Scratch Build – Complete Cygnus X1.
Discussion in 'Project Logs' started by Attila, 18 Sep 2008.
  1. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    That looks so damn good with the clear coat on. Either my morning coffee hasn't kicked in or my eyes are just not working, but I am seeing nothing but fantastic craftsmanship....but that may be because I want to see the end result about as much as I would like to spend a weekend with Megan Fox, Kate Beckinsale, Jessica Alba and Jessica Biel......
  2. The boy 4rm oz
    10 Apr 2008
    The wood looks sssssssssssoooooooooooooo good with the clear on, very nice finish.
  3. skreenname
    skreenname SFF Forever
    11 Jun 2009
    This just keeps getting better and better.
  4. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Yay! Update! :clap:
    Man, that wood looks fantastic after the first 4 coats (esp the one on the right!). I see no irregularities or problems with that at all. Personally, I think you could mount the side panel on the wall and people would love it!
    Sexy curves!
    So am I to believe that you are mounting hinges and panel soon?
  5. tuberc
    tuberc What's a Dremel?
    16 Dec 2008
    Bring back memories of the woodwork classes in school, of course we threw pieces of wood at each other instead of making nice things like you are doing.....
  6. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Oh wow... This is looking better and better everyday!
  7. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Woah! You almost snuck this one past me, posting in the middle of the night here! You're a sneaky one...
    That is flippin' gorgeous, sir!
  8. MikeK
    MikeK What's a Dremel?
    6 Feb 2005
    It looks amazing! Just like the rest of your fantastic build. I must sya you have good skills in working with wood!
    Good luck with the rest of the build!
  9. bagman
    bagman Minimodder
    18 Apr 2009
    thats unfortunate with the blemishs but you still have done a fantastic work with the wooden side panels
  10. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Looks great! I like using a sanding sealer to highlight "issues" before moving on to final finishes.
    Personally, I like knots and "blemishes" in a wood. It adds character and proves it's not fake. :thumb:
  11. Cheapskate
    13 May 2007
    The clear really brought the contrast out. I would be tempted to add extra clear to the knots and fill them completely in. The only knot that bothered me was the one on the corner, but the rounding fixed it.:thumb: It's placement and size made it look more like an scar from dropping.
    There's a face and top panel that need to be made now, right?:D
  12. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    OMG woah. best ever
  13. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    i broked my jaw. :jawdrop:
  14. Attila
    Attila still thinking....
    22 Feb 2008
    :) Thanks a lot everyone!
    Only one coat so far MM, and yep the hinges are next.
    Indeed. Some people consider these features unfortunate but like you, I like em.
    Yes the reason for so many coats of clear is to fill in the grain, so the feature on the top front
    should be mostly filled when all the painting is done.
    Yes there will be a multi-segment panel across the top and front that will be hinged in three
    places.
    Here are some pics to show how the side panels look with the chassis.
    Just a few points with these pics: You will see many runs and blobs of clear, this is OK, it's
    just the first coat and I slop it on heavy.
    The panels are sitting on the same surface as the chassis but they will be raised about 4mm
    when mounted.
    You wont actually see the contrast between the side panels and chassis when complete, except at the back.
    The shape will change as I need to cut away some material at the top rear on both sides so
    the panels can open without fouling the top.
    The strong grain on the right side makes the bulge at the front look really weird. :worried:
    I've decided to leave these at one coat until after they are mounted and all the other
    stuff is made. I just know I'm going to slip with a driver or drop something on them, so
    better to leave the finishing till last.
    Back soon with hinges.
  15. The boy 4rm oz
    10 Apr 2008
    The rich dark colour of the wood goes perfectly with the powdercoated chassis, you certainly did your research my friend, and it paid off ;). Simply stunning :D.
  16. Cheapskate
    13 May 2007
    MOTY for sure this time.:D Be sure to finish up this year. I don't ever want to compete against you.:hehe: (pretty arrogant sounding, aren't I?:D)
  17. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I don't wanna compete with you either.
    You completely blow me away.
    It was hard enough to compete with you for MOTM, when nobody's finished.
  18. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Simply freaking amazing... Like the The boy 4rm oz said, the contrast between the powdercoated aluminum and wood is stunning. Two materials so opposite, look so perfect together.
  19. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    This is my dreamcase now! These two materials are awesome with together!!
  20. Reverse
    25 Sep 2008
    This is the best custom-case-build i have seen. EVER!
    Mod of the year for sure!
