Hardware Intel Core i5-760 Review
Discussion in 'Article Discussion' started by Lizard, 15 Oct 2010.
  1. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Intel Speedstep or whatever they call it now works in this way.
    My i7 920 clocks down when it isn't loaded (even though it's overclocked) and this chip should too (assuming to don't switch the features off in the bios).
  2. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    I'm waiting on Ivy Bridge... :D It should appear in Q4/2011... :p
    (Wiki)
  3. Zaim
    Zaim Minimodder
    18 May 2010
    The review was good but disappointing. why didn't you include the Phenom X6 1055t? its the same price as the I5? you had the i7 in there so don't understand why the X6 from amd isn't there.
  4. Nature
    Nature Minimodder
    21 Nov 2005
    Dear Mr. Goodhead,
    i5-760
    Speed8/10
    Features9/10
    Value9/10
    Overall9/10
    Phenom 2 X4 Black
    Speed7/10
    Features9/10
    Value7/10
    Overall7/10
    Why do you round down for one and round up for another?
  5. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    If memory serves, the overall value isn't a rounding of the top three. Different readers and customers may value each of the first three scores differently, some may want the most speed and not care about value as much. Some may be just the opposite. And for any given product there may be features which aren't sufficiently covered by the first three scores. The Overall score is Bit-tech's/the author's perception of the product as a whole. None of the scores are based on a scientifically rigid process. Look at the benchmarks for those types of figures. :)
    In the case of the two products you list I'd assume that the i5-760 scored as if it was rounded up because of its overclocking potential. The X4 Black was probably scored lower because even though it's a decent product, there are better options at its price point.
  6. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    That's a good spot, we needed a picture for the how we test page and I'd forgotten to take one so I dug up that one in a rush and didn't check it close enough. I've swapped it out now.
    We used the latest F11 BIOS for testing, the first thing we did when we found the issue was to check the BIOS was up to date.
  7. Material
    13 Apr 2010
    As Sloth points out the Overall mark isn't simply an average of the other three marks. We consider speed and value to be more important than features when it comes to CPUs, hence they tend to have more of a weighting when we discuss the overall score the product should get.
  8. mickjc
    mickjc What's a Dremel?
    5 Nov 2009
    @Xir,
    "And while there are great overclocking gadgets out there, the software that allows you to say: OC now (4.1 Ghz), I'm gaming, and stop overclocking, I'm going to surf, isn't really around now, is it?"
    There is: it's AMD's Cool and Quiet...
  9. -EVRE-
    -EVRE- What's a Dremel?
    12 May 2004
    It appears B-T is putting a lot of emphasis on overclocking.
    Maybe instead of rating a processor WORSE because it doesn't overclock well, have overclocking performance be its own rating category and base the value and performance based on its stock clocks.
    This would help B-T cater to a wider audience. As it is BT is only catering to the overclocker. I admit I am curious to find out how well it overclocks. However I would not base my decision on what to buy based on overclocking. I may be one of those poor saps who buys a processor only to find out it wont clock well.
    *edit*
    this post was started well before Material's comment.
  10. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Well hopefully after reading the reviews here you will choose a processor thats OK!
  11. Zaim
    Zaim Minimodder
    18 May 2010
    Well, not for those trying to chose between a 1055t and a i5 750/760
  12. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    would you be bothered at all to test again with the F10, just to see if the boost works on that one? Sometimes the BIOS people make one step back, two forward it seems :p:p
  13. Nature
    Nature Minimodder
    21 Nov 2005
    If the criteria for math here is an invisible category: overclocking potential, and/or how the overall score "feels" to the author based on how important the speciffic category is to him. Then isn't it logical to define and value each category scoring worth?
    For example: 1 speed point = 1.33 points
    1 feature point = 0.xxpoints
    1 value point = 0.xx
    Total=xx/xx
    Why isn't overclocking potential, heat & temps, and how we feel about the product categories if they are going to determine the overall score?
  14. Kaihekoa
    Kaihekoa What's a Dremel?
    26 May 2010
    The only negative against this CPU is that Intel's next generation of chips will be out early next year and will require a new socket/motherboard. The initial Sandy Bridge chips are supposed to be mainstream too. Unless you <b>need</b> an upgrade or don't mind buying a MB thatwill be obsolete in 2011 I it would be wiser financially to avoid buying any Intel CPU until Sandy Bridge.
  15. Makaveli
    Makaveli What's a Dremel?
    25 Nov 2009
    I'm on a 920 at 3.6 and turbo is disabled I however don't browse the net at 3.6
    Speedstep is your friend!
    Machine downclocks to 2.2Ghz and stays there for most light workloads.
    Running the machine at 4.0+ without speedstep would be stupid!
  16. Snips
    14 Sep 2010
    Can we get an overclocking guide using the most common boards revised for this processor?
  17. Xir
    Xir Modder
    26 Apr 2006
    I was under the impression that this article stated, non overclocking the chip was a waste, and WHEN overclocking, Intel Turbo was disabeled.
    (doesn't mention speedstep anywhere, so I don't know if this is enabeled in the overclocking tests)
    *I suppose this regime of disabling goes for C&C as well. I use it, but I don't overclock.
  18. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    Consistently clocks higher at lower temperature than the i5 760, that's how I managed to squeeze 3.6GHz out of one in the Game Cube. It is the i5 equivalent of the 930 and Q6600 G0 refreshes. Would still like to see some 32mn Quads for the 1156 platform then we might bee looking at 4.5GHz OCs on reasonably priced systems.
  19. Xir
    Xir Modder
    26 Apr 2006
    Which one are you talking about, this article is about the i5 760...:confused:
    (so the i5 760 consistentently clocks higher ... than the i5 760 doesn't make sense)
  20. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    I agree. We should always wait for the next hardware. That way financially we would never pay for new hardware because we would never buy new hardware because we would always be waiting for the next hardware upgrade that Intel or AMD will release in the future.:wallbash:
Tags: Add Tags
