Modding blue ring lit power button? who posted about one
Discussion in 'Modding' started by Seth, 6 Aug 2002.
  1. Cheese
    Cheese Doc
    6 Oct 2001
    You can get really large drill bits... that's the neatest way ;) The rim around the switch will hide any rough edges though so you might get away with dremeling - I wouldn't like to do it though :)
    r.
  2. Risky
    Risky Modder
    10 Sep 2001
    Problen is that there's nothing to centre the drill on give the 156mm hole there already. Only way I can see is to grind it out. I don't even know if I have the dremel bits for to remove 0.333cmsq of metal twice.
  3. Cheese
    Cheese Doc
    6 Oct 2001
    This is what I used to do a similar job recently,
    25mm holesaw thingie-majig :) Works a treat,
    Rob.
  4. Risky
    Risky Modder
    10 Sep 2001
    Thanks, looks just right. I'll have a hunt for one.
  5. Seth
    Seth What's a Dremel?
    14 Mar 2002
    what did that have to do with my origional post?
    unless it was for cutting holes in your case for buttons.:idea:
  6. Risky
    Risky Modder
    10 Sep 2001
    Exactly, the Bulgin needs a 18.2mm cutout.
    We may be off-(initial)topic butits been kinda incremental:)
  7. Cheese
    Cheese Doc
    6 Oct 2001
    It was :) We're still on topic ;)
    r.
  8. Risky
    Risky Modder
    10 Sep 2001
    can find yet. Screfix have this: http://www.screwfix.com/shop_products.html?1184
    but it diesn't say if that works for metal.
  9. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    I think that'll only work on plastics and GRP. I've only ever seen one used on TV, and they used it to enlarge some holes in a plastic container.
  10. Risky
    Risky Modder
    10 Sep 2001
  11. GreatOldOne
    29 Jan 2002
    Looks like it!
    If you've got a steel case, it should manage it (It's for sheet steel if you read the decription), and if you've got aluminum, you're laughing, as it's nice and soft to cut (I've cut holes in it with woodworking spadebits!)
  12. macroman
    macroman The One
    3 Sep 2001
  13. firewars
    firewars What's a Dremel?
    14 Oct 2001
    Is it me or is the site gone? .. :eyebrow:
  14. Cheese
    Cheese Doc
    6 Oct 2001
    It isn't you :)
    r.
  15. firewars
    14 Oct 2001
    Too bad, I really wanted a blue one :(
  16. linear
    linear Minimodder
    5 Oct 2001
    For everyone's reference:
    http://forums.bit-tech.net/showthread.php?s=&threadid=13141#post132083
  17. linear
    linear Minimodder
    5 Oct 2001
    I can't. Most of the words are censored.
    Honestly, how short do you think people's memory is?
  18. Seth
    14 Mar 2002
    like linear I can not tell you how I feel, in short for the things I would say I would be banned, much like you were before.
    anyway.
    I find it insulting that you would believe that our memories are that short.
    If we can remember how to build a computer we sure as hell are not going to forget you.
    I personally don't find you very welcome here, but it is not my site. However this is my thread. So please, don't post in it.
    oh and the so called tools that he uses to take the buttons appart can be bought at your local tool store. (But he said he has special tools to take appart the buttons..) yes what makes these special is that they are in his hands not yours which makes him money.. but not from here..
    Seth.
  19. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    I had a sealed connector one time that some ****wit ripped the wires out of.
    The manufacturer wanted 700$US to fix it. Standard fee. Every return is completly refurbed. Even if all I wanted was to fix a wire.
    I asked to speak to a tech. Techs are almost always helpful. He said to break it apart you need a special tool that is built by the connector maker. They only sell you one if you buy connectors from them and the tool is 300$US.
    I said, I'm not paying that.
    He told me what they use, and sent me the parts to make the breaking tool.
    All it was: The female portion of the connection soldered to a nut driver.
    Totally unrelated, I just trot that out when I hear "Special tools"
  20. Seth
    14 Mar 2002
    word to that..
    prolly what that guy uses.
