Scratch Build – In Progress Megablaster 2010 work log (diy ghettoblaster)
Discussion in 'Project Logs' started by drakmin, 14 Mar 2010.
  1. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Use a coordinate measuring machine. If you wait a few weeks they will show Haoki and me how to operate one. And if we get lucky that thing will fit inside the working space of the one in the student metrology lab at TTY.
  2. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    True... Thought about that solution as well :) Btw... It's next week we'll have to get into grips with that one. :D Oh and the 0.5 mm accuracy shouldn't be any problem :p
  3. drakmin
    drakmin I don't use Dremel.
    20 May 2006
    Javerh: oh cool! Blaster measures roughly 70x35x14cm.
    Sleepstreamer: Yes I wan't highly glossy black finish. I tried this technique already with my subwoofer. Sub had less strange shapes so laser cut parts fitted without any work. Here's two shots how it looks:
  4. The boy 4rm oz
    10 Apr 2008
    This is some seriously awesome work, as are your previous builds. I will be keeping a close eye on this one.
  5. Autti
    Autti New Member
    29 Oct 2009
    Why are you making it sealed out of interest? Wouldn't that just decrease the sound volume and require more power to be louder?
    *with my rudimentary understanding of sound physics
  6. Javerh
    5 Sep 2006
    ^^ Speakers produce a front wave and a back wave. Usually when the back wave gets out of the speaker box it is out of phase with the front wave. The back wave then interferes with the front wave diminishing the sound pressure level. The back wave can get out through unsealed joints. This can also produce hissing sounds when air rushes through.
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    You sure about that, go look at all speaker boxes, and you'll find they are sealed.
  8. The boy 4rm oz
    10 Apr 2008
    Unless they are a woofer box, then they have an air duct.
  9. Autti
    Autti New Member
    29 Oct 2009
    Err... look at the pic above of his custom made subwoofer box.
    It's mostly used on woofers because they move a lot more air than normal speakers and at lower frequencies (obviously), but the holes are actually designed to increase sound and are placed so that you get a correlating wave coming out so it doesn't create a point of no sound with the woofer in the room.
    It's physics :)
  10. Javerh
    5 Sep 2006
    ^^ No. That's already acoustics. And physics ain't part of philosophy anymore.
  11. oliverw92
    oliverw92 New Member
    15 May 2009
    Nice woodworking skills! I love it!
  12. drakmin
    20 May 2006
    I'm making it sealed since the bass drivers in my build work best in sealed box. Some drivers work better in reflex box (the box with "duct" aka. reflex port) Properly designed reflex box will add couple of db's to the lowest bass. Main problem with reflex tuning with my drivers would be the size of the box. Blaster would be even bigger if I chose reflex box. I have two bassdrivers since it guides the bass frequencies more to the front of the box. Normally bass frequencies escape to all directions. When listening in a room this is not a big problem.
    So I have this 20 liter sealed 2x8" box. 1x8" driver would work in same 20 liter reflex box but I will get more bass from sealed box since it looses less bass to wrong directions because it has more drivers. Reflex box has also steeper roll off curve so bass extension cut's just where the tuning frequency is.
    To make it short is chose sealed design as I wanted the box as small as possible.
  13. m0rt
    m0rt New Member
    27 Dec 2008
    How many volts are you powering the amplifier with? I ordered one since I was curious and I found out that there is a big difference between 12 and 24 volts. Guess you get more watts with more volts.... but have you tried?
  14. drakmin
    20 May 2006
    2x100W @ 36V. My battery is 18,5V which gives me about 2x40W
  15. drakmin
    20 May 2006
    Finally attached the handle:
    Placement of crossover and amplifier:
    Grilles:
    Scanner running:
  16. drakmin
    20 May 2006
    First test of the led scanner, sorry for the cellphone quality:
  17. drakmin
    20 May 2006
    Measuring the box with help of Javerh. Now I start drawing the plastic parts in CAD.
  18. Javerh
    5 Sep 2006
    Too bad I'm not familiar enough with the interface. We couldn't get all the needed dimensions.
  19. Jipa
    5 Feb 2004
    What the heck.. Ghettoblaster goes hi-tech..
  20. drakmin
    20 May 2006
    I removed the fan from the amp and went to lan party to test if it runs without fan. Amp works great when taking 30-40w power from it. I gave the unfinished blaster a good abuse and since it survived the weekend I can now finish it. Here's some cover parts I've already drawn.
    I hope this short clip gives some idea of the sound it generates, it's pretty loud since you can't hear the 20 drunken people talking and shouting in the room :]
