Scratch Build – In Progress Level Eleven
Discussion in 'Project Logs' started by slipperyskip, 1 Mar 2010.
  1. The boy 4rm oz
    10 Apr 2008
    I think Bod hit the nail on the head with the button placement.
  2. Combatus
    16 Feb 2009
    Looking great!
    Is this the customary slipperyskip can of coke?
    :D
  3. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Yes. The Coke can has been declared to be the USC (Universal Size Comparator). However, I have recently discovered that AA batteries will do in a pinch. Some of my other can work over the years...
  4. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Cut a piece of aluminum and temporarily placed it. I start out with a full box-width aluminum band even though the shadows distort it somewhat. You'll also see a slight overhang at the edge because...well...that's the way I do things.
  5. stonedsurd
    11 Mar 2009
    The beer strip looks good. I'm just not sure on the switch.
  6. floppyeardbunny
    floppyeardbunny What's a Dremel?
    4 Jan 2006
    so pretty...
    make me happy and want to mount it... to my wall.
    but white plastic in USB ports is driving me NUTS. Sharpie it away please. Light brown sharpie should look nice...
  7. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    Your work is excellent...respect.
    I dont personally like the chrome zig zag, i think a more sundial ish pattern would have been more appealing.
    I am not sure on the button being bright chrome especially against the matte finish on the fins.
    Square button...Mother of Pearl ...for me :)
    Love this project.
  8. skreenname
    skreenname SFF Forever
    11 Jun 2009
    That extra Aluminium looks great.
    I kind of like how it looks without a button.
    But then again I've got a monolithic case.
  9. talladega
    talladega I'm Squidward
    18 Aug 2007
    agreed!
    also, where can I buy one of those super tiny motherboards?
  10. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Well, there is no switch. Only a button to an imaginary switch. :hehe: I would never put a real switch on the SSD box because then it would become tethered by a wire. I could have just as easily placed the aux ports on the back of the Pico box but didn't for the same reason.
    Done. Thanks for that! Good idea.
    Thanks. Lots of possibilities here. Too many. Any one remember Mission? What color side panels? Big difference here is that changes are pretty much permanent.
    Please analyze attached photos and respond...thanks in for the feedback!
    This is as far as my pimpage will go. You might want to look at the new Artigo 1100. It contains the same board plus it has other bits like front panel ports all for the same price. I think the board in the Artigo has a slightly different HSF but I could be wrong.
    VIA Store
    After scoring the outline I used my razor knife to literally carve out hundreds of tiny little pieces of cherry. I did this hopefully to prevent any slippage and subsequent damage to nearby surfaces. It worked.
    When the underlying basswood started to appear I switched over to my small straightedge to use as a scraper. I had originally used the straightedge's width as a guide to the aluminum band's width so this all worked real nice.
    Result of efforts. A hobby file was used to trim down the edge of the adjacent aluminum and fingernail files were used to flatten out the new surface. Garnet-based fingernail files NOT emory-based ones.
    Playing around with a look. A small black bit on the front might not look too bad considering the other small black bits on the back. The DE box is out for final massage and spraying.
    Thanks for looking.
  11. talladega
    18 Aug 2007
    Thanks for the link!
    Bookmarked for future reference!
  12. stonedsurd
    11 Mar 2009
    Hm. The button doesn't look half bad.
    Can we have a picture without it?
  13. skreenname
    11 Jun 2009
    I think I'd go with no 'button'.
    I really like how pure it looks with just the Aluminum strip.
  14. slipperyskip
    slipperyskip Member
    26 Oct 2003
    You do know that is wood and not metal right? The actual metal piece is still prepared to go completely across...if need be.
    The punch line is "Everyone's got one".
  15. talladega
    18 Aug 2007
    no button.
  16. skreenname
    11 Jun 2009
    Assuming that was directed to me, No I didn't.
    But I kinda like how it stops.
    Also I just noticed that you changed the color of the USB ports.
    Looks great.
    I just stared at this comment for five minutes before I realized what I was doing.
    I need to go to bed.
  17. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    I'd vote for no button as well. It looks a lot more clean without it, much like the rest of the design :)
  18. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Yep I'm with the rest here, no button IHMO. Nice work on those usb ports. I'm also amazed by the way you carved out material for the extra piece, I envy your patience!
  19. MikeMania
    MikeMania What's a Dremel?
    25 Feb 2009
    What if the button was the size and shape of the remaining material needed for the strip to go completely across? It would blend in a bit more, but that would be one big button.
  20. devilxc
    devilxc Biding my time...
    23 Mar 2010
    Much cleaner without a button, I also like the strip along the full length of the side.
    Great work.
