Scratch Build – In Progress My Now finished mean Computer Numerical Control machine build
Discussion in 'Project Logs' started by Teelzebub, 21 Jul 2014.
What colour should it be painted?
  1. Red
    10 vote(s)
    34.5%
  2. Blue
    5 vote(s)
    17.2%
  3. Silver
    3 vote(s)
    10.3%
  4. Black
    7 vote(s)
    24.1%
  5. Mixed
    8 vote(s)
    27.6%
Multiple votes are allowed.
  1. David
    7 Apr 2009
    We need some hot CNC action!
    Where da vidz?
  2. Teelzebub
    27 Nov 2009
    Did a bit of test cutting turned out a bit too hot lol
    Should happen soon, just finishing setting up the limit switches etc
  3. Teelzebub
    27 Nov 2009
    Cutting that from 15mm thick plate
  4. David
    7 Apr 2009
    I want one.
  5. bulldogjeff
    2 Mar 2010
    It's alive...:jawdrop:
  6. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Jealous.
    This is what you call a 'real man's' toy.
  7. Nexxo
    23 Oct 2001
  8. bulldogjeff
    2 Mar 2010
    This is probably closer to the truth than you realise Nexxo
  9. Cheapskate
    13 May 2007
    Video:"Miiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiingbuuuuuuuuuuuuuuuuuuuuuuur"
    Ah, yes. I remember now why I chose the rig I have. It may be slow and small, but I don't think I could survive a few hours of earpro-penetrating whine.:lol:
    Definitely need flood coolant if you are going to be cutting at that speed. It would be catastrophic if the blade gummed up. That "tic, tic, tic" Is the blade catching/hitting chips if you didn't already know.
  10. Teelzebub
    27 Nov 2009
    Yeah flood and mist is coming, also that's why I'm using carbide bits they can stand hotter temps although by looking at the chips it's not getting hot at all no bluing on them , I was going to fit a air line to it to clear the chips but for some reason the compressors gives off emi and interferes with control signals.
    God know how to shield two compressors lol
  11. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Distance!:wallbash:
  12. Teelzebub
    27 Nov 2009
    Yeah but unfortunately getting them far enough away is not possible anyway the air lines would have to very long that way
  13. Cheapskate
    13 May 2007
    Yes! Plug it into your neighbor's grid.:hehe: It sounds like you need to shield the controller.
    I've done better with lower speeds because the higher RPM was actually throwing the lube off and never making it to the cut. -Made a mess too.:D
    Wait, 2 compressors? can you daisy-chain them together and not power the one closest? Just use it as a extra tank.
  14. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    If you are getting interference through your wiring you could try a line conditioner on the CNC. Tripp Lite makes some relatively cheap ones that might help.
  15. Teelzebub
    27 Nov 2009
    The controller is completely shielded and is all the cables which is all shielded cables that's why I didn't expect it, they are daisy chained to run a sand blaster both does the interference regardless of what one is used can't get any further away only thing left to try is a different ring main not got my hopes up though, Maybe build a shielded box around the compressors
    If you look at the vid you'll see it wasn't spitting the coolant out though
  16. Nexxo
    23 Oct 2001
    Time to quit all that amateur stuff and do it proper: mad scientist's lab in the basement of a Gothic mansion. Tesla coils. Lightning rods in the tower. Glass jars with strange things in them, coiled and twitching in a pulsating green glow.
    And hire an Igor. Must have an Igor to throw The Switch at your cackling command.
  17. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Awesomly Insane :thumb:
  18. Teelzebub
    27 Nov 2009
    Interesting idea and certainly worth a try, thing is the compressors are on completely different ring main from the computor but the PSU for the control gear is on the same one as the compressors.
    Looks like I have a job for you mate :hehe:
    Thanks insane is always a good place to start from :hehe:
  19. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Ah I see, well before you start spending money I would try running an extension cord to a different ring main from the compressors if you haven't already. That extra isolation might help. Out of curiosity, what power supply are you using for the drivers and controller?
  20. Nexxo
    23 Oct 2001
    Yeth, master!
