Modding How To Make Your Own Watercooling Reservoir
Discussion in 'Article Discussion' started by Sifter3000, 28 Feb 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Jehla
    Jehla Minimodder
    8 Jan 2010
    Brilliant! Been looking for something like this.
  3. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Alas some modding! Great work bit-tech!
  4. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Excellent...well done and very informative
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Very nice, cool tubing trick too
  6. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Do you not have to be carefulabout using metals in a cooling loop? I've read about galvanic erosion or something like that?
    It's to do with having two different metals. Don't know much more about it than that.
  7. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Yes, different metals will cause galvanic corrosion, in which ions move from one metal to the other. It doesn't happen quickly, but it will eventually destroy your waterblocks/fittings/radiator/pump.
    Which is why you should always add a corrosion inhibitor to the coolant (along with an algae killer too).
  8. capnPedro
    11 Apr 2007
    That's why things are nickel plated. It prevents corrosion. A rule of thumb is to use either all copper blocks/rads/etc or all aluminium blocks.
  9. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Or a cheap(er) res - cut up a water bottle. Use the bottle cap as the filler, and use two holes at the side for input and output. I used to use a bottle for pneumatics, so I did find out that blutack is something exceedingly airtight. ;)
  10. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    Now THAT's a cool article!
    Good work!
  11. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    What about those of us who want the ultra large reservoirs that water beds provide?
  12. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Great article, very useful and informative!
    That trick with the tubing is excellent too, I'm definitely going to make use of that in future.
  13. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Love the air pressure and tubing tricks. :thumb:
  14. Alec**
    Alec** What's a Dremel?
    28 Feb 2010
    This article has fantastic timing!! Me and a mate are planning a old Stacker Res-Orection, the clue is in the name that it will feature a large (custom made) Res. Was planning to order the parts tonight and this article has helped (especially with type of plastic) Thanks! Should be posting results in a couple of weeks (might start a thread up on here).
  15. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    now thats cool
    nice job
  16. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    perfect timing! I am currently designing a reservoir for my project and i was wondering about using acrylic cement. I've used it plenty for bonding other projects but was a little worried about using it for a reservoir.
    Also the tubing trick is awesome!
  17. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    I'm absolutely interested in doing this, i have some very specific requirements for the res that's getting a key spot in my next mod. Great stuff man!
  18. talladega
    talladega I'm Squidward
    18 Aug 2007
    Excellent guide! I liked the part about forming the tubing. Very helpful!
  19. Darkraven
    Darkraven What's a Dremel?
    23 Dec 2006
    Well done article, nicely written and good layout. Enjoyed reading it, course the information has tobe just stored on minds back page while waiting to get rich & famous to finally get into water cooling.:D
  20. dslickness
    dslickness What's a Dremel?
    27 Feb 2008
    Thank you so much for posting a Modding Article!! Bit-tech.net used to have so many modding guides (some of the best), and then suddenly they trashed most of the guides.
    Anyway, thanks for the info. I wish I knew more about Extruded Acrylic back then. I will come back to this page for info on tube molding.
Tags: Add Tags
