Case Mod - In Progress Commodore P.E.T. 2011 - Problems!
Discussion in 'Project Logs' started by TheGreatSatan, 16 Mar 2011.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    This is a dream come true
    Ever since I first saw a Commodore PET on eBay, I have wanted one. The only thing that has stopped me is MONEY.
    Usually only working Commodore PET's come up for sale and then sell for an easy $200 to $300.
    THIS TIME I GOT LUCKY!
    I finally found a non-working one for just $53!!
    Here are the new specs:
    AMD Phenom X6 1090T
    MSI 870A-G54
    MSI R6850 Cyclone
    16GB DDR3-1333
    64GB SSD
    640GB WD Black
    650 Watt XFX PSU
    Slim DVD
    Here's the best part, looking inside
    I guess that's me
    This slot is already here
    Ahhh Yes! Perfect!
    I opened the back of the CRT to remove it
    The inside is stamped June 20, 1980
    Now it's empty
  2. TheGreatSatan
    5 Aug 2005
    I really need a motherboard tray and backplate, so I'll cannibalize this Antec three hundred
    Like this:
    I'll be needing a USB hub and headphone jack
    And the power button too
    It dawned on me that I'll have to have the back appear like any modern PC if I want it all to fit in. It's in the back so no one will see it anyway.
    I'll obviously still have to clean it up
    At the start I realized a few of the parts I wanted all had 6's in them, so in keeping with the 6's:
    6 cores
    6 gigs
    650 watts
    64GB
    640GB (6Gbps)
    6850
    870A-G54: This part was actually unintentional, but really funny. (8+7+5+4=24, 2+4=6)
  3. TheGreatSatan
    5 Aug 2005
    I got my processor and board
    And I'm modifying my Big Shuriken heatsink
    With this awesome 3000rpm beast of a fan
    Like this
    In a mock up, it appears that my RAM will still fit fine
    With the lid closed there's still about three inches of clearance
    I bought the MSI Radeon 6850 1GB because the PCB doesn't have an overly large heatshield
    Here it is in my dead board
    And the lid closesd just fine! :banana:
    The best part is having the power connection on the top of the card
  4. TheGreatSatan
    5 Aug 2005
    One thing I had to do was clean the 20 years of filth out of the inside and then riveting the motherboard tray to the frame
    Now on to the power supply
    The only place I have room for this is where the monitor used to be
    But first, I'll have to measure out a place to cut the back of the vent. I want to retain as much of the old backplate as I can
    I'll also be thinking of a clean way to add some much needed 21st century ports
    To here:
    I cleaned up the back edges and painted it all black just as it originally came
    I'm not going to have any pretty lights inside the case either so drowning out all the color is important too
    I added the AMD 1090T and the 6GB of RAM to the board
    And then I secured the 64GB Micro Center SSD and the 640GB Western Digital hard drive to the drive cage
    The only place where I'll have room for the drive cage is here in the monitor next to the Power Supply
    On to the monitor backplane. I sanded off the rust and then covered the "High Voltage" sticker. This is one of those original pieces I want to preserve
    Then I added a thick coat of flat black paint. This will make it match the IO back panel and tie the whole rear together
    Once it dried I peeled off the protective tape
    This is how it looks before I cut out the PSU spot
    My 7-inch Kodak Pulse digital photo frame arrived. I'm using it in the place of a LCD screen. I'd rather have it play images of the build or even Commodore wallpaper instead of a little screen I really can't use anyway
    There is just a slight gap around the edges that I will fill later
  5. TheGreatSatan
    5 Aug 2005
    I've been costing out this project and this is how it looks thus far:
    Proc...................$200
    Mobo..................$65
    RAM...................$72
    Video.................$190
    SSD...................$100
    HD.....................$70
    PSU....................$95
    Frame.................$80
    Ext DVD.............Already had it
    Card reader.........$16
    2.5 to 3.5............$12
    Pwr Button..........$3
    Heatsink/fan........$55
    Windows 7 Pro.....$40!!
    Total: $998
    These prices are face value and do not account for taxes/shipping fees
  6. TheGreatSatan
    5 Aug 2005
    I got my Silverstone 3.5 inch bay today
    Tonight I'll cut out an area right here for it
    I got this USB 3.0 extension cable that I'll be adding next to the Power button
    For the 3.0 cable I'll route it under the motherboard tray
    And out the other side. I'll run the cable outside the back and plug it into the motherboard, just like they do for most 3.0 cases these days
    I'm also getting rid of these slot covers
    And replacing them with something a little better for ventilation
    The open slots will be occupied by the video card and a USB 2.0 PCI card
  7. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    *Flash back* I had that dread sensation when I saw the title .. School... When the PET's arrived, then were promptly nicked that weekend.
    Excellent Mod crack on .. :dremel:
  8. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Im pretty sure its 30 YEARS not 20 years of filth. I was born in 1980 so i should know its 30 years :waah::waah:
    great build by the way brings back memories :thumb:
  9. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I know it's a small thing, but why, when you're investing so much time, money, effort to this project, did the masking off of this sticker went all wobbly?
    I think it's the attention to detail which can really make or break any project.
    And don't get me started about the use of a digi-frame for the screen! The next thing you'll be telling us you're not wiring up the keyboard to work!
  10. KidMod-Southpaw
    28 Sep 2010
    WOW I've never seen such a thing! That's bloody awesome.
  11. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    OUCH! You set him straight.
    JK Though awesome project. I too hope that you wire that keyboard up to work.
  12. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I spent ages at my friends house on his dads PET, that brings back memories.
  13. TheGreatSatan
    5 Aug 2005
    I'm absolutely not wiring the keyboard to work. It will stay for aesthetics only. There are way too many keys on there that don't mean anything for modern systems.
    And I'm not set on the frame just yet. I do have a 7 inch screen laying around
  14. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Shame IMO, I think you'll find the PET keyboard has less keys than a modern keyboard, not more. A bit of re-mapping, even some relabelling...
  15. TheGreatSatan
    5 Aug 2005
    It's time to mount my media bay
    And I'll definitely I need some Quicksteel
    Now to look at the USB 3.0 port
    I really need a fan in the back, so I move the High Voltage sticker
    And carefully line up my hole saw
    And that's what 80mm looks like
    I'm still not sure about the grill though
  16. TheGreatSatan
    5 Aug 2005
    I thought it would be a good idea to test the system so I'd know to return something before I was ready to install it
    My processor and RAM are showing up OK
    And my fan is going near 2800rpms. The amount of air I can feel around the base of the board is tremendous. The nearby RAM and Northbridge are getting a lot of cool air from out of the bottom of the heatsink
  17. Cheapskate
    13 May 2007
    That fan is a monster!:lol: I'm not sure I'd want one of those again. My C64 'portable' was a friggen back breaker.
    Lots of room for an optical drive in the top.:D
  18. TheGreatSatan
    5 Aug 2005
    I'll be using a slim external DVD drive, internally.....
  19. sinner666999
    sinner666999 What's a Dremel?
    3 Jan 2011
    Nice build! Shame your not putting a real montior in it, usefullness aside, nor attempting to use the original keyboard or mount a modern one in its place. Personally, I think both of those are things that would put it a step above modding it to accomadate a modern PC.
    But thats just my $0.02 and its a nice build regardless.
  20. TheGreatSatan
    5 Aug 2005
    Using the keyboard seems pointless because I would not want to use it anyway. The height and angle of the keyboard would wear me out using it. Plus, the system will be pushed back against the wall on my desk and the keyboard will be out of reach
    The monitor I'm still on the fence. I actually do have a 7 inch LCD that I can integrate, but I'm just not sure about the resolution and how useable it will actually be. I would probably connect an internal USB to VGA adapter for the mnonitor. That way no cables would have to run outside to connect to the DVI to VGA input.
