bit-tech 2017 refresh feedback: Bugs and errors
Discussion in 'Feedback & Suggestions' started by Dogbert666, 27 Jun 2017.
  1. GeorgeK
    18 Sep 2010
    Cheesecake
    By the way cheesecake isn't spelled Cheesecake
  2. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Hi guys, surprised this hasn't been raised, so concerned its my setup; but none of the links to articles in the Article Discussion section work for me...
    When clicking on the links I get the following (example):
    http:////www.bit-tech.net/news/rebellion-announces-evil-genius-2/1/
    Notice the 4 slashes
    and http not https - but that doesn't break it.
    Using IE11 (please don't kill me - its not a choice, and I cant check on anything else)
  3. Gareth Halfacree
    4 Dec 2007
    What happens if you click on the following link?
    If the answer is "it's broken," then IE is apparently incorrectly handling protocol-relative URIs. An http://example.com link will connect you to example.com via HTTP; an https://example.com link will connect you to example.com via HTTPS; a //example.com link will connect you to example.com via whatever connection type you are currently using. So, if you're on HTTP you're connected via HTTP; HTTPS, you're connected via HTTPS.
    All browsers should be able to handle protocol-relative URIs: it's RFC3986. That said, if bit-tech is redirecting all traffic to HTTPS anyway there's no real reason not to use https://example.com instead of //example.com.
  4. wolfticket
    19 Apr 2008
    IE11, Firefox, Chrome and Edge all handle those links okay here.
  5. MadGinga
    19 Mar 2009
    Clicking on that link results in an 'address not valid' error page.
    If I remove two of the four slashes, and refresh/reload it works fine.
    The http/https comment was just an off-hand remark that it was odd to be redirected to http when originaly browsing in https.
  6. Gareth Halfacree
    4 Dec 2007
    Then your work proxy is breaking stuff, 'cos the whole point of protocol-relative URIs is to make sure you never get directed away from the protocol you're currently using. Wolf's confirmed that IE11 handles the URIs fine, so you need to be asking IT exactly what they're doing and pointing 'em to RFC3986 to get 'em to stop.
  7. MadGinga
    19 Mar 2009
    Awesome o_O I'll add to the rather long list of really poor implementation that they ignore.
    EDIT: My bet would be if I bring to their attention, their solution will be to block access to Bit-Tech.
  8. Assassin8or
    Assassin8or Minimodder
    24 Apr 2009
    I'm afraid that it's probably the former
    In the past, when IE8 and 9 were released, I found that broken layouts in browsers were always down to bugs in sloppy HTML markup, CSS and JS, not the browsers (JS always being the worst culprit as those developers seemed to think that they were DOM gods, that the rules didn't apply to them and that they could fix everything with yet more JS.)
    Firefox and IE get bad press these days for rendering layout honestly, whereas the likes of Chrome and Edge hide the mistakes by educated guesswork. I prefer the former approach to the latter, I prefer people to know that they're not doing a good job so that they can learn from the process.
  9. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Issue has been fixed and it was actually down to IE not supporting a CSS rule that all other browsers support so ¯\_(ツ)_/¯
  10. Assassin8or
    24 Apr 2009
    I guess as IE gets older this will happen. Do you know if the feature you are using is actually a released feature, or if it's in a recommended state but it hasn't been signed off yet (however most browsers have support for it)?
    I mention this because of its not finalised and signed off you're essentially using beta implementations of the spec and YMMV in terms of browser support and specific implementation, which can lead to horrible differences in rendering.
    It's always best to check the
    https://caniuse.com/ website before using new features; to check browser compatibility.
  11. MLyons
    3 Mar 2017
    https://caniuse.com/#search=inherit
  12. Assassin8or
    24 Apr 2009
    JS eh. http://kangax.github.io/compat-table/es6/ Even Edge doesn't support all the features of ES6 yet :D
    As with all things on the web, you have to look at your own visitor stats and make a decision on whether to use a technology based on what proportion of your visitors you're willing not to support; if the technology is not fully supported.
  13. MLyons
    3 Mar 2017
    The only people that use IE are people who go on bit-tech at work and are forced to use IE by their bad policies. I got a fix out fairly quickly to my knowledge nothing else is broken on IE. If it is broke then we get so few visitors on IE that non of them have reported it.
  14. MLyons
    3 Mar 2017
    Been bamboozled. Fixed
  15. David
    7 Apr 2009
    Um, is the alert system borked?
    I'm getting emails abut replies to subscribed threads, despite having email alerts switched off in my preferences. :lol:
  16. MLyons
    3 Mar 2017
    Not to my knowledge. Please almighty gaben don't let it be so.
  17. Xlog
    Xlog Minimodder
    16 Dec 2006
    Dunno if its an error or a feature, but banned members are not show as such and going to their profile shows "This user's profile is not available." error page.
  18. Xir
    Xir Modder
    26 Apr 2006
    The Forum does a sort of "soft Scrolling" where is slows down when you stop Scrolling.
    All the time it moves the text is not sharp.
    Also, in the articles, the slightly Grey font makes the text "blurry"
  19. adidan
    25 Mar 2009
    Was looking at mod of the month, related articles mini-mods-making-simple-cable-clamps is borked 404 styley.
  20. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    hmmm, that is interesting as that will be 404 as I haven't finished writing it yet and it shouldn't be visible at all, not sure why it has chosen that article :/ . Thanks for letting us know @MLyons can you pass this on to the team please <3
