Guide Blueprints Collection
Discussion in 'Modding' started by Djayness, 13 Oct 2009.
  1. Andersen1337
    Andersen1337 What's a Dremel?
    10 Apr 2009
    Well, Cinema 4D takes all those formats except .max, and 3D Studio Max takes all of those formats except .c4d ofc. As for .dxf and .obj, they're supported by all 3D design softwares.
    A good thing with Cinema 4D is also that you can export the files to 3D Studio Max, or make a .dae-file (Collada) which can be opened by Sketchup. When exporting from Sketchup you simply export for Collada aswell, and make a .dae-file which can be opened by Cinema 4D, not sure about 3D Studio Max.
    But all in all, it should be a very efficient loop.
  2. Guest-23315
    Guest-23315 Guest
    I've got a load of stuff like the below which I did a few years ago when I was designing Watery. These are a standard 120mm fan and then the standard 15mm fan spacings for single to quad rads.
    This the sort of stuff youre after?
  3. motas
    motas What's a Dremel?
    7 Dec 2009
    So I finished my 3.5" bay and have contacted jezmck to submit it. Will also do some rad mounts while im here and I think djayness has some 5.25" bays I saw. Hopefully spark some interest in this because it would be a great idea to be able to design a whole case without the effort of reverse engineering each mounting.
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  5. voras
    voras What's a Dremel?
    11 May 2011
    I'm interested in your dxf file, I'm trying to do my own case for a matx 245x245 mm, and with your file i would have to do a little modifications:clap:
  6. voras
    11 May 2011
  7. Blackbriar
    Blackbriar What's a Dremel?
    5 Nov 2010
    Hi guys
    i need a accurate model of a Lian Li Q11, because i want to build a watercooled cube.
    i can´t build it in 3D, because i have no programs for this.
    if anyone there can help?
    Thanks a lot =)
    best regards
  8. markpg28
    markpg28 What's a Dremel?
    22 Dec 2007
    360 radiator template
    Hi I have a CNC router & want to cut out a triple rad mount on top of a lian li pc A77, its a feser xchanger with 17mm soacing but I can cut the holes on a pillar drill., anybody have a cdr, dxf, etc template I coule use, I am not very proficcient with the drawing yet.
    Thanx
  9. markpg28
    22 Dec 2007
    Hi I have a CNC router & want to cut out a triple rad mount on top of a lian li pc A77, its a feser xchanger with 17mm spacing, but I can cut the holes on a pillar drill, anybody have a cdr, dxf etc template I coule use, I am not very proficient with the drawing aoftware yet.
    Thanx
  10. markpg28
    22 Dec 2007
    double post
    sorry for dpuble post, I cant seem to delete one
