How to get the most Folding Points from your Hardware
Discussion in 'bit-tech Folding Team' started by Lizard, 23 Apr 2009.
  1. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Will a 1090T running at 3.9GHz complete bigadv projects?
  2. One_Box
    One_Box Folder of the month April 2012
    11 Jul 2010
    No, you need an 8 thread capable cpu for -bigadv. :(
  3. meandmymouth
    15 Sep 2009
    Well that sucks, oh well
  4. discovertrance.com
    discovertrance.com What's a Dremel?
    3 May 2011
    Thank you Lizard. Each of the servers has 16gb of ram.
  5. discovertrance.com
    3 May 2011
    Thanks Tangster :)
  6. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    With that much RAM I recommend running the bigadv version of the Windows or Linux CPU client (depending on what OS your servers are already running). If you have dual or quad CPU servers in your cluster then you should run a single instance of the client with the following parameters added onto the end of the command line:
    -bigadv -smp x
    where x = the number of physical and logical (Hyper-Threaded) cores in the system.
    To get the most points you'll also need to request a passkey from Stanford and enter this into each client when setting it up. This will after 10 submitted WUs give you a substantial points bonus for every WU you submit back to Stanford before its deadline.
    Good luck and let us know how you get on :thumb:
  7. discovertrance.com
    3 May 2011
    Thanks for taking the time to share this information Lizard.. Will change the run command to match the one you suggest now.
    Will post results later :)
  8. holzj17
    holzj17 What's a Dremel?
    22 Sep 2010
    you could also join our chimps challenge team for a bit :) you would be a huge help. drop coolamasta a pm and he can give you the passkey
  9. discovertrance.com
    3 May 2011
    Hey mate is there any reason to do that?
  10. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Definitely, it's a way of encouraging more people to fold (more) for 10 days once a year as a competition between the top 10 folding teams in the world.
  11. discovertrance.com
    3 May 2011
    ok.. im in :) can someone issue me with a key?
  12. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    On it's way in a PM now :) Thanks for joining in :thumb:
  13. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    I thought this thread might be helpful for one of the new systems I'm building, but it seems outdated even for the old QX9770 I should be receiving in tomorrows mail.
    If it gets updated, I might be worth adding how much better/worse the latest beta is for gpus (I understand that the use of openCL has levelled the playing field for modern AMD/ATI gpus).
  14. ch1nb34rd
    ch1nb34rd What's a Dremel?
    12 Jan 2012
    How many ppd should my 1090T be getting? What parameters should I be using in the SMP client to get the most out of my CPU?
  15. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    For the gpu console can you run with -bigadv too?
  16. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Nope. BIGADV are a CPU work unit.
  17. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Cheers.
    Is there supposed to be a significant advantage to console over systray?
    Switched GPU to console and these are the difference:
    systray: PPD ~16.5K, TPF 1m
    console: PPD ~17K, TPF 4m
    Edit:
    GPU is also running 10deg C higher.
  18. gero1369
    gero1369 Ummm...Wha?
    12 Jan 2012
    No big difference between console and systray clients. I personally prefer console, but to each his own.
  19. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Ahh tnx for that.
    I think the GPU was running hotter as it was a warmer day than usual. lol
    Back to 77Deg C now.
    I'll leave em as console. :)
  20. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    thanks for the tip!... currently doing my first WU on the i7 3930K. might build another rig based on an i7 920.
