Scratch Build – In Progress Hydros Core Copper Reservior
Discussion in 'Project Logs' started by Kewtdz, 12 Mar 2009.
  1. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Thanks for the Info!
    I was able to get into the shop tonight for only a little bit. I got a little bit more done on the base:
    I was able to get the center hole drilled and chamfered.
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    BSPT - British Standard Taper Pipe Thread (tapered threads) [eg: R1/4", R3/8", R1/2", etc]
    BSPP - British Standard Pipe Parallel Thread (straight threads) [eg: G1/4", G3/8", G1/2", etc]
    NPT - National American Pipe Taper (tapered threads)
    NPT is not compatible with G1/4"!
  3. talladega
    talladega I'm Squidward
    18 Aug 2007
    just what I was going to say Langer.
    Cheap, you should know better. :nono:
    As for where to get em. Try McMaster Carr. The tap is $17. It is part number 8328A22
  4. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Well I was asking for a cheaper one. The BSPP taps I found where $35 and I didn't really want to pay THAT much for one. I am going to order one from McMaster today.
    Thanks for the link! You guys rock!:clap:
  5. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Hydros Core Res Update
    Update TIME!
    Sorry for not updating sooner but here is what I have done so far.
    I got the O-ring done for the base and scribed the circle for the bolts before parting the base.
    Also I cleaned up the edges so that way they aren't sharp.
    Also at the end of last week some of the parts I need to start build my case and cooling system arrived.
    Magicool Extreme Slim Profile 4X120mm Radiator
    Danger Den DD-CPX-Pro 12V Pump
    I am using Plug and Cool Fittings from Aquacomputer. I had to order them from Germany :D
    Aquacomputer Cuplex HD
    I also ordered some switches from mnpctech.com and Bill Owen threw in a fan grill!
    I am still trying to figure out exactly where I am going to put the fan grill but it will be in my scratch build.
    Thats it for now. I won't have anything new until next week because I am machining some bushings for a automotive student.
  6. The boy 4rm oz
    10 Apr 2008
    The res is looking really good. WOW, that is a HUGE radiator lol, don't see a 120.4 everyday lol.
  7. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Hydros Core Res Finished!
    I finally finished the Reservoir! Unfortunately I haven't had a camera but here is the finished product:
    Back Bottom
    Front Bottom
    Thats all the pics I have for now. I hope to be able to shoot it again sometime. I am also starting a NB and SB water block which I will post on this thread but I will start a new one for the actual case.
    SkiDave likes this.
  8. stonedsurd
    11 Mar 2009
    That's a great looking res mate!
    You'd give the AquaTube guys a run for their money! :thumb:
  9. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    that looks killer.. good work
  10. The boy 4rm oz
    10 Apr 2008
    That looks amazing, kinda reminds me of a light saber lol.
  11. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Brilliant lathe skills! That is an awesome reservoir.
  12. badje
    badje boni
    30 Oct 2006
    That a sweet res dude. How much fluid can go in there?
  13. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Great work, really great reservoir.
  14. Cheapskate
    13 May 2007
    Sweeet!
    @Langer - OK, it's not exact, but it works if you do the custom fit thing I said.;)
  15. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Hydros Core Reservoir/NBSB Block
    Hey Guys! I finally have enough stuff to post a decent update! So here is what I've been up to.
    First, here is my Rhino drawings. This is just to get a good idea of what I am trying to accomplish. I don't have the bolts drawn yet.
    Here is my little piece of copper plate. 7" x 7" x 0.25"
    The only problem is I need .200" so the block will fit underneath my graphics cards. Solution:
    After plainning, I scribed out the drawing onto the copper. If you look closely on the drawing you can see the start of the O-ring being drawn in but we decided to go with a gasket setup instead since space is so limited.
    After scribing, I broke 2 9/64 end mills I switched to a 3/16 and got the rpm and feeds right.
    This is all I have done for now. I am going to do as much as possible with the larger end mill then I will switch to a smaller one for the tiny channel areas. After the channels are milled I will go back with some files and sandpaper to clean up the rough areas.
    I hope to have more soon! :D
  16. DonT-FeaR
    23 Jul 2008
    Wow looks great man keep it up
  17. The boy 4rm oz
    10 Apr 2008
    Sweet, custom NB/SB block.
  18. stonedsurd
    11 Mar 2009
    Amazing! :jawdrop:
  19. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    That's a beautiful looking reservoir. Are you going to be running one loop from that Danger Den CPX? I think it may well struggle with all the 180 degree bends of the NB-SB block and CPU/GFX as well.
  20. Kewtdz
    Kewtdz Hydros Core
    12 Mar 2009
    Update
    Well I am only going to be running a loop for my CPU and NB/SB. I don't really need liquid for the graphics cards I am using. Also for the mosfets I am going to make a passive heat sink but I will tell you more about that when I get closer to making it.
    For now here are a couple more photos:
    I am going in tomorrow for about 7 hours so I will have more then. Thanks for all of the complements.
