Bits First Look: Windows 7 Beta Performance
Discussion in 'Article Discussion' started by Tim S, 16 Jan 2009.
  1. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I can see where kusar is coming from, neither vista nor 7 offer much to make me want to upgrade (over 2K), however much as i was dragged kicking from win2k it is inevitable i will have to leave xp behind however if can put this off as long as possible, fine, so while win7 may just be a version of vista i still don't mind too much since i'll have saved at least one upgrade stage and probably £80.
    Besides they seem to be stealing more and more from linux and os x maybe they'll have a decent wm sometime soon.
  2. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    I see your point, Wuyanxu. The reason why I want to skip Vista and get #7 instead is that Vista might get discontinued(support) a bit sooner than #7(even though it's "modified" vista, you know - marketing reasons). And #7 will be here soon enough. I'll get used to it eventually...
    And BT recommendation is enough to convince me Vista isn't as bad as people say :)
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Vista support won't be discontinued for a long, long time. Windows 2k is still in the Extended Support period and will officially be supported until somewhen in 2010. So Vista will most likely be supported until 2016, 2017. No need to worry there. ;)
    And about the stealing from OSX/Linux: They've always stolen ideas. Every OS is basically a rip-off of another one [at least partially]. It's all about making it the best/most secure/most comfortable choice for customers. If they see something good, chances are they'll implement in their next release. But it's not only MS who do that.
  4. psychoti
    psychoti What's a Dremel?
    6 Mar 2008
    do you think that it will be alright if i install windows 7 to my amd 64 4000+ ?
    :D
  5. RobertJG
    RobertJG What's a Dremel?
    21 Jan 2009
    People complain about the aero interface being "fluff" and a waste of resources.
    Other people review vista and 7 and defend aero or agree that it's a waste.
    How come NONE of the people who spend all that time playing the both OS's TOTALLY FAIL to mention that it's a simple matter to turn all that fluff OFF????????????
    These are (probably) intelligent people who most likely are well aware of this fact, but chose to ignore it.
    Is there some reason none of them want to mention that the "fluff" can be turned off?? This ability has been available since XP.
    Right click on computer, select advanced then performance and uncheck everything except the drop shadows.
    Simple.
  6. perplekks45
    9 May 2004
    It still doesn't look like Win 98. And that seems to be what those people are after. Without all the fluff it just looks like Diet Aero.
    @ psychoti: Errr... why not? I don't get it... :confused:
  7. ArcAngeL
    ArcAngeL What's a Dremel?
    14 Nov 2006
    They need to make a solution to proxy settings on multuple networks. I'm sick of staff comming to me unable to connect their laptop to the internet at home or at work cause they have their bloody proxy settings set wrong. Sure I can make scripts and stuff for them to run to fix this, but I shouldn't have to, it sounds like they have already made this adjustment for network printing.
    That and the drop down menu to see parent folders when file save as'ing, when they removed that it was very uncool.
  8. ashchap
    ashchap Minimodder
    28 Feb 2005
    Am I the only one who in general found vista faster than XP and win7 slower than vista?
    I think it's probably because it's in beta but occasionally I get a slowdown in windows 7 and explorer (not internet explorer) often seems preoccupied when I want to do stuff...
  9. GoodBytes
    20 Jan 2007
    Vista is faster than XP thanks to a working Prefetch technology, and Superfetch. Also dropping old technologies and making the OS asynchronously rather than synchronously makes Vista faster and more responsive. You are not the only one to see this.
    Windows 7 might be slower because the lack of official, and especially optimized drivers. Microsoft did modifications to the drivers sections in Windows 7, enough to have this effect but not enough to prevent Vista drivers from working. Another effect that you see, is the same as if you would re-install Vista, as the OS still learns what you do with the system (i.e: Superfetch learns what program you run often and at what time, and preloads it before you do.)
    Look at the Windows Experience Index and compare it form the one in Vista. On my laptop my HDD under Vista 64-bit is 5.3 but under Windows 7
    it's 2.9.
    Oh and I almost forgot, under Windows 7, the system is probably indexing your HDD.
  10. crispy
    crispy What's a Dremel?
    29 Aug 2008
    I spent the weekend testing Windows 7 64bit.
    It boots significantly faster than Vista.
    Like Vista, the compatibility mode worked flawlessly.
    It was very stable
    I was able to use Vista drivers when needed.
  11. perplekks45
    9 May 2004
    I think you just summed up a lot of people's experience so far. Well done, crispy! :thumb:
  12. m0o0oeh
    m0o0oeh Modder
    20 Dec 2006
    Is it still possible to get in on the 7 beta bandwagon?
  13. Guest-16
    Guest-16 Guest
    RC1 is due in a month or two..
  14. perplekks45
    9 May 2004
    There are loads of torrents over on the usual sites. And as beta keys are not unique it shouldn't be too hard to grab one.
    [HINT] PM me. [/HINT] ;)
  15. dumde
    dumde What's a Dremel?
    28 Jan 2009
    I got several BSOD when I tried this....
    Not that impressive either, imo. Why should it be praised if it's what vista SHOULD have been?
    Meh, I'll stick to *nix.
  16. GoodBytes
    20 Jan 2007
    Dude:
    1- It's BETA.
    2- your drivers are at Alpha or Beta stage (or non-existent).
    3- It's still under development (BETA).
    4- Your computer is probably no Vista ready either-way.
  17. Guest-16
    Guest-16 Guest
    *nix fanboy Looking for an excuse tbh :yawn:
  18. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    I only need one thing from Win 7- The recognition that some of us luddites still run CRTs and want to push them out to 100Hz like XP lets us do at the moment. Vista assumes the world has gone TFT and locks the modes down to 85Hz at most. Same hardware, crippled by software unless I get RivaTuner or ATi equivalent to hack it (and that's even when it PnPs the right monitor). If I'm just doing 2D then I do use Vista in a dual-boot now but for DX9 gaming I just leave all that to XP at present.
    Also will want to go 64-Bit with 7 and I don't know if those versions are included in the big pre-order fanfare. If they were, I'd reconsider my waiting for a service pack.
  19. GoodBytes
    20 Jan 2007
    1- You did not install (or doesn't exists) your monitor drivers In my case I can set my monitor (without drivers as it's for XP only) to 150Hz no problem under Vista 64-bit.
    2- If you have an Nvidia graphic card (maybe the same with ATI.. try to look for that), you can force a resolution and refresh rate by creating a custom added resolution. See video card control panel.
    3- Computer LCD TFT goes to 150Hz, and as for TV you have 200+ Hz. Vista has no problem.
    4- You don't need RivaTuner, it's in front of you, at the Nvidia control panel (see side column).
    5- Everything said above applies to Win7.
    6- DirectX 9 and earlier works perfectly with no performance drop under Vista/Win7. You don't need XP unless the game was programed in 16-bit CPU's instead of 32-bit (x86) processors, like the original Pentium. Some games have non-official patches to make them "NT compatible" which is a hacked exe of the game made in 32-bit instead of 16-bit.
  20. knuck
    knuck Hate your face
    25 Jan 2002
    my vista build (7100) is running my LCD at 120hz so I don't see why the RTM wouldn't be able to do it with CRTs ... oh and I was at 100hz on vista back when I had my CRT so I'm not sure why you had this problem
Tags: Add Tags
