Case Mod - Complete Neptune's Trident: Wallpapers
Discussion in 'Project Logs' started by Boddaker, 31 Dec 2008.
  1. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Sometimes the regular ones get boring and, well, regular. Gotta mix it up every now and then :p
    Congrats on the MOTM nomination!
  2. Guest-23315
    Guest-23315 Guest
    Congrats on MOTM bod..
    And as always, :thumb:
  3. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Wow, thanks guys, and thank you BT for the MotM nomination! :rock:
  4. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Congrats Boddaker! :rock:
  5. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    congrats bro
  6. DragonONE
    DragonONE What's a Dremel?
    27 Jun 2007
    Congratulations on the nomination - you have my vote for sure..
    Cannot wait to see that waterfloor in action....
  7. jhanlon303
    7 Sep 2006
    I had to vote for this one for old time's sake. It was a Boddaker mod - Mystique 2 - that got my modding out of the closet and into the forums.
    Good luck and Thanx for sharing another mod with the world.
    john
  8. milotic858
    milotic858 What's a Dremel?
    20 May 2008
    congrats on MotM nomination! got my vote:thumb:
  9. Boddaker
    30 Nov 2006
    Thanks all! :D
    Thanks John. It's always nice to know my work has inspired others!
    I'm finishing up a cool piece for the video cards, and should have another update for ya tomorrow. It's a cable cover that will route all those unsightly video card power cables down through the motherboard tray and hidden from view. And of course it's trident shaped. :p
  10. Jipa
    5 Feb 2004
    How come I have yet to comment in this build :O
    Good job all the way! The water-bottom-thing is just such an insane idea... It's always a time to celebrate when someone comes up with such an idea :) 3 loops in one case seem crazy enough, but if you can pull it off so neatly, why not?
  11. Boddaker
    30 Nov 2006
    Made a piece to cover the ends of the video cards, where all the power cables plug in. I wanted the cables to be hidden,
    so I fashioned a trident-shaped cover that routes the cables down and through the motherboard tray. I'm making
    my own extension cables too, so the actual power cables from the psu will plug into these behind the mobo tray.
    Here is the mess of cables: two 6-pin plugs for each card = 36 wires!
    First thing I did was glue them all together with some acrylic and styrene spacers.
    Once glued, I can remove them all as one.
    After measuring, I cut out the trident shape and side pieces.
    Gluing them together, using the ruler as a square:
    Testing the cable assembly in the cover..
    Test fit on the cards (one of many, many test fits lol)
    Another test fit, this time with more side pieces glued onto the cover:
    You can see how the cables are being routed to the center of the cover and down.
    After the usual sanding-filling-sanding routine, the cover got a coat of white and pearl, like the others.
    Here's a close up shot of the hole I made in the motherboard tray, where all the wires will go through. The cover will
    conceal this hole from view.
    A wide shot of the video cards with cover. The cables are not plugged in yet. I will need to have the case reassembled
    to finish the wiring on the other side of the mobo tray.
    A final close up shot of the cover. I had hopes of permanently gluing the cable assembly into the cover, but plugging
    all six connectors in at once proved very difficult at best, and would be near impossible when concealed by the cover.
    So I will be leaving the cover loose.
    Next up are the three custom bottom plates for the vid cards. :D
  12. haakon.t
    haakon.t :)
    8 Dec 2007
    Your attention to detail is stunning! Really good work on the cover :)
  13. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
    really nice idea, gratz!
  14. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Nice work! Where do you get your cable making supplies?
  15. Matticus
    Matticus ...
    23 Feb 2008
    Flipping 'eck, that looks incredible.
  16. Boddaker
    30 Nov 2006
    Thanks guys! :D
    Got 'em from Moddersmart. :thumb:
  17. Guest-23315
    Guest-23315 Guest
  18. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Great ideas and amazing modding skills man! Bravo!!!
  19. Carpet3
    Carpet3 Minimodder
    2 Mar 2004
    looks really nice :D
  20. The boy 4rm oz
    10 Apr 2008
    Bod that is such a cool idea, and unlike my cool idea that turn out very very bad, yours looks awesome hahahaha.
