't surprise me that much you know...
  15. Boddaker
    30 Nov 2006
    Ooohh, holograms! Now THERE'S an idea! :D
  16. mvagusta
    24 Dec 2006
    lolol i'm not gonna shutup until he makes it float :hehe:
    you know, there's another idea.... i'm imagining 4 high torque servos in each corner, each driving a black steel pin down through the base of the case, lifting it say 1 inch, and say 4 or more nice amounts of lighting projected down & outwards, which sort of look like rocket launchers and also contribute to hiding the black pins. Don't blame me for this idea, a few people have asked for it to be able to float or fly, so it's thier fault :D
  17. Mother-Goose
    22 Jul 2004
    Whilst you're at it bod, can you fashion some kinda of working ftl drive for it too? Usefull for when it blue screens, it'll move around the room so you can't hit it and destroy all that work.
  18. Boddaker
    30 Nov 2006
    So while I'm waiting for things, I thought I would delve back into my windowed slot loading dvd drive,
    and see if I could fix it. If you remember, the disc wouldn't fully load into the drive. It would go in and try to
    mount, but would just spit back out. I pretty much knew what I had done wrong, that I hadn't gotten the
    center ring positioned correctly. So after taking the drive cover off again, I carefully unstuck it off the acrylic window.
    Then I removed the cover off my spare drive and proceeded to take more precise measurements.
    Here is a shot of both covers side by side:
    Once I got the measurements, I transferred them to the window and re-glued the center ring back down.
    After ample drying time, I powered the drive up and loaded a disc in. This time it took the disc all the way, but
    didn't quite seat it onto the hub. As a consequence, it spit the disc back out. After a few more tries, I figured
    out that with just a slight bit of downward pressure on the window, it will seat. The center ring is merely there
    for the drive's actuating arm to press against momentarily in order to seat the disc onto the spinning hub.
    Here it is spinning away!
    And here's a shot with the disc ejected.
    So all I have to do is apply a little bit of pressure on the window for it to work. I will accomplish this by adding
    a small acrylic washer in between the medallion and the window, so when i secure the medallion down, it will apply
    that pressure and should solve the problem.
    :cooldude:
  19. mvagusta
    24 Dec 2006
    Awesome :clap: So what did you think of the hover illusion idea? :naughty:
  20. The boy 4rm oz
    10 Apr 2008
    Can't wait to see how this CD drive turns out.
