Bits How to set up Folding@home
Discussion in 'Article Discussion' started by Tim S, 17 Jun 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. PT88
    PT88 What's a Dremel?
    13 Apr 2009
    I know folding@home is for a good cause and all, but is having your PC running full whack all the time not hard on your wallet, lecky style?!
  3. MajorTom
    MajorTom Minimodder
    14 Aug 2008
    I agree with PT88. It's a noble cause but I can't afford to do this.
  4. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Article needs more disclaimer imo, TV style "make sure you have permission from the bill payer"...
  5. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    Although you can look at the text log files each client produces, a better method is to use a third-party application such as [eurl=http://fahmon.net ]FahMon[/eurl]
    i guess there is something wrong
  6. mclean007
    mclean007 Officious Bystander
    22 May 2003
    My house has electric central heating, so I run FAH whenever I'm at home during the winter, as it makes sense to me to be doing something useful with the power before it gets dumped into the room as heat - basically using my PC and PS3 as heaters. In the summer, though, I don't fold - electricity is too expensive; I don't believe in leaving electrical goods on more than necessary; and my place gets hot enough as it is without adding to it!
  7. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Fixed, thanks. Tiny typo...
  8. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    I just turn it on when I'm doing other things. My pc would be on most of the day and I haven't really noticed much of a difference bill-wise using one core for folding and carrying on with email, browsing,etc on the other.
  9. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Frankly excellent article James. I tried setting up F@H a few times, and ran in to so many problems, with fixes hard to find, that I just gave up.
    Everything needed is nice and tidy in this article. Well done.
  10. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    Nice write-up, thanks for the guide. I've now got started with my local PC and two 24/7 servers - configured to contribute to the bit-tech/cpc team of course!.
    That FAHMon tool is pretty sweet too, I was a bit confused by it at first as I was pointing it to the F@H directory and it wasn't picking up the client - but that wasn't where the FAHlog.txt file was. Found it in the C:\Users\%NAME%\AppData\Roaming\Folding@home-x86 (example path is from Windows 7).
  11. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    W00t what a complicated setup! I already set mine up before reading the artical. Turns out I did some things wrong.
    But why is it better to run SMP compared to 2 regular clients? Plz explain.
  12. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    In short - you'll get far more points per day running an SMP client on a dual-core CPU than two standard CPU clients.
  13. pullmyfoot
    pullmyfoot superbacon
    1 Oct 2008
    When you guys all complain of hot summers, you arent thinking of people who live in heat all the time. Here in Singapore a cool day would be 25-27 degrees. Hot will be like >30. Its usually in between.
  14. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Pah! 30C is nothing, when I used to live in Dubai it was regularly 45C+ for a large part of the year. Now that I live in the UK again I can fold more easily (and use the farm to heat my house nicely too :) )
  15. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    small disclaimer (and i might be wrong on this one but this is what i am getting) the smp client for Linux is for x64 only.
  16. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Once I finish Trident, I plan to set up GPU folding on it, as it will have three video cards. However, I only have two monitors at the moment, and F@H requires each video card to have a monitor connected in order for it to recoqnize the card. Could you go over how to "fool" the folding client into thinking that there are more monitors plugged in? Some sort of wiring trick with the DVI port or something. Thanks!
  17. p3n
    31 Jan 2002
    Connect the VGA cable from one of the monitors to the third gfx card? (assuming your 'using' DVI and they have both :p)
  18. zoot2boot
    zoot2boot What's a Dremel?
    9 May 2006
    mmm. i don't see any particularly amazing science coming out of this. just a whole bunch of wasted power messing up the environment... and scant justification for that faster cpu, that new graphics card. bit of a weird obsession imo.
  19. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    Define "amazing science"
  20. uncle_fungus
    27 Mar 2009
    I know this is probably a little late now, and I haven't compared this to the print article in issue 70 either, but there are several misnomers on page 4 of this article.
    First, the -local flag is deprecated and does precisely nothing in the version 6 clients since the registry is no longer used to determine the working directory for the clients. -local is implicit in version 6.
    Second, multiple console clients (of the same type) can be set up in exactly the same way as the system tray clients. You only need 1 executable which is shared by all clients. The "Start in" folder is what determines where the client actually works from.
    Edit: Why can't I delete my own incompetent double-post?
Tags: Add Tags
