Awesome! You really do some amazing things here Are you finish? Since Cebit06 is over (soon?), then you must be finished? Me want pics
That's coming along fantastically. How did you measure the size/shape of the wing skins that you needed to cut as they are complex curves (curving in different directions in 3 dimensions) and how did you tension them? I love how you hid the stitching. Very smart. I can't wait for the next update.
I have equipped of the Cebit. The nkcm stand for the door. Time to go to the work As first remove the hardware. Than do something with the pyramid. I hope that it looks more to a rock when I am ready with it. That needs some time to dry. Also I remove the paint from the wings. The result after 3 hours. Tomorrow more.
Woot i thought that you had stopped this, god to see you back. Shame that you couldn't finish it the way you wanted before Cebit
Sorry to say but this case, in my opinion has nothing to do with case modding. Unlike your really cool case extreme lian li! That one is really cool. Only this one is more or less building an odd shape bock and stuffing computerhardware inside. I understand that it was for a sponsor so ok thats ok. Good luck with this one and your other ones. Also keep up the good work at tweakers.net!! Dutchies rule!!
Firstly I put the knife in the ****. After that polyester, where necessarily. After that in the ground paint. After that darker grey, the basis layer for the rock effect. Here you see the color difference better. I say till tomorrow
That looks nice Ed, but i was wondering how you gonna make the cover for the hardware, do you gonna the complete cover from plexi ? I've never seen you bending plexi, but anyway, it will look wonderfull like always!
The black paint also on the rocks now. Also I have started a job for monks. That nail on its body was gold-colourful. I forget do. Again I paint its tail red. Its mouth finishes what I still had do. Also inside his mouth. Also the other side. For the rest hyphens make. A lot of hyphens. And also I have a bench of 5 meters. Troop I make it everywhere. See you later.
Yes I make a full plexi cover for the hardware. You never seen me bending plexi. But I can tell you that I in former days have working in a plexifactory.
The first color was to bleu the second to grey. So I mixed them. Its glass must more around. This is the first part from the way I make that. Also on his snout I must do some things. I make his nose holes bigger. It is not 100% yet. I put the primer on the nose to see where I must fix some things. And than, I fill it with polyester. Than do your job with grid paper. So as you can see there are some small holes to fill with polyester. See you next time.
I find it terrible from everything wat's happend around the Batcase and the NKCM But your case is still amazing
@ Jado, and al the other people please don’t talk about the Dutch NKCM. But talk about the Batcase that’s where this topic for is.
