Project BatCase **R.I.P.**
Discussion in 'Project Logs' started by Ediejo, 15 Aug 2005.
  1. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Project BatCase
    -Introduction
    -What's the plan?
    -Construction plan
    -Materials
    -Hardware
    -Updates
    The time has come to build a new casemod. Jurgen from Point of View has given me a green light to start this casemod.
    This casemod will be a demo-case for Point of View at Cebit 2006
    What's it based on?
    As an inspiration I'm going to use the Point of View bat which is on the box of a 7800GTX!
    Construction plan
    The bat will be placed on a pedestal, this will be a piramid that will be covered with a rocklike structure. The colours of the box will be re-used.
    Inside the piramid will be some hardware and a part of the watercooling.
    The bat will be attached to the pedestal with an iron tube (welding).
    The hoses of the watercooling and the necessary wiring will go true it.
    In the body of the bad will be the mobo, behind the shields on the bat.
    In the head, in the place of the eyes, will be 2 reservoirs.
    Material
    -Several colours of plexiglass. (Shields and mobo must be visible)
    -Leather for the wings and part of the body.
    -Preformed shape to pour little rockcubes.
    -Iron to make a frame.
    -You will see how I'll build it during updates!
    Hardware
    -Videocards: Point of View 7800GTX
    -Psu: Be Quiet Dark Power 600W
    -Watercooling: Innovatek
    -Cpu: Amd type?
    -Mobo: Epox EP-9NF4 SLI2
    -Mem: Corsair XMS Expert
    -Harddisk: ?
    updates
    Update 1
    Update 2
    Update 3
    Update 4
    Update 5
    Update 6
    Update 7
    Update 8
    Update 9
    Update 10
    Update 11
    Update 12
    Update 13
    Update 14
    Update 15
    Update 16
    Update 16
    Update 17
    Update 18
    Update 19
    Update 20
    Update 21
    Update 22
    Update 23
    Update 24
    Update 25
    Update 26
    Update 27
    Update 28
    Update 29
    Update 30
    Update 31
    Update 32
    Update 33
    Update 34
    Update 35
    Update 36
    Update 37
    Update 38
    Update 39
    Update 40
    Update 41
    Update 42
    The Beginning
    The base of the piramid
    A few dots and it's already looking better.
    This is where the cd-rom will be placed
    After some work with the Dremel :dremel: there's a hole for the cd-rom
    And it fits. I don't weld everything because of the tension in the material.
    Everything will be covered with rocks anyway. The space between the base and the tilted sideplate is for airflow.
    This is how it looks like from behind, I only placed half of the panel there to see if the psu would fit. This isn't the actual hardware, it will be replaced soon.
    More updates soon! ;-)
    The WaterCooling
  2. Pete_Venkman
    Pete_Venkman What's a Dremel?
    20 Jul 2005
    Looks like a good start...nice clean pyramid. I'm extremely interested to see how you plan to recreate the bat...
    BTW, I have to admit I was expecting a Batman theme...but this looks cool.
  3. Franklin
    Franklin Minimodder
    24 Oct 2004
    Welcome Ediejo. I see you found you're way to Bit-tech too. This is a mod I will watch closely. Ediejo is known for some very good mods in Holland, so I'm sure this one wil be very good too. Promising plans you got there.
    Impressive hardware those 7800 videocards!
  4. Ediejo
    31 Jul 2005
    @Pete_Venkman I build that with my hands, from steel. Afterwards covering with several material leather and plexiglass.
    @Franklin thanks for the welcome, and yes i will show this mod on bit tech, because bit tech was for a part an inspiration for me first casemod. I think the idea is orgineel I can place it also on bit tech. And publicity for Point of View and Innovatek
  5. roadkiller
    roadkiller What's a Dremel?
    6 Jun 2005
    Surprisingly few reply's, knowing that Ediejo is a modder well known in the Netherlands. His previous mod (that maked him "famous" :rolleyes: ) is this one: Clickie
    I heard it's going to be huge, having the motherboard, radiators and the sli gfx cards inside the bat. Nice :clap:
    Dutch mode:
    Kvoel me vereerd om beetje aan je TS mee te mogen geholpen hebben (samen met tim) en keep up tha good work.
  6. Jathm
    Jathm What's a Dremel?
    15 Oct 2004
    looks very promising so far i cant wait to see the result of this mod. especially with the very nice hardware going in there.
  7. Hackjedi
    Hackjedi What's a Dremel?
    7 May 2004
    THE EDIEJO has come to bit-tech :jawdrop:
    cool mate :thumb:
    so your LI is finished then?
    nice start so far. as we could expect from you
  8. JamesM
    JamesM What's a Dremel?
    8 May 2005
    Looks great, will be watching this :)
  9. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    hey Ediejo, good to see you on the job again :hip:
    Looking forward to watch this project. A hell of job if you ask me but I'm sure it's going to be a beauty again. :dremel:
  10. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    :worried: The bigger the challenge, the greater the fun HUH?
    You have to have modded balls to try to build that...
    I wish you good luck senjor. :rock:
  11. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Looks nice, good luck.
  12. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    I like what you're planning to do with it, nice work hope to see more soon.
    Subscribed :)
  13. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    Nice welds.
    MIG is where it's at.
  14. Ediejo
    31 Jul 2005
    Due to illness I haven't been able to do any work on the casemod, I don't think I will work on it this weekend either, so a real update will be after this weekend. The watercooling is ordered though, this will be the set up:
    CPU cooler, the red one:
    Chipset cooler: again, the red one:
    Radiotor: 2 radiators, one on the left, and one on the right of the mobo:
    Reservoir, These will be on the place of the eyes:
    2 pumps, these will be inside the piramid:
    Plugs:
    Watercoolingtubes, again the red one:
  15. Ediejo
    31 Jul 2005
    Project Batcase.
    The Project log.
    I move the Discussion to this part from the form.
  16. Ediejo
    31 Jul 2005
    I wanted to wait to 1 Jan 2006 with update.......... But here then at last an update. ;) The only part I use from a regular case is the mobo panel. I choice this one as the victim.
    The treatment.
    The setup of the hardware and radiators. With a drawing where its tail must come.
    Some more steel to shape
    Then starting to build the lower part.
    Looking or it will be appropriate. Yes that looks well for me.
    On its tail still a red shield sits I makes that this way.
    Of course there comes still what across, the first low polyester.
    And now wait to it is hard.
    I move the Discussion to this part of the form.
  17. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    waiting for updates....
  18. Ediejo
    31 Jul 2005
    30-12 Update 2
    The polyester is ready so I can move on. From the backside of the bat I have no example, Then what improvises. I make it from some small steel plates.
    Now it is possible that the pyramid and the bat can be weld to each other.
    Because I have only a poster as sample, there is more to improvise.
    Let the saw do the job
    The first part of his legs.
    sorry for the quality of the pictures I forgot my cam these are make by a foon.
  19. Ediejo
    31 Jul 2005
    Updated.
  20. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    Heey man, this will be a great mod too:)
    Was nice to come and watch it in real life.
    When this mod become's half as nice as the extreme lian li , it will be great.
    Still a lot of work to be done, but ok.
    Really nice job:):)
