Case Mod - Complete Neptune's Trident: Wallpapers
Discussion in 'Project Logs' started by Boddaker, 31 Dec 2008.
  1. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Interesting. I'll keep my eye on this
  2. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Work continues on the PSU area.
    In order to fit the power supply where I wanted, I have to stand it on end. Which meant that I had to remove part of the case
    for airflow and to reach the power switch.
    I turned the case over and removed the back wheelset. I forgot to take a shot before cutting, so here's what it looked like lol.
    And here's after the cut. I later had to remove a bit more from the bottom of the case to clear the power switch. You will notice
    in the next couple of pics I repositioned the wheelset forward a bit.
    Here is the original back plate. I'm cutting off the PSU mounting portion and relocating it.
    Relocated! Now I can place the PSU in for a test fit.
    I'm using Corsair's 1KW power supply, which can accommodate the three EVGA GTX 260 cards in SLI. It has six 6-8pin cables
    right out of the box. No need for molex adapters!
    It is quite long, but it fits!
    Since I mutilated the original backplate, I needed to make a new one. So I grabbed some left-over aluminum panel and cut one to size.
    Then I curved the bottom portion so it would match the corner curvature of the case. Looking around the garage, I found a ladder
    wall hook to have a suitable tube diameter to bend around. :)
    And back on the case.
    Last thing to do was to cut the fan hole. The Corsair psu has a 140mm fan, so I found the center, used a compass to draw a 5 1/2"
    circle, and cut it out.
    I'm working on getting some grills made, so that will cover up the hole and finish it off.
  3. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Quality work as always Brian! That new backplate looks excellent.
  4. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice design !
    interesting way to place the psu,
    it will be hard to plug in the power cord :)
    keep on with the good work :dremel:
  5. craigbru
    28 Feb 2008
    He doesn't need any power cord... His awesomeness radiates electricity... :lol:
  6. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    The PSU should be OK with a 90degree Power Connector as it is raised from the floor with the wheels.
  7. Boddaker
    30 Nov 2006
    Yep I was just going to say I am planning on using one of these
    LOL thanks Craig!
  8. The boy 4rm oz
    10 Apr 2008
    Nice idea of moving the PSU mounting location Bod, that should give you a lot more room to move in the case.
  9. jhanlon303
    7 Sep 2006
    Never one to do a simple mod, Eh Bod?
    sweet!
    john
  10. InferiorPlanets
    InferiorPlanets Worshiping the SilverStonehenge™
    22 Jan 2008
    My thoughts exactly Craig! Boddaker fact #1- Boddaker modded Chuck Norris! :hehe:
  11. Boddaker
    30 Nov 2006
    Well, that was my intent with this one lol! This was supposed to be a simple, straight-forward build as opposed to my last one. Comparatively speaking, it still is I guess. Hell, I don't know what simple is anymore! :hehe:
  12. Boddaker
    30 Nov 2006
    rofl!
  13. Boddaker
    30 Nov 2006
    Got a bit more work done last night. Made the pieces that will go in between the Typhoons and around
    the corner to complete the trident shape.
    I used more of the left-over side panel and cut two 9/16" strips.
    Then I bent them 90°. Here's a shot of them in place to give you an idea. They will just be mounted to the
    wrap-around window with double-sided tape, as I dont want any visible fasteners.
  14. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    This is already looking fine!
    Subscribed!
  15. The boy 4rm oz
    10 Apr 2008
    Nice work on the window, I can't wait to see it finished.
  16. jhanlon303
    7 Sep 2006
    You got a different gravity in Bodsland than we do here in Colorado?
    What holds up the two cards/stuff in the front? Blue tape? Seems adequate but not up to your standards?
    john
  17. headala
    headala What's a Dremel?
    9 Oct 2005
    I love it!
  18. Boddaker
    30 Nov 2006
    Smallish update just to let you know I'm still working on it :thumb:
    Laying out the rads and fans placement, I whipped up some quick mounts from angle bar.
    Then I laid them out to see where they will eventually go.
    I'm working up some custom acrylic one-piece mounts that will look much better than these ones.
    I also did some cosmetic work to the front of the case. It seems that Lian Li forgot to drill some holes in this one area,
    and they just stuck a square name badge over it to cover up their mistake! :lol:
    Well, not to worry, I'll take care of it...
    I used the corner piece I cut out as a guide to drill out the missing holes.
    All done, save for some sanding and filing. :)
    I will have a custom name badge mounted over this area, so it has to look uniform, which is why I drilled out the old LL badge.
    I should be able to get some more work done over the weekend, so til then!
  19. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    This is truely inspired!
    Subscribed :)
  20. Cheapskate
    13 May 2007
    Yeah!!!! Get rid of that logo!! Whoo!!
    I never liked that part...
